Axis Aligned Bounding Box.
Holds coordinates, scale factor delta portion and status.
Definition at line 94 of file nvmedia_vpi.h.
Data Fields | |
| float | x |
| x coordinate. More... | |
| float | y |
| y coordinate. More... | |
| float | width |
| width of bounding box. More... | |
| float | height |
| height of bounding box. More... | |
| uint8_t | trackingStatus |
| 1 indicates tracking is invalid, 0 indicates valid. More... | |
| uint8_t | updateTemplate |
| 1 indicatestemplate needs updating, 0 indicates template is valid. More... | |
| uint8_t | reserved1 |
| Reserved for future use. More... | |
| uint8_t | reserved2 |
| float NvMediaVPIAABB::height |
Definition at line 102 of file nvmedia_vpi.h.
| uint8_t NvMediaVPIAABB::reserved1 |
Do not read/write this field.
Definition at line 108 of file nvmedia_vpi.h.
| uint8_t NvMediaVPIAABB::reserved2 |
Definition at line 110 of file nvmedia_vpi.h.
| uint8_t NvMediaVPIAABB::trackingStatus |
Definition at line 104 of file nvmedia_vpi.h.
| uint8_t NvMediaVPIAABB::updateTemplate |
Definition at line 106 of file nvmedia_vpi.h.
| float NvMediaVPIAABB::width |
Definition at line 100 of file nvmedia_vpi.h.
| float NvMediaVPIAABB::x |
x coordinate.
Definition at line 96 of file nvmedia_vpi.h.
| float NvMediaVPIAABB::y |
y coordinate.
Definition at line 98 of file nvmedia_vpi.h.
