9.0/sources/apps/apps-common/includes/deepstream_common.h File Reference
Macros
#define NVGSTDS_ERR_MSG_V(msg, ...)   nvds_capture_error(__func__, __LINE__, msg, ##__VA_ARGS__)
#define NVGSTDS_INFO_MSG_V(msg, ...)   g_print("** INFO: <%s:%d>: " msg "\n", __func__, __LINE__, ##__VA_ARGS__)
#define NVGSTDS_WARN_MSG_V(msg, ...)   g_print("** WARN: <%s:%d>: " msg "\n", __func__, __LINE__, ##__VA_ARGS__)
#define NVGSTDS_LINK_ELEMENT(elem1, elem2)
#define NVGSTDS_LINK_ELEMENT_FULL(elem1, elem1_pad_name, elem2, elem2_pad_name)
#define NVGSTDS_BIN_ADD_GHOST_PAD_NAMED(bin, elem, pad, ghost_pad_name)
#define NVGSTDS_BIN_ADD_GHOST_PAD(bin, elem, pad)   NVGSTDS_BIN_ADD_GHOST_PAD_NAMED (bin, elem, pad, pad)
#define NVGSTDS_ELEM_ADD_PROBE(probe_id, elem, pad, probe_func, probe_type, probe_data)
#define NVGSTDS_ELEM_REMOVE_PROBE(probe_id, elem, pad)
#define GET_FILE_PATH(path)   ((path) + (((path) && strstr ((path), "file://")) ? 7 : 0))
Functions
 __attribute__ ((weak)) gchar *g_nvds_last_error_message
static void nvds_capture_error (const gchar *func, gint line, const gchar *msg,...)
gboolean link_element_to_tee_src_pad (GstElement *tee, GstElement *sinkelem)
 Function to link sink pad of an element to source pad of tee. More...
gboolean link_element_to_streammux_sink_pad (GstElement *streammux, GstElement *elem, gint index)
 Function to link source pad of an element to sink pad of muxer element. More...
gboolean unlink_element_from_streammux_sink_pad (GstElement *streammux, GstElement *elem)
 Function to unlink source pad of an element from sink pad of muxer element. More...
gboolean link_element_to_demux_src_pad (GstElement *demux, GstElement *elem, guint index)
 Function to link sink pad of an element to source pad of demux element. More...
void str_replace (gchar *str, const gchar *replace, const gchar *replace_with)
◆ GET_FILE_PATH
#define GET_FILE_PATH (   path)    ((path) + (((path) && strstr ((path), "file://")) ? 7 : 0))
◆ NVGSTDS_BIN_ADD_GHOST_PAD
#define NVGSTDS_BIN_ADD_GHOST_PAD (   bin,
  elem,
  pad
◆ NVGSTDS_BIN_ADD_GHOST_PAD_NAMED
#define NVGSTDS_BIN_ADD_GHOST_PAD_NAMED (   bin,
  elem,
  pad,
  ghost_pad_name
Value:
do { \
GstPad *gstpad = gst_element_get_static_pad (elem, pad); \
if (!gstpad) { \
NVGSTDS_ERR_MSG_V ("Could not find '%s' in '%s'", pad, \
GST_ELEMENT_NAME(elem)); \
goto done; \
gst_element_add_pad (bin, gst_ghost_pad_new (ghost_pad_name, gstpad)); \
gst_object_unref (gstpad); \
} while (0)
Definition at line 104 of file 9.0/sources/apps/apps-common/includes/deepstream_common.h.
◆ NVGSTDS_ELEM_ADD_PROBE
#define NVGSTDS_ELEM_ADD_PROBE (   probe_id,
  elem,
  pad,
  probe_func,
  probe_type,
  probe_data
Value:
do { \
if (!gstpad) { \
goto done; \
probe_id = gst_pad_add_probe(gstpad, (probe_type), probe_func, probe_data, NULL); \
} while (0)
Definition at line 119 of file 9.0/sources/apps/apps-common/includes/deepstream_common.h.
