Holds picture parameter information for an MPEG 1 or MPEG 2 picture.
Definition at line 772 of file nvmedia_common.h.
Data Fields | |
| NvMediaRefSurface * | forward_reference |
| Reference used by B and P frames. More... | |
| NvMediaRefSurface * | backward_reference |
| Reference used by B frames. More... | |
| uint8_t | picture_structure |
| Holds a copy of the MPEG bitstream field. More... | |
| uint8_t | picture_coding_type |
| uint8_t | intra_dc_precision |
| uint8_t | frame_pred_frame_dct |
| uint8_t | concealment_motion_vectors |
| uint8_t | intra_vlc_format |
| uint8_t | alternate_scan |
| uint8_t | q_scale_type |
| uint8_t | top_field_first |
| uint8_t | full_pel_forward_vector |
| Holds a copy of the MPEG-1 bitstream field. More... | |
| uint8_t | full_pel_backward_vector |
| uint8_t | f_code [2][2] |
| uint8_t | intra_quantizer_matrix [64] |
| Holds a copy of the MPEG bitstream field, converted to raster order. More... | |
| uint8_t | non_intra_quantizer_matrix [64] |
| uint32_t | nNumSlices |
| Holds the number of slices in this picture. More... | |
| uint32_t * | pSliceDataOffsets |
| Passing NULL for pSliceDataOffsets disables error-concealment. More... | |
| uint8_t | flag_slices_across_multiple_rows |
| Indicates whether the MPEG slices span across multiple rows. More... | |
| uint8_t NvMediaPictureInfoMPEG1Or2::alternate_scan |
Definition at line 797 of file nvmedia_common.h.
| NvMediaRefSurface* NvMediaPictureInfoMPEG1Or2::backward_reference |
Set to NULL when not used.
Definition at line 782 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::concealment_motion_vectors |
Definition at line 793 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::f_code[2][2] |
For MPEG-1, fill both horizontal and vertical entries.
Definition at line 810 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::flag_slices_across_multiple_rows |
Definition at line 822 of file nvmedia_common.h.
| NvMediaRefSurface* NvMediaPictureInfoMPEG1Or2::forward_reference |
Definition at line 777 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::frame_pred_frame_dct |
Definition at line 791 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::full_pel_backward_vector |
For MPEG-2, set to 0.
Definition at line 805 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::full_pel_forward_vector |
Definition at line 803 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::intra_dc_precision |
Definition at line 789 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::intra_quantizer_matrix[64] |
Definition at line 812 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::intra_vlc_format |
Definition at line 795 of file nvmedia_common.h.
| uint32_t NvMediaPictureInfoMPEG1Or2::nNumSlices |
nNumSlices entries contain the offset of each slice within the bitstream data buffer. Required for nvdec.
Definition at line 818 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::non_intra_quantizer_matrix[64] |
Definition at line 814 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::picture_coding_type |
Definition at line 787 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::picture_structure |
Definition at line 785 of file nvmedia_common.h.
| uint32_t* NvMediaPictureInfoMPEG1Or2::pSliceDataOffsets |
Definition at line 820 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::q_scale_type |
Definition at line 799 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoMPEG1Or2::top_field_first |
Definition at line 801 of file nvmedia_common.h.
