9.0/sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h File Reference
Data Structures
struct  _GstRTPTimestampMeta
Macros
#define CHECK_CUDA(err, err_str)
#define INVALID_STREAM_ID   ((rmx_stream_id)-1L)
#define MAX_ST2022_7_STREAMS   2
#define round_up(num, round)   ((((num) + (round) - 1) / (round)) * (round))
#define LEAP_SECONDS   (37)
#define DEFAULT_PTP_SRC   NULL
Typedefs
typedef enum StreamType StreamType
typedef enum VideoType VideoType
typedef enum MemoryType MemoryType
typedef struct _GstRTPTimestampMeta GstRTPTimestampMeta
Enumerations
enum  StreamType {
  VIDEO_2110_20_STREAM,
  VIDEO_2110_22_STREAM,
  AUDIO_2110_30_31_STREAM,
  ANCILLARY_2110_40_STREAM,
  APPLICATION_CUSTOM_STREAM,
enum  VideoType {
  PROGRESSIVE = 1,
  INTERLACE = 2,
  PROGRESSIVE = 1,
  INTERLACE = 2
enum  MemoryType {
  MEM_TYPE_HOST,
  MEM_TYPE_DEVICE,
  MEM_TYPE_SYSTEM,
  MEM_TYPE_UNKNOWN,
  MEM_TYPE_HOST,
  MEM_TYPE_DEVICE,
  MEM_TYPE_SYSTEM,
  MEM_TYPE_UNKNOWN
Functions
gboolean gst_udp_parse_uri (const gchar *uristr, gchar **host, guint16 *port)
GInetAddress * gst_udp_resolve_name (gpointer obj, const gchar *address)
GType gst_rtp_timestamp_meta_api_get_type (void)
const GstMetaInfo * gst_rtp_timestamp_meta_get_info (void)
GstRTPTimestampMetagst_buffer_add_rtp_timestamp_meta (GstBuffer *buffer, guint32 timestamp)
GstRTPTimestampMetagst_buffer_get_rtp_timestamp_meta (GstBuffer *buffer)
void * gpu_allocate_memory (int gpuId, size_t size, size_t align)
size_t gpu_aligned_size (int gpuId, size_t allocSize)
gboolean cudaFreeMmap (uint64_t *ptr, size_t size)
◆ CHECK_CUDA
#define CHECK_CUDA (   err,
  err_str
Value:
do { \
if ((err) != cudaSuccess) { \
GST_WARNING (err_str ", cuda err: %s", cudaGetErrorName (err)); \
return FALSE; \
} while (0)
Definition at line 21 of file 9.0/sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h.
◆ DEFAULT_PTP_SRC
◆ INVALID_STREAM_ID
◆ LEAP_SECONDS
◆ MAX_ST2022_7_STREAMS
◆ round_up
#define round_up (   num,
  round
Typedef Documentation
◆ GstRTPTimestampMeta
◆ MemoryType
◆ StreamType
◆ VideoType
◆ MemoryType
enum MemoryType
Enumerator
MEM_TYPE_HOST
MEM_TYPE_DEVICE
MEM_TYPE_SYSTEM
MEM_TYPE_UNKNOWN
MEM_TYPE_HOST
MEM_TYPE_DEVICE
MEM_TYPE_SYSTEM
MEM_TYPE_UNKNOWN
Definition at line 48 of file 9.0/sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h.
◆ StreamType
enum StreamType
Enumerator
Definition at line 35 of file 9.0/sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h.
◆ VideoType
enum VideoType
Enumerator
PROGRESSIVE
INTERLACE
PROGRESSIVE
INTERLACE
Definition at line 43 of file 9.0/sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h.
Function Documentation
◆ cudaFreeMmap()
gboolean cudaFreeMmap ( uint64_t *  ptr,
size_t  size
◆ gpu_aligned_size()
size_t gpu_aligned_size ( int  gpuId,
size_t  allocSize
◆ gpu_allocate_memory()
void* gpu_allocate_memory ( int  gpuId,
size_t  size,
size_t  align
◆ gst_buffer_add_rtp_timestamp_meta()
GstRTPTimestampMeta* gst_buffer_add_rtp_timestamp_meta ( GstBuffer buffer,
guint32  timestamp
◆ gst_buffer_get_rtp_timestamp_meta()
GstRTPTimestampMeta* gst_buffer_get_rtp_timestamp_meta ( GstBuffer buffer)
◆ gst_rtp_timestamp_meta_api_get_type()
GType gst_rtp_timestamp_meta_api_get_type ( void  )
◆ gst_rtp_timestamp_meta_get_info()
const GstMetaInfo* gst_rtp_timestamp_meta_get_info ( void  )
◆ gst_udp_parse_uri()
gboolean gst_udp_parse_uri ( const gchar *  uristr,
gchar **  host,
guint16 *  port
◆ gst_udp_resolve_name()
GInetAddress* gst_udp_resolve_name ( gpointer  obj,
const gchar *  address