◆ NVGSTDS_ELEM_REMOVE_PROBE
#define NVGSTDS_ELEM_REMOVE_PROBE (   probe_id,
  elem,
  pad
Value:
do { \
if (probe_id == 0 || !elem) { \
break; \
if (!gstpad) { \
break; \
gst_pad_remove_probe(gstpad, probe_id); \
} while (0)
Definition at line 131 of file 9.0/sources/apps/apps-common/includes/deepstream_common.h.
◆ NVGSTDS_ERR_MSG_V
#define NVGSTDS_ERR_MSG_V (   msg,
◆ NVGSTDS_INFO_MSG_V
#define NVGSTDS_INFO_MSG_V (   msg,
◆ NVGSTDS_LINK_ELEMENT
#define NVGSTDS_LINK_ELEMENT (   elem1,
  elem2
Value:
do { \
if (!gst_element_link (elem1,elem2)) { \
GstCaps *src_caps, *sink_caps; \
src_caps = gst_pad_query_caps ((GstPad *) (elem1)->srcpads->data, NULL); \
sink_caps = gst_pad_query_caps ((GstPad *) (elem2)->sinkpads->data, NULL); \
NVGSTDS_ERR_MSG_V ("Failed to link '%s' (%s) and '%s' (%s)", \
GST_ELEMENT_NAME (elem1), \
gst_caps_to_string (src_caps), \
GST_ELEMENT_NAME (elem2), \
gst_caps_to_string (sink_caps)); \
goto done; \
} while (0)
Definition at line 69 of file 9.0/sources/apps/apps-common/includes/deepstream_common.h.
◆ NVGSTDS_LINK_ELEMENT_FULL
#define NVGSTDS_LINK_ELEMENT_FULL (   elem1,
  elem1_pad_name,
  elem2,
  elem2_pad_name
Value:
do { \
GstPad *elem1_pad = gst_element_get_static_pad(elem1, elem1_pad_name); \
GstPad *elem2_pad = gst_element_get_static_pad(elem2, elem2_pad_name); \
GstPadLinkReturn ret = gst_pad_link (elem1_pad,elem2_pad); \
if (ret != GST_PAD_LINK_OK) { \
gchar *n1 = gst_pad_get_name (elem1_pad); \
gchar *n2 = gst_pad_get_name (elem2_pad); \
NVGSTDS_ERR_MSG_V ("Failed to link '%s' and '%s': %d", \
n1, n2, ret); \
g_free (n1); \
g_free (n2); \
gst_object_unref (elem1_pad); \
gst_object_unref (elem2_pad); \
goto done; \
} while (0)
Definition at line 84 of file 9.0/sources/apps/apps-common/includes/deepstream_common.h.
◆ NVGSTDS_WARN_MSG_V
#define NVGSTDS_WARN_MSG_V (   msg,
Function Documentation
◆ __attribute__()
__attribute__ ( (weak)  )
◆ link_element_to_demux_src_pad()
gboolean link_element_to_demux_src_pad ( GstElement *  demux,
GstElement *  elem,
guint  index
Parameters
[in]demuxdemuxer element.
[in]elemdownstream element.
[in]indexpad index of demuxer element.
Returns
true if link successful.
◆ link_element_to_streammux_sink_pad()
gboolean link_element_to_streammux_sink_pad ( GstElement *  streammux,
GstElement *  elem,
gint  index
Parameters
[in]streammuxmuxer element.
[in]elemupstream element.
[in]indexpad index of muxer element.
Returns
◆ link_element_to_tee_src_pad()
gboolean link_element_to_tee_src_pad ( GstElement *  tee,
GstElement *  sinkelem
Parameters
[in]teeTee element.
[in]sinkelemdownstream element.
Returns
◆ nvds_capture_error()
static void nvds_capture_error ( const gchar *  func,
gint  line,
const gchar *  msg,
inlinestatic
◆ str_replace()
void str_replace ( gchar *  str,
const gchar *  replace,
const gchar *  replace_with
◆ unlink_element_from_streammux_sink_pad()
gboolean unlink_element_from_streammux_sink_pad ( GstElement *  streammux,
GstElement *  elem
Parameters
Returns
true if unlinking was successful.
