9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h File Reference
nvdsgst_inferserver plugin header file.
This file contains the standard GStreamer boilerplate definitions and declarations for the nvinferserver element and plugin.
Definition in file 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h.
Data Structures
struct  _GstNvInferServer
 Opaque structure storing data of the nvinferserver element. More...
struct  _GstNvInferServerClass
 The class structure for the nvinferserver element. More...
Namespaces
 gstnvinferserver
Macros
#define PACKAGE   "nvinferserver"
#define VERSION   "1.0"
#define LICENSE   "Proprietary"
#define DESCRIPTION   "NVIDIA DeepStreamSDK TensorRT Inference Server plugin"
#define BINARY_PACKAGE   "NVIDIA DeepStreamSDK TensorRT Inference Server plugin"
#define URL   "http://nvidia.com/"
#define GST_TYPE_NVINFER_SERVER   (gst_nvinfer_server_get_type())
#define GST_NVINFER_SERVER(obj)
#define GST_NVINFER_SERVER_CLASS(klass)
#define GST_NVINFER_SERVER_GET_CLASS(obj)
#define GST_IS_NVINFER(obj)   (G_TYPE_CHECK_INSTANCE_TYPE((obj), GST_TYPE_NVINFER_SERVER))
#define GST_IS_NVINFER_CLASS(klass)   (G_TYPE_CHECK_CLASS_TYPE((klass), GST_TYPE_NVINFER_SERVER))
#define GST_NVINFER_SERVER_CAST(obj)   ((GstNvInferServer*)(obj))
Typedefs
typedef typedefG_BEGIN_DECLS struct _GstNvInferServer GstNvInferServer
typedef struct _GstNvInferServerClass GstNvInferServerClass
Enumerations
enum  GstNvInferServerProperty {
  PROP_0,
  PROP_UNIQUE_ID,
  PROP_PROCESS_MODE,
  PROP_CONFIG_FILE_PATH,
  PROP_BATCH_SIZE,
  PROP_INFER_ON_GIE_ID,
  PROP_OPERATE_ON_CLASS_IDS,
  PROP_INTERVAL,
  PROP_OUTPUT_CALLBACK,
  PROP_OUTPUT_CALLBACK_USERDATA,
  PROP_INPUT_TENSOR_META,
  PROP_LAST,
  PROP_0,
  PROP_UNIQUE_ID,
  PROP_PROCESS_MODE,
  PROP_BATCH_SIZE,
  PROP_INTERVAL,
  PROP_LAST
 List of GObject properties for the element. More...
Functions
GType gst_nvinfer_server_get_type (void)
◆ BINARY_PACKAGE
◆ DESCRIPTION
◆ GST_IS_NVINFER
#define GST_IS_NVINFER (   obj)    (G_TYPE_CHECK_INSTANCE_TYPE((obj), GST_TYPE_NVINFER_SERVER))
◆ GST_IS_NVINFER_CLASS
#define GST_IS_NVINFER_CLASS (   klass)    (G_TYPE_CHECK_CLASS_TYPE((klass), GST_TYPE_NVINFER_SERVER))
◆ GST_NVINFER_SERVER
#define GST_NVINFER_SERVER (   obj)
Value:
(G_TYPE_CHECK_INSTANCE_CAST( \
Definition at line 52 of file 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h.
◆ GST_NVINFER_SERVER_CAST
#define GST_NVINFER_SERVER_CAST (   obj)    ((GstNvInferServer*)(obj))
◆ GST_NVINFER_SERVER_CLASS
#define GST_NVINFER_SERVER_CLASS (   klass)
Value:
(G_TYPE_CHECK_CLASS_CAST( \
Definition at line 55 of file 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h.
◆ GST_NVINFER_SERVER_GET_CLASS
#define GST_NVINFER_SERVER_GET_CLASS (   obj)
Value:
(G_TYPE_INSTANCE_GET_CLASS( \
Definition at line 58 of file 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h.
◆ GST_TYPE_NVINFER_SERVER
◆ LICENSE
◆ PACKAGE
◆ URL
◆ VERSION
Typedef Documentation
◆ GstNvInferServer
◆ GstNvInferServerClass
◆ GstNvInferServerProperty
Enumerator
PROP_0
PROP_UNIQUE_ID
PROP_PROCESS_MODE
PROP_BATCH_SIZE
PROP_INTERVAL
PROP_LAST
PROP_0
PROP_UNIQUE_ID
PROP_PROCESS_MODE
PROP_BATCH_SIZE
PROP_INTERVAL
PROP_LAST
Definition at line 70 of file 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h.
Function Documentation
◆ gst_nvinfer_server_get_type()
GType gst_nvinfer_server_get_type ( void  )
GstNvInferServer
Definition: sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h:47
Definition: 9.0/sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h:51
Definition: sources/gst-plugins/gst-nvinferserver/gstnvinferserver.h:121
