9.0/sources/includes/nvmsgbroker.h File Reference
Data Structures
struct  NvMsgBrokerClientMsg
Macros
#define NV_MSGBROKER_VERSION   "2.0"
#define LOG_CAT   "DSLOG:NV_MSGBROKER"
Typedefs
typedef void * NvMsgBrokerClientHandle
typedef void(* nv_msgbroker_connect_cb_t) (NvMsgBrokerClientHandle h_ptr, NvMsgBrokerErrorType status)
 Connect callback method registered during connect. More...
typedef void(* nv_msgbroker_send_cb_t) (void *user_ptr, NvMsgBrokerErrorType status)
 Send callback method registered during send_async. More...
typedef void(* nv_msgbroker_subscribe_cb_t) (NvMsgBrokerErrorType status, void *msg, int msglen, char *topic, void *user_ptr)
 subscribe callback method registered during subscribe More...
Enumerations
enum  NvMsgBrokerErrorType {
  NV_MSGBROKER_API_OK,
  NV_MSGBROKER_API_ERR,
  NV_MSGBROKER_API_RECONNECTING,
  NV_MSGBROKER_API_NOT_SUPPORTED,
Functions
NvMsgBrokerClientHandle nv_msgbroker_connect (char *broker_conn_str, char *broker_proto_lib, nv_msgbroker_connect_cb_t connect_cb, char *cfg)
 Connect to a remote entity by calling into msgbroker library. More...
NvMsgBrokerErrorType nv_msgbroker_send_async (NvMsgBrokerClientHandle h_ptr, NvMsgBrokerClientMsg message, nv_msgbroker_send_cb_t cb, void *user_ctx)
NvMsgBrokerErrorType nv_msgbroker_subscribe (NvMsgBrokerClientHandle h_ptr, char **topics, int num_topics, nv_msgbroker_subscribe_cb_t cb, void *user_ctx)
 Subscribe to a remote entity for receiving messages on particular topic(s) More...
NvMsgBrokerErrorType nv_msgbroker_disconnect (NvMsgBrokerClientHandle h_ptr)
char * nv_msgbroker_version (void)
◆ LOG_CAT
Definition at line 29 of file 9.0/sources/includes/nvmsgbroker.h.
◆ NV_MSGBROKER_VERSION
Definition at line 28 of file 9.0/sources/includes/nvmsgbroker.h.
Typedef Documentation
◆ nv_msgbroker_connect_cb_t
Parameters
[in]h_ptrMsgbroker Connection handle
[in]statusConnection status
Definition at line 62 of file 9.0/sources/includes/nvmsgbroker.h.
◆ nv_msgbroker_send_cb_t
Parameters
[in]user_ptrPointer passed during send_async for context
[in]statusCompletion status of send operation
Definition at line 68 of file 9.0/sources/includes/nvmsgbroker.h.
◆ nv_msgbroker_subscribe_cb_t
Parameters
[in]msgConsumer Message. Should be copied before function return
[in]msglenLength of message consumed
[in]topicSubscribed Topic where message is received
Definition at line 78 of file 9.0/sources/includes/nvmsgbroker.h.
◆ NvMsgBrokerClientHandle
typedef void* NvMsgBrokerClientHandle
Definition at line 54 of file 9.0/sources/includes/nvmsgbroker.h.
◆ NvMsgBrokerErrorType
Enumerator
NV_MSGBROKER_API_OK
NV_MSGBROKER_API_OK
Definition at line 34 of file 9.0/sources/includes/nvmsgbroker.h.
Function Documentation
◆ nv_msgbroker_connect()
NvMsgBrokerClientHandle nv_msgbroker_connect ( char *  broker_conn_str,
char *  broker_proto_lib,
char *  cfg
Parameters
[in]broker_conn_strA connection string (optional) with format
[in]broker_proto_libFull Path to Message protocol adapter library
[in]connect_cbA pointer to a callback function for events associated with the connection.
[in]cfgPathname of a configuration file passed to be passed to the message protocol adapter
Returns
A connection handle.
◆ nv_msgbroker_disconnect()
NvMsgBrokerErrorType nv_msgbroker_disconnect ( NvMsgBrokerClientHandle  h_ptr)
◆ nv_msgbroker_send_async()
NvMsgBrokerErrorType nv_msgbroker_send_async ( NvMsgBrokerClientHandle  h_ptr,
void *  user_ctx
◆ nv_msgbroker_subscribe()
NvMsgBrokerErrorType nv_msgbroker_subscribe ( NvMsgBrokerClientHandle  h_ptr,
char **  topics,
int  num_topics,
void *  user_ctx
Parameters
[in]h_ptrConnection handle
[in]topicspointer to array of topics (cannot be NULL)
[in]num_topicsnumber of topics
[in]cbA pointer to a callback function to forward consumed message
[in]user_ctxuser ptr to be passed to callback for context
Returns
◆ nv_msgbroker_version()
char* nv_msgbroker_version ( void  )
