Holds the image capture settings for the CSI format per virtual group.
Definition at line 259 of file nvmedia_icp.h.
Data Fields | |
| NvMediaICPInterfaceType | interfaceType |
| Holds the interface type. More... | |
| uint32_t | interfaceLanes |
| Holds the number of active CSI interface lanes. More... | |
| struct { | |
| struct { | |
| uint16_t virtualChannelIndex | |
| NvMediaICPSettings icpSettings | |
| NvMediaRect clipRect | |
| NvMediaBool disablePFSD | |
| Holds a flag for disabling PFSD (Permanent Fault Software Diagnostic) functionality in the capture engine. More... | |
| } virtualChannels [NVMEDIA_ICP_MAX_VIRTUAL_CHANNELS] | |
| uint16_t numVirtualChannels | |
| Holds the number of virtual channels per group. More... | |
| } | virtualGroups [NVMEDIA_ICP_MAX_VIRTUAL_GROUPS] |
| uint16_t | numVirtualGroups |
| Holds the number of virtual groups. More... | |
| NvMediaICPCsiPhyMode | phyMode |
| Holds the CSI phy mode. More... | |
| NvMediaRect NvMediaICPSettingsEx::clipRect |
Definition at line 273 of file nvmedia_icp.h.
| NvMediaBool NvMediaICPSettingsEx::disablePFSD |
This function is enabled by default, meaning that the capture engine overwrites the 64 pixels (2 pixels/bit) or 128 pixels (1 pixel/bit) from the left side of the bottom line. Disable this flag if the application must use the whole frame.
Definition at line 281 of file nvmedia_icp.h.
| NvMediaICPSettings NvMediaICPSettingsEx::icpSettings |
Definition at line 271 of file nvmedia_icp.h.
| uint32_t NvMediaICPSettingsEx::interfaceLanes |
In case of DPHY, each interfaceLane corresponds to two data lanes. In case of CPHY, each interfaceLane corresponds to three data lanes.
Definition at line 265 of file nvmedia_icp.h.
| NvMediaICPInterfaceType NvMediaICPSettingsEx::interfaceType |
Definition at line 261 of file nvmedia_icp.h.
| uint16_t NvMediaICPSettingsEx::numVirtualChannels |
Definition at line 284 of file nvmedia_icp.h.
| uint16_t NvMediaICPSettingsEx::numVirtualGroups |
Definition at line 287 of file nvmedia_icp.h.
| NvMediaICPCsiPhyMode NvMediaICPSettingsEx::phyMode |
Definition at line 289 of file nvmedia_icp.h.
| uint16_t NvMediaICPSettingsEx::virtualChannelIndex |
Definition at line 269 of file nvmedia_icp.h.
| struct { ... } NvMediaICPSettingsEx::virtualChannels[NVMEDIA_ICP_MAX_VIRTUAL_CHANNELS] |
| struct { ... } NvMediaICPSettingsEx::virtualGroups[NVMEDIA_ICP_MAX_VIRTUAL_GROUPS] |
