NvMediaVPIGetSparseFlowPyrLKParams.
Definition at line 972 of file nvmedia_vpi.h.
Data Fields | |
| const NvMediaVPITerminationCriterion | termination |
| Holds the termination criteria. More... | |
| float | epsilon |
| Holds the error for terminating the algorithm. More... | |
| uint32_t | numPoints |
| Holds the number of points. More... | |
| uint32_t | numIterations |
| Holds the number of iterations. More... | |
| uint32_t | windowDimension |
| Holds the size of the window on which to perform the algorithm. More... | |
| int32_t | calcError |
| Holds a Boolean flag that indicates whether to calculate tracking error. More... | |
| uint32_t | numLevels |
| Holds the number of levels in the pyramid. More... | |
| int32_t NvMediaVPIGetSparseFlowPyrLKParams::calcError |
Definition at line 986 of file nvmedia_vpi.h.
| float NvMediaVPIGetSparseFlowPyrLKParams::epsilon |
Definition at line 976 of file nvmedia_vpi.h.
| uint32_t NvMediaVPIGetSparseFlowPyrLKParams::numIterations |
Definition at line 980 of file nvmedia_vpi.h.
| uint32_t NvMediaVPIGetSparseFlowPyrLKParams::numLevels |
Definition at line 988 of file nvmedia_vpi.h.
| uint32_t NvMediaVPIGetSparseFlowPyrLKParams::numPoints |
Definition at line 978 of file nvmedia_vpi.h.
| const NvMediaVPITerminationCriterion NvMediaVPIGetSparseFlowPyrLKParams::termination |
Definition at line 974 of file nvmedia_vpi.h.
| uint32_t NvMediaVPIGetSparseFlowPyrLKParams::windowDimension |
Must be in the range [3,32].
Definition at line 983 of file nvmedia_vpi.h.
