This is used to get header info (SPS/PPS/VPS) using GetAttribute call.
HeaderInfo type is defined in NvMediaEncAttrType
Definition at line 1854 of file nvmedia_common.h.
Data Fields | |
| uint32_t | ulNalSize |
| Nal size for header. More... | |
| uint8_t | data [MAX_NON_SLICE_DATA_SIZE] |
| header data passed on this buffer More... | |
| uint8_t NvMediaNalData::data[MAX_NON_SLICE_DATA_SIZE] |
Definition at line 1858 of file nvmedia_common.h.
| uint32_t NvMediaNalData::ulNalSize |
Definition at line 1856 of file nvmedia_common.h.
