Holds H264 video usability information parameters.
Definition at line 1864 of file nvmedia_common.h.
Data Fields | |
| NvMediaBool | aspectRatioInfoPresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the aspectRatioIdc is present. More... | |
| uint8_t | aspectRatioIdc |
| Holds the acpect ratio IDC (as defined in Annex E of the ITU-T Specification). More... | |
| uint16_t | aspectSARWidth |
| If aspectRatioIdc is Extended SAR then it indicates horizontal size of the sample aspect ratio (in arbitrary units). More... | |
| uint16_t | aspectSARHeight |
| If aspectRatioIdc is Extended SAR then it indicates vertical size of the sample aspect ratio (in the same arbitrary units as aspectSARWidth) More... | |
| NvMediaBool | overscanInfoPresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the overscanInfo is present. More... | |
| NvMediaBool | overscanAppropriateFlag |
| Holds the overscan info (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | videoSignalTypePresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the videoFormat, videoFullRangeFlag and colourDescriptionPresentFlag are present. More... | |
| uint8_t | videoFormat |
| Holds the source video format (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | videoFullRangeFlag |
| Holds the output range of the luma and chroma samples (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | colourDescriptionPresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the colourPrimaries, transferCharacteristics and colourMatrix are present. More... | |
| uint8_t | colourPrimaries |
| Holds color primaries for converting to RGB (as defined in Annex E of the ITU-T Specification). More... | |
| uint8_t | transferCharacteristics |
| Holds the opto-electronic transfer characteristics to use (as defined in Annex E of the ITU-T Specification). More... | |
| uint8_t | colourMatrix |
| Holds the matrix coefficients used in deriving the luma and chroma from the RGB primaries (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | timingInfoPresentFlag |
| Holds that num_units_in_tick, time_scale and fixed_frame_rate_flag are present in the bitstream (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | bitstreamRestrictionFlag |
| Holds the bitstream restriction info (as defined in Annex E of the ITU-T Specification). More... | |
| uint8_t NvMediaEncodeConfigH264VUIParams::aspectRatioIdc |
Definition at line 1869 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::aspectRatioInfoPresentFlag |
Definition at line 1866 of file nvmedia_common.h.
| uint16_t NvMediaEncodeConfigH264VUIParams::aspectSARHeight |
Definition at line 1875 of file nvmedia_common.h.
| uint16_t NvMediaEncodeConfigH264VUIParams::aspectSARWidth |
Definition at line 1872 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::bitstreamRestrictionFlag |
Definition at line 1905 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::colourDescriptionPresentFlag |
Definition at line 1891 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH264VUIParams::colourMatrix |
Definition at line 1900 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH264VUIParams::colourPrimaries |
Definition at line 1894 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::overscanAppropriateFlag |
Definition at line 1879 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::overscanInfoPresentFlag |
Definition at line 1877 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::timingInfoPresentFlag |
Definition at line 1903 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH264VUIParams::transferCharacteristics |
Definition at line 1897 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH264VUIParams::videoFormat |
Definition at line 1885 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::videoFullRangeFlag |
Definition at line 1888 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH264VUIParams::videoSignalTypePresentFlag |
Definition at line 1882 of file nvmedia_common.h.
