9.0/sources/apps/apps-common/includes/deepstream_gie.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2018-2026 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __NVGSTDS_GIE_H__
14 #define __NVGSTDS_GIE_H__
15
16 #include <gst/gst.h>
17
18 #ifdef __cplusplus
19 extern "C"
20 {
21 #endif
22
23 #include "gstnvdsmeta.h"
24 #include "gstnvdsinfer.h"
25 #include "deepstream_config.h"
26
27 typedef enum
28 {
34
35 typedef struct
36 {
37  gboolean enable;
38
39  gchar *config_file_path;
40
41  gboolean input_tensor_meta;
42
43  gboolean override_colors;
44
45  gint operate_on_gie_id;
46  gboolean is_operate_on_gie_id_set;
47  gint operate_on_classes;
48
49  gint num_operate_on_class_ids;
50  gint *list_operate_on_class_ids;
51
52  gboolean have_bg_color;
53  NvOSD_ColorParams bbox_bg_color;
54  NvOSD_ColorParams bbox_border_color;
55
56  GHashTable *bbox_border_color_table;
57  GHashTable *bbox_bg_color_table;
58
59  guint batch_size;
60  gboolean is_batch_size_set;
61
62  guint interval;
63  gboolean is_interval_set;
64  guint unique_id;
65  gboolean is_unique_id_set;
66  guint gpu_id;
67  gboolean is_gpu_id_set;
68  guint nvbuf_memory_type;
69  gchar *model_engine_file_path;
70
71  gchar *audio_transform;
72  guint frame_size;
73  gboolean is_frame_size_set;
74  guint hop_size;
75  gboolean is_hop_size_set;
76  guint input_audio_rate;
77
78  gchar *label_file_path;
79  guint n_labels;
80  guint *n_label_outputs;
81  gchar ***labels;
82
83  gchar *raw_output_directory;
84  gulong file_write_frame_num;
85
86  gchar *tag;
87
88  NvDsGiePluginType plugin_type;
89
90  // Vision encoder specific fields (when plugin_type == NV_DS_GIE_PLUGIN_VISION_ENCODER)
91  gchar *model_variant;
92  gchar *device;
93  guint min_crop_size;
94  gboolean is_min_crop_size_set;
95  guint verbose;
96  gchar *backend; // "transformers" or "triton"
97  gchar *triton_url; // Triton gRPC endpoint (host:port)
98  gchar *triton_model; // Model name in Triton repository
100
101 #ifdef __cplusplus
102 }
103 #endif
104
105 #endif
NV_DS_GIE_PLUGIN_INFER
@ NV_DS_GIE_PLUGIN_INFER
Definition: 9.0/sources/apps/apps-common/includes/deepstream_gie.h:29
NV_DS_GIE_PLUGIN_VIDEO_TEMPLATE
@ NV_DS_GIE_PLUGIN_VIDEO_TEMPLATE
Definition: 9.0/sources/apps/apps-common/includes/deepstream_gie.h:31
NvDsGiePluginType
NvDsGiePluginType
Definition: sources/apps/apps-common/includes/deepstream_gie.h:27
NvDsGieConfig
Definition: sources/apps/apps-common/includes/deepstream_gie.h:35
_NvOSD_ColorParams
Holds the color parameters of the box or text to be overlayed.
Definition: sources/includes/nvll_osd_struct.h:81
@ NV_DS_GIE_PLUGIN_VISION_ENCODER
Definition: 9.0/sources/apps/apps-common/includes/deepstream_gie.h:32
NV_DS_GIE_PLUGIN_INFER_SERVER
@ NV_DS_GIE_PLUGIN_INFER_SERVER
Definition: 9.0/sources/apps/apps-common/includes/deepstream_gie.h:30
deepstream_config.h
NvDsGiePluginType
NvDsGiePluginType
Definition: 9.0/sources/apps/apps-common/includes/deepstream_gie.h:27
