Holds VP8 encoder configuration parameters.
Definition at line 2756 of file nvmedia_common.h.
Data Fields | |
| uint32_t | features |
| Holds bit-wise OR`ed configuration feature flags. More... | |
| uint32_t | gopLength |
| Holds the number of pictures in one GOP. More... | |
| uint32_t | numReferenceFrames |
| Number of reference frame. More... | |
| uint32_t | version |
| VP8 version type. More... | |
| NvMediaEncodeRCParams | rcParams |
| Holds the rate control parameters for the current encoding session. More... | |
| uint32_t | filter_type |
| Set the feature flag NVMEDIA_ENCODE_CONFIG_VP8_ENABLE_LOOP_FILTER_PARAMS to change the following parameters. More... | |
| uint32_t | filter_level |
| Specifies the loop filter strength for each segment. More... | |
| uint32_t | sharpness_level |
| Specifies Sharpness level. More... | |
| int8_t | ref_lf_deltas [4] |
| Specifies the Loop filter strength adjustments based on frame type (intra, inter) More... | |
| int8_t | mode_lf_deltas [4] |
| Specifies the Loop filter strength adjustments based on mode (zero, new mv) More... | |
| NvMediaBool | bmode_ref_lf_delta_enabled |
| Set it to true if MB-level loop filter adjustment is on. More... | |
| NvMediaBool | bmode_ref_lf_delta_update |
| Set it to true if MB-level loop filter adjustment delta values are updated. More... | |
| uint32_t | base_qindex |
| Set the feature flag NVMEDIA_ENCODE_CONFIG_VP8_ENABLE_QUANTIZATION_PARAMS to set the following parameters. More... | |
| uint32_t | y1dc_delta_q |
| VP8 delta (subtracted from baseline quant index) More... | |
| uint32_t | y2dc_delta_q |
| VP8 Y2 dc delta. More... | |
| uint32_t | y2ac_delta_q |
| VP8 Y2 ac delta. More... | |
| uint32_t | uvdc_delta_q |
| VP8 UV dc delta. More... | |
| uint32_t | uvac_delta_q |
| VP8 UV ac delta. More... | |
| uint32_t | refresh_entropy_probs |
| VP8 refresh entropy probs. More... | |
| uint32_t | update_mb_segmentation_map |
| Set the feature flag NVMEDIA_ENCODE_CONFIG_VP8_ENABLE_SEGMENTATION to set the following parameters. More... | |
| uint32_t | update_mb_segmentation_data |
| VP8 update mb segmentation data. More... | |
| uint32_t | mb_segment_abs_delta |
| VP8 mb segment abs delta. More... | |
| int8_t | seg_filter_level [4] |
| VP8 segment filter level. More... | |
| int8_t | seg_qindex [4] |
| VP8 segment qp index. More... | |
| NvMediaBool | mb_no_coeff_skip_flag |
| Set to enable skipping of macroblocks with no non-zero coefficients at the frame level. More... | |
| NvMediaBool | no_temporal_mv_hints |
| Set to disable temporal mv hints. More... | |
| NvMediaBool | stop_prob_update |
| Set to turn off all probability updates to save hw testing time. More... | |
| NvMediaEncodeQP | initQP |
| Holds Initial QP parameters. More... | |
| NvMediaEncodeQP | maxQP |
| Holds max QP parameters. More... | |
| NvMediaEncodeQuality | quality |
| Holds encode quality pre-set. More... | |
| uint32_t NvMediaEncodeConfigVP8::base_qindex |
Specifies quant base index (used only when rc_mode = 0) for each segment 0...255
Definition at line 2790 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigVP8::bmode_ref_lf_delta_enabled |
Definition at line 2784 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigVP8::bmode_ref_lf_delta_update |
Definition at line 2786 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::features |
Definition at line 2758 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::filter_level |
Definition at line 2775 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::filter_type |
Specifies the type of the filter used. :0 eight-tap smooth, 1: eight-tap, 2: eight-tap sharp, 3: bilinear, 4: switchable
Definition at line 2773 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::gopLength |
Low-latency application client can set goplength to NVMEDIA_ENCODE_INFINITE_GOPLENGTH so that keyframes are not inserted automatically.
Definition at line 2762 of file nvmedia_common.h.
| NvMediaEncodeQP NvMediaEncodeConfigVP8::initQP |
Client must set NVMEDIA_ENCODE_CONFIG_VP8_INIT_QP in features to use this. QP values should be within the range of 1 to 255
Definition at line 2824 of file nvmedia_common.h.
| NvMediaEncodeQP NvMediaEncodeConfigVP8::maxQP |
Client must set NVMEDIA_ENCODE_CONFIG_VP8_QP_MAX in features to use this. max QP values must be within the range of 1 to 255 and must be greater than NvMediaEncodeRCParams::minQP
Definition at line 2828 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigVP8::mb_no_coeff_skip_flag |
Definition at line 2817 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::mb_segment_abs_delta |
Definition at line 2811 of file nvmedia_common.h.
| int8_t NvMediaEncodeConfigVP8::mode_lf_deltas[4] |
Definition at line 2782 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigVP8::no_temporal_mv_hints |
Definition at line 2819 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::numReferenceFrames |
Definition at line 2764 of file nvmedia_common.h.
| NvMediaEncodeQuality NvMediaEncodeConfigVP8::quality |
See NvMediaEncodeQuality enum.
Definition at line 2830 of file nvmedia_common.h.
| NvMediaEncodeRCParams NvMediaEncodeConfigVP8::rcParams |
Definition at line 2768 of file nvmedia_common.h.
| int8_t NvMediaEncodeConfigVP8::ref_lf_deltas[4] |
Definition at line 2780 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::refresh_entropy_probs |
Definition at line 2803 of file nvmedia_common.h.
| int8_t NvMediaEncodeConfigVP8::seg_filter_level[4] |
Definition at line 2813 of file nvmedia_common.h.
| int8_t NvMediaEncodeConfigVP8::seg_qindex[4] |
Definition at line 2815 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::sharpness_level |
Definition at line 2777 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeConfigVP8::stop_prob_update |
Definition at line 2821 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::update_mb_segmentation_data |
Definition at line 2809 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::update_mb_segmentation_map |
VP8 update mb segmentation map
Definition at line 2807 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::uvac_delta_q |
VP8 UV ac delta.
Definition at line 2801 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::uvdc_delta_q |
VP8 UV dc delta.
Definition at line 2799 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::version |
VP8 version type.
Definition at line 2766 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::y1dc_delta_q |
VP8 Y1 dc delta
Definition at line 2793 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::y2ac_delta_q |
VP8 Y2 ac delta.
Definition at line 2797 of file nvmedia_common.h.
| uint32_t NvMediaEncodeConfigVP8::y2dc_delta_q |
VP8 Y2 dc delta.
Definition at line 2795 of file nvmedia_common.h.
