Holds VP8-specific encoder picture parameters, which are sent on a per frame basis.
Definition at line 2857 of file nvmedia_common.h.
Data Fields | |
| NvMediaEncodePicType | pictureType |
| Holds input picture type. More... | |
| uint32_t | encodePicFlags |
| Holds bit-wise OR`ed encode pic flags. More... | |
| NvMediaEncodeRCParams | rcParams |
| Holds the rate control parameters from the current frame onward if the NVMEDIA_ENCODE_PIC_FLAG_RATECONTROL_CHANGE is set in the encodePicFlags. More... | |
| uint32_t | frameRateNum |
| Holds the numerator for frame rate used for encoding in frames per second ( Frame rate = frameRateNum / frameRateDen ). More... | |
| uint32_t | frameRateDen |
| uint32_t NvMediaEncodePicParamsVP8::encodePicFlags |
See enum NvMediaEncodePicFlags.
Definition at line 2862 of file nvmedia_common.h.
| uint32_t NvMediaEncodePicParamsVP8::frameRateDen |
Definition at line 2873 of file nvmedia_common.h.
| uint32_t NvMediaEncodePicParamsVP8::frameRateNum |
Definition at line 2870 of file nvmedia_common.h.
| NvMediaEncodePicType NvMediaEncodePicParamsVP8::pictureType |
Definition at line 2859 of file nvmedia_common.h.
| NvMediaEncodeRCParams NvMediaEncodePicParamsVP8::rcParams |
Please note that the rateControlMode cannot be changed on a per frame basis only the associated rate control parameters.
Definition at line 2867 of file nvmedia_common.h.
