Holds an External Motion Vector hint.
Definition at line 1925 of file nvmedia_common.h.
Data Fields | |
| int32_t | mvx: 12 |
| Holds the x component of integer pixel MV (relative to current MB) S12.0. More... | |
| int32_t | mvy: 10 |
| Holds the y component of integer pixel MV (relative to current MB) S10.0 . More... | |
| uint32_t | refidx: 5 |
| Holds the reference index (31=invalid). More... | |
| uint32_t | dir: 1 |
| Holds the direction of motion estimation . More... | |
| uint32_t | partType: 2 |
| Holds the block partition type. More... | |
| uint32_t | lastofPart: 1 |
| Set to NVMEDIA_TRUE for the last MV of (sub) partition. More... | |
| uint32_t | lastOfMB: 1 |
| Set to NVMEDIA_TRUE for the last MV of macroblock. More... | |
| uint32_t NvMediaEncodeExternalMEHint::dir |
0=L0 1=L1.
Definition at line 1933 of file nvmedia_common.h.
| uint32_t NvMediaEncodeExternalMEHint::lastOfMB |
Definition at line 1939 of file nvmedia_common.h.
| uint32_t NvMediaEncodeExternalMEHint::lastofPart |
Definition at line 1937 of file nvmedia_common.h.
| int32_t NvMediaEncodeExternalMEHint::mvx |
Definition at line 1927 of file nvmedia_common.h.
| int32_t NvMediaEncodeExternalMEHint::mvy |
Definition at line 1929 of file nvmedia_common.h.
| uint32_t NvMediaEncodeExternalMEHint::partType |
0=16x16 1=16x8 2=8x16 3=8x8 (blocks in partition must be consecutive).
Definition at line 1935 of file nvmedia_common.h.
| uint32_t NvMediaEncodeExternalMEHint::refidx |
Current we support only 1 reference frame per direction for external hints, so refidx must be 0.
Definition at line 1931 of file nvmedia_common.h.
