Holds the H.265 video usability information parameters.
Definition at line 2226 of file nvmedia_common.h.
Data Fields | |
| NvMediaBool | aspectRatioInfoPresentFlag |
| If set to NVMEDIA_TRUE, specifies the aspectRatioIdc is present. More... | |
| uint8_t | aspectRatioIdc |
| Holds the aspect ratio IDC (as defined in Annex E of the ITU-T specification). More... | |
| uint16_t | aspectSARWidth |
| If aspectRatioIdc is Extended SAR it indicates horizontal size of the sample aspect ratio (in arbitrary units). More... | |
| uint16_t | aspectSARHeight |
| If aspectRatioIdc is Extended SAR it indicates vertical size of the sample aspect ratio (in the same arbitrary units as aspectSARWidth). More... | |
| NvMediaBool | overscanInfoPresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the overscanInfo is present. More... | |
| NvMediaBool | overscanAppropriateFlag |
| Holds the overscan info (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | videoSignalTypePresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the videoFormat, videoFullRangeFlag, and colourDescriptionPresentFlag are present. More... | |
| uint8_t | videoFormat |
| Holds the source video format (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | videoFullRangeFlag |
| Holds the output range of the luma and chroma samples (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | colourDescriptionPresentFlag |
| If set to NVMEDIA_TRUE, it specifies that the colourPrimaries, transferCharacteristics, and colourMatrix are present. More... | |
| uint8_t | colourPrimaries |
| Holds color primaries for converting to RGB (as defined in Annex E of the ITU-T Specification). More... | |
| uint8_t | transferCharacteristics |
| Holds the opto-electronic transfer characteristics to use (as defined in Annex E of the ITU-T Specification). More... | |
| uint8_t | matrixCoeffs |
| Holds the matrix coefficients used in deriving the luma and chroma from the RGB primaries (as defined in Annex E of the ITU-T Specification). More... | |
| NvMediaBool | vuiTimingInfoPresentFlag |
| NvMediaBool | bitstreamRestrictionFlag |
| uint8_t NvMediaEncodeConfigH265VUIParams::aspectRatioIdc |
Definition at line 2231 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::aspectRatioInfoPresentFlag |
Definition at line 2228 of file nvmedia_common.h.
| uint16_t NvMediaEncodeConfigH265VUIParams::aspectSARHeight |
Definition at line 2237 of file nvmedia_common.h.
| uint16_t NvMediaEncodeConfigH265VUIParams::aspectSARWidth |
Definition at line 2234 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::bitstreamRestrictionFlag |
Definition at line 2267 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::colourDescriptionPresentFlag |
Definition at line 2253 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH265VUIParams::colourPrimaries |
Definition at line 2256 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH265VUIParams::matrixCoeffs |
Definition at line 2262 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::overscanAppropriateFlag |
Definition at line 2241 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::overscanInfoPresentFlag |
Definition at line 2239 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH265VUIParams::transferCharacteristics |
Definition at line 2259 of file nvmedia_common.h.
| uint8_t NvMediaEncodeConfigH265VUIParams::videoFormat |
Definition at line 2247 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::videoFullRangeFlag |
Definition at line 2250 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::videoSignalTypePresentFlag |
Definition at line 2244 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigH265VUIParams::vuiTimingInfoPresentFlag |
Definition at line 2265 of file nvmedia_common.h.
