Holds stream-specific settings of Control Algorithm plugin output.
Definition at line 814 of file nvmedia_ipp.h.
Data Fields | |
| union { | |
| struct { | |
| NvMediaBool histogramSettingsValid [2] | |
| Holds validity flags for histogram settings. More... | |
| NvMediaISPStatsHistogramSettingsV4 histogramSettings [2] | |
| Holds histogram settings. More... | |
| NvMediaBool lacSettingsValid [2] | |
| Holds validity flags for LAC settings. More... | |
| NvMediaISPStatsLacSettingsV4 lacSettings [2] | |
| Holds LAC settings. More... | |
| NvMediaBool flickerBandSettingsValid | |
| Holds validity flags for flicker band settings. More... | |
| NvMediaISPStatsFlickerBandSettingsV4 flickerBandSettings | |
| Holds flicker band settings. More... | |
| } v4 | |
| struct { | |
| NvMediaISPStatsHistogramSettingsV5 histogramSettings [2] | |
| NvMediaISPStatsLacSettingsV5 lacSettings [2] | |
| NvMediaISPStatsFlickerBandSettingsV5 flickerBandSettings | |
| } v5 | |
| union { ... } |
| NvMediaISPStatsFlickerBandSettingsV4 NvMediaIPPPluginOutputStreamSettings::flickerBandSettings |
Settings are applied if flickerBandSettingsValid is set to NVMEDIA_TRUE.
Definition at line 838 of file nvmedia_ipp.h.
| NvMediaISPStatsFlickerBandSettingsV5 NvMediaIPPPluginOutputStreamSettings::flickerBandSettings |
Definition at line 861 of file nvmedia_ipp.h.
| NvMediaBool NvMediaIPPPluginOutputStreamSettings::flickerBandSettingsValid |
Set to NVMEDIA_TRUE if the settings are required.
Definition at line 834 of file nvmedia_ipp.h.
| NvMediaISPStatsHistogramSettingsV4 NvMediaIPPPluginOutputStreamSettings::histogramSettings[2] |
Settings are applied if the histogramSettingsValid is set to NVMEDIA_TRUE.
Definition at line 824 of file nvmedia_ipp.h.
| NvMediaISPStatsHistogramSettingsV5 NvMediaIPPPluginOutputStreamSettings::histogramSettings[2] |
Settings are applied if histogramSettingsValid is set to NVMEDIA_TRUE.
Definition at line 847 of file nvmedia_ipp.h.
| NvMediaBool NvMediaIPPPluginOutputStreamSettings::histogramSettingsValid[2] |
Definition at line 820 of file nvmedia_ipp.h.
| NvMediaISPStatsLacSettingsV4 NvMediaIPPPluginOutputStreamSettings::lacSettings[2] |
Holds LAC settings.
Settings are applied if lacSettingsValid is set to NVMEDIA_TRUE.
Definition at line 831 of file nvmedia_ipp.h.
| NvMediaISPStatsLacSettingsV5 NvMediaIPPPluginOutputStreamSettings::lacSettings[2] |
Holds LAC settings.
Definition at line 854 of file nvmedia_ipp.h.
| NvMediaBool NvMediaIPPPluginOutputStreamSettings::lacSettingsValid[2] |
Definition at line 827 of file nvmedia_ipp.h.
| struct { ... } NvMediaIPPPluginOutputStreamSettings::v4 |
| struct { ... } NvMediaIPPPluginOutputStreamSettings::v5 |
