Holds the sensor temperature structure.
Definition at line 1280 of file nvmedia_isc.h.
Data Fields | |
| NvMediaBool | tempValid |
| Holds a flag which enables or disables the sensor temperature block. More... | |
| uint8_t | numTemperatures |
| Holds the number of active temperatures. More... | |
| float_t | sensorTempCelsius [NVMEDIA_ISC_MAX_NUM_TEMPERATURES] |
| Holds the values of active sensor temperatures in degrees Celsius. More... | |
| uint8_t NvMediaISCTemperature::numTemperatures |
Must be in the range [1, NVMEDIA_ISC_MAX_NUM_TEMPERATURES].
Definition at line 1290 of file nvmedia_isc.h.
| float_t NvMediaISCTemperature::sensorTempCelsius[NVMEDIA_ISC_MAX_NUM_TEMPERATURES] |
Array indexes must be in the range [0, (numTemperatures-1)].
Definition at line 1296 of file nvmedia_isc.h.
| NvMediaBool NvMediaISCTemperature::tempValid |
Definition at line 1284 of file nvmedia_isc.h.
