Holds VP8-specific encode initialization parameters.
Definition at line 2836 of file nvmedia_common.h.
Data Fields | |
| uint32_t | encodeWidth |
| Holds the encode width. More... | |
| uint32_t | encodeHeight |
| Holds the encode height. More... | |
| uint32_t | frameRateNum |
| Holds the numerator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint32_t | frameRateDen |
| Holds the denominator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint8_t | maxNumRefFrames |
| Holds the max reference numbers used for encoding. More... | |
| uint32_t NvMediaEncodeInitializeParamsVP8::encodeHeight |
Definition at line 2840 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP8::encodeWidth |
Definition at line 2838 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP8::frameRateDen |
Definition at line 2846 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP8::frameRateNum |
Definition at line 2843 of file nvmedia_common.h.
| uint8_t NvMediaEncodeInitializeParamsVP8::maxNumRefFrames |
Allowed range is [0, 2]. Values:
Definition at line 2851 of file nvmedia_common.h.
