Holds NvMedia display attributes.
Definition at line 2930 of file nvmedia_common.h.
Data Fields | |
| NvMediaDispCompMode | compositionMode |
| Defines the composition mode for the layer. More... | |
| uint32_t | depth |
| Holds a positive value (up to 255) that specifies the video displays relative to the top-most layer. More... | |
| NvMediaRect | position |
| The rectangle where the video renders. More... | |
| NvMediaDispCompMode NvMediaDispAttributes::compositionMode |
NVMEDIA_DISP_COMP_MODE_OPAQUE
NVMEDIA_DISP_COMP_MODE_SRC_ALPHA
NVMEDIA_DISP_COMP_MODE_PREMULTI_SRC_ALPHA NVMEDIA_DISP_ATTR_COMPOSITION.
Definition at line 2937 of file nvmedia_common.h.
| uint32_t NvMediaDispAttributes::depth |
. NVMEDIA_DISP_ATTR_SET_DEPTH.
Definition at line 2942 of file nvmedia_common.h.
| NvMediaRect NvMediaDispAttributes::position |
NVMEDIA_DISP_ATTR_SET_POSITION.
Definition at line 2946 of file nvmedia_common.h.
