Holds an image surface map descriptor used by NvMediaImageLock().
It contains up to 6 surface descriptors, depending on the image type.
Definition at line 192 of file nvmedia_image.h.
Data Fields | |
| NvMediaSurfaceType | type |
| Holds image surface type. More... | |
| uint32_t | width |
| Holds image width. More... | |
| uint32_t | height |
| Holds image height. More... | |
| uint32_t | surfaces |
| Holds the number of surfaces in the image. More... | |
| NvMediaImageSurface | surface [6] |
| Holds surface descriptors. More... | |
| void * | metaData |
| Holds a pointer to metadata associated with the surface. More... | |
| uint32_t NvMediaImageSurfaceMap::height |
Holds image height.
Definition at line 198 of file nvmedia_image.h.
| void* NvMediaImageSurfaceMap::metaData |
Definition at line 205 of file nvmedia_image.h.
| NvMediaImageSurface NvMediaImageSurfaceMap::surface[6] |
Only the first surface number of elements is valid.
Definition at line 203 of file nvmedia_image.h.
| uint32_t NvMediaImageSurfaceMap::surfaces |
Definition at line 200 of file nvmedia_image.h.
| NvMediaSurfaceType NvMediaImageSurfaceMap::type |
Definition at line 194 of file nvmedia_image.h.
| uint32_t NvMediaImageSurfaceMap::width |
Holds image width.
Definition at line 196 of file nvmedia_image.h.
