Holds VP9-specific encode initialization parameters.
Definition at line 2647 of file nvmedia_common.h.
Data Fields | |
| uint32_t | encodeWidth |
| Holds the encode width. More... | |
| uint32_t | encodeHeight |
| Holds the encode height. More... | |
| NvMediaBool | enableLimitedRGB |
| Holds a flag indicating whether input is limted-RGB (16-235). More... | |
| uint32_t | frameRateNum |
| Holds the numerator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint32_t | frameRateDen |
| Holds the denominator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint8_t | maxNumRefFrames |
| Holds the max reference numbers used for encoding. More... | |
| NvMediaBool | enableExternalMEHints |
| Holds a flag indicating whether to enable or disable the external ME hints. More... | |
| NvMediaEncodeExternalMeHintCountsPerBlocktype | maxMEHintCountsPerBlock [2] |
| If Client wants to pass external motion vectors in NvMediaEncodePicParamsVP9 meExternalHints buffer it must specify the maximum number of hint candidates, per block and per direction, for the encode session. More... | |
| NvMediaBool NvMediaEncodeInitializeParamsVP9::enableExternalMEHints |
Set to NVMEDIA_TRUE to enable external ME hints. Currently this feature is not supported if B frames are used.
Definition at line 2670 of file nvmedia_common.h.
| NvMediaBool NvMediaEncodeInitializeParamsVP9::enableLimitedRGB |
Set this to NVMEDIA_TRUE for limited-RGB (16-235) input.
Definition at line 2654 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP9::encodeHeight |
Definition at line 2651 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP9::encodeWidth |
Definition at line 2649 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP9::frameRateDen |
Definition at line 2660 of file nvmedia_common.h.
| uint32_t NvMediaEncodeInitializeParamsVP9::frameRateNum |
Definition at line 2657 of file nvmedia_common.h.
| NvMediaEncodeExternalMeHintCountsPerBlocktype NvMediaEncodeInitializeParamsVP9::maxMEHintCountsPerBlock[2] |
The NvMediaEncodeInitializeParamsVP9 maxMEHintCountsPerBlock[0] is for L0 predictors and NvMediaEncodeInitializeParamsVP9 maxMEHintCountsPerBlock[1] is for L1 predictors. This client must also set NvMediaEncodeInitializeParamsVP9 enableExternalMEHints to NVMEDIA_TRUE.
Definition at line 2677 of file nvmedia_common.h.
| uint8_t NvMediaEncodeInitializeParamsVP9::maxNumRefFrames |
Allowed range is [0, 2]. Values:
Definition at line 2666 of file nvmedia_common.h.
