Holds configuration information for an ISP component.
Definition at line 1180 of file nvmedia_ipp.h.
Data Fields | |
| NvMediaISPSelect | ispSelect |
| Holds ISP select. More... | |
| uint32_t | ispSettingAttr |
| Holds the ISP-setting attribute flag, which specifies bit-wise OR`ed flags defined in the enum NvMediaIPPIspAttrFlags. More... | |
| NvMediaISPSelect NvMediaIPPIspComponentConfig::ispSelect |
Holds ISP select.
Definition at line 1182 of file nvmedia_ipp.h.
| uint32_t NvMediaIPPIspComponentConfig::ispSettingAttr |
Definition at line 1185 of file nvmedia_ipp.h.
