Holds H264-specific encode initialization parameters.
Definition at line 2093 of file nvmedia_common.h.
Data Fields | |
| uint32_t | encodeWidth |
| Holds the encode width. More... | |
| uint32_t | encodeHeight |
| Holds the encode height. More... | |
| NvMediaBool | enableLimitedRGB |
| Set this to NVMEDIA_TRUE for limited-RGB (16-235) input. More... | |
| uint32_t | frameRateNum |
| Holds the numerator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint32_t | frameRateDen |
| Holds the denominator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint8_t | profile |
| Holds the encoding profile. More... | |
| uint8_t | level |
| Holds the encoding level. More... | |
| uint8_t | maxNumRefFrames |
| Holds the max reference numbers used for encoding. More... | |
| NvMediaBool | enableExternalMEHints |
| Set to NVMEDIA_TRUE to enable external ME hints. More... | |
| NvMediaEncodeExternalMeHintCountsPerBlocktype | maxMEHintCountsPerBlock [2] |
| If Client wants to pass external motion vectors in NvMediaEncodePicParamsH264 meExternalHints buffer it must specify the maximum number of hint candidates per block per direction for the encode session. More... | |
| NvMediaBool | enableReconCRC |
| Enable support for recon CRC generation. More... | |
| NvMediaBool | enableMVC |
| If client want to do MVC encoding then this flag need to be set. More... | |
| NvMediaBool | enableROIEncode |
| Enable region of interest encoding. More... | |
| NvMediaBool | enableSliceEncode |
| use slice encode to reduce latency in getting encoded buffers. More... | |
| uint32_t | useBFramesAsRef |
| Enables B frames to be used as refernces frames. More... | |
| NvMediaBool | enableTwoPassRC |
| Enable 2 pass RC support. More... | |
| NvMediaBool | enableSourceHalfScaled |
| Enable 2 pass RC with quarter resolution first pass. More... | |
| uint32_t | mvcNumViews: 4 |
| Number of views used for MVC. More... | |
| uint32_t | enableExternalPictureRC: 1 |
| enable external picture rate control More... | |
| uint32_t | enableAllIFrames: 1 |
| Encode all frames as I frames. More... | |
| uint32_t | reserved: 26 |
| Add padding. More... | |
| uint32_t NvMediaEncodeInitializeParamsH264::enableAllIFrames |
Definition at line 2153 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableExternalMEHints |
Currently this feature is not supported if B frames are used
Definition at line 2122 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::enableExternalPictureRC |
Definition at line 2151 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableLimitedRGB |
Definition at line 2099 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableMVC |
Definition at line 2136 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableReconCRC |
NVMEDIA will allocate extra surface for recon CRC calculation. This can be enabled at run time for any frame by enabling recon CRC and passing recon CRC rectangle.
Definition at line 2134 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableROIEncode |
Region of interest encoding parameters are passed with Input extra data parameters
Definition at line 2139 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableSliceEncode |
Definition at line 2141 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableSourceHalfScaled |
Definition at line 2147 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsH264::enableTwoPassRC |
First pass RC can be run on full or quarter resolution.
Definition at line 2145 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::encodeHeight |
Definition at line 2097 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::encodeWidth |
Definition at line 2095 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::frameRateDen |
Definition at line 2105 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::frameRateNum |
Definition at line 2102 of file nvmedia_common.h.
| uint8_t NvMediaEncodeInitializeParamsH264::level |
Client is recommended to set this to NVMEDIA_ENCODE_LEVEL_AUTOSELECT in order to enable the Encode interface to select the correct level.
Definition at line 2113 of file nvmedia_common.h.
| NvMediaEncodeExternalMeHintCountsPerBlocktype NvMediaEncodeInitializeParamsH264::maxMEHintCountsPerBlock[2] |
The NvMediaEncodeInitializeParamsH264 maxMEHintCountsPerBlock[0] is for L0 predictors and NvMediaEncodeInitializeParamsH264 maxMEHintCountsPerBlock[1] is for L1 predictors. This client must also set NvMediaEncodeInitializeParamsH264 enableExternalMEHints to NVMEDIA_TRUE.
Definition at line 2129 of file nvmedia_common.h.
| uint8_t NvMediaEncodeInitializeParamsH264::maxNumRefFrames |
Allowed range is [0, 2]. Values:
Definition at line 2119 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::mvcNumViews |
Definition at line 2149 of file nvmedia_common.h.
| uint8_t NvMediaEncodeInitializeParamsH264::profile |
Client is recommended to set this to NVMEDIA_ENCODE_PROFILE_AUTOSELECT in order to enable the Encode interface to select the correct profile.
Definition at line 2109 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::reserved |
Add padding.
Definition at line 2155 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsH264::useBFramesAsRef |
Definition at line 2143 of file nvmedia_common.h.
