Information about an H.264 reference frame.
Definition at line 181 of file nvmedia_common.h.
Data Fields | |
| NvMediaRefSurface * | surface |
| The surface that contains the reference image. More... | |
| NvMediaBool | is_long_term |
| Is this a long term reference (else short term). More... | |
| NvMediaBool | top_is_reference |
| Is the top field used as a reference. More... | |
| NvMediaBool | bottom_is_reference |
| Is the bottom field used as a reference. More... | |
| int32_t | field_order_cnt [2] |
| [0]: top, [1]: bottom More... | |
| uint16_t | FrameIdx |
| Copy of the H.264 bitstream field: frame_num from slice_header for short-term references, LongTermPicNum from decoding algorithm for long-term references. More... | |
| uint16_t | not_existing |
| Parser only: Non-existing reference frame flag (corresponding PicIdx should be set to -1) More... | |
| NvMediaBool NvMediaReferenceFrameH264::bottom_is_reference |
Set to NVMEDIA_FALSE for unused entries.
Definition at line 198 of file nvmedia_common.h.
| int32_t NvMediaReferenceFrameH264::field_order_cnt[2] |
Definition at line 200 of file nvmedia_common.h.
| uint16_t NvMediaReferenceFrameH264::FrameIdx |
Definition at line 206 of file nvmedia_common.h.
| NvMediaBool NvMediaReferenceFrameH264::is_long_term |
Definition at line 188 of file nvmedia_common.h.
| uint16_t NvMediaReferenceFrameH264::not_existing |
Definition at line 211 of file nvmedia_common.h.
| NvMediaRefSurface* NvMediaReferenceFrameH264::surface |
Set to NULL for unused entries.
Definition at line 186 of file nvmedia_common.h.
| NvMediaBool NvMediaReferenceFrameH264::top_is_reference |
Definition at line 193 of file nvmedia_common.h.
