9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h File Reference
Macros
#define TRITONSERVER_DECLSPEC
#define TRITONSERVER_API_VERSION_MAJOR   1
 TRITONSERVER API Version. More...
#define TRITONSERVER_API_VERSION_MINOR   34
Typedefs
typedef enum TRITONSERVER_datatype_enum TRITONSERVER_DataType
 TRITONSERVER_DataType. More...
typedef enum TRITONSERVER_memorytype_enum TRITONSERVER_MemoryType
 TRITONSERVER_MemoryType. More...
typedef enum TRITONSERVER_parametertype_enum TRITONSERVER_ParameterType
 TRITONSERVER_ParameterType. More...
typedef enum TRITONSERVER_instancegroupkind_enum TRITONSERVER_InstanceGroupKind
 TRITONSERVER_InstanceGroupKind. More...
typedef enum TRITONSERVER_loglevel_enum TRITONSERVER_LogLevel
 TRITONSERVER_Logging. More...
typedef enum TRITONSERVER_logformat_enum TRITONSERVER_LogFormat
 Logging Formats. More...
typedef enum TRITONSERVER_errorcode_enum TRITONSERVER_Error_Code
 TRITONSERVER_Error. More...
typedef struct TRITONSERVER_Error *(* TRITONSERVER_ResponseAllocatorAllocFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp, void **buffer, void **buffer_userp, TRITONSERVER_MemoryType *actual_memory_type, int64_t *actual_memory_type_id)
 TRITONSERVER_ResponseAllocator. More...
typedef struct TRITONSERVER_Error *(* TRITONSERVER_ResponseAllocatorBufferAttributesFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, struct TRITONSERVER_BufferAttributes *buffer_attributes, void *userp, void *buffer_userp)
 Type for allocation function that allocates a buffer to hold an output tensor with buffer attributes. More...
typedef struct TRITONSERVER_Error *(* TRITONSERVER_ResponseAllocatorQueryFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp, const char *tensor_name, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id)
 Type for function that is called to query the allocator's preferred memory type and memory type ID. More...
typedef struct TRITONSERVER_Error *(* TRITONSERVER_ResponseAllocatorReleaseFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *buffer, void *buffer_userp, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id)
 Type for function that is called when the server no longer holds any reference to a buffer allocated by TRITONSERVER_ResponseAllocatorAllocFn_t. More...
typedef struct TRITONSERVER_Error *(* TRITONSERVER_ResponseAllocatorStartFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp)
 Type for function that is called to indicate that subsequent allocation requests will refer to a new response. More...
typedef enum tritonserver_metricformat_enum TRITONSERVER_MetricFormat
 TRITONSERVER_Metrics. More...
typedef enum tritonserver_tracelevel_enum TRITONSERVER_InferenceTraceLevel
 TRITONSERVER_InferenceTrace. More...
typedef enum tritonserver_traceactivity_enum TRITONSERVER_InferenceTraceActivity
 Trace activities. More...
typedef void(* TRITONSERVER_InferenceTraceActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, uint64_t timestamp_ns, void *userp)
 Type for trace timeline activity callback function. More...
typedef void(* TRITONSERVER_InferenceTraceTensorActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, const char *name, TRITONSERVER_DataType datatype, const void *base, size_t byte_size, const int64_t *shape, uint64_t dim_count, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp)
 Type for trace tensor activity callback function. More...
typedef void(* TRITONSERVER_InferenceTraceReleaseFn_t) (struct TRITONSERVER_InferenceTrace *trace, void *userp)
 Type for trace release callback function. More...
typedef enum tritonserver_requestflag_enum TRITONSERVER_RequestFlag
 TRITONSERVER_InferenceRequest. More...
typedef enum tritonserver_requestreleaseflag_enum TRITONSERVER_RequestReleaseFlag
 Inference request release flags. More...
typedef enum tritonserver_responsecompleteflag_enum TRITONSERVER_ResponseCompleteFlag
 Inference response complete flags. More...
typedef void(* TRITONSERVER_InferenceRequestReleaseFn_t) (struct TRITONSERVER_InferenceRequest *request, const uint32_t flags, void *userp)
 Type for inference request release callback function. More...
typedef void(* TRITONSERVER_InferenceResponseCompleteFn_t) (struct TRITONSERVER_InferenceResponse *response, const uint32_t flags, void *userp)
 Type for callback function indicating that an inference response has completed. More...
typedef enum tritonserver_modelcontrolmode_enum TRITONSERVER_ModelControlMode
 TRITONSERVER_ServerOptions. More...
typedef enum tritonserver_ratelimitmode_enum TRITONSERVER_RateLimitMode
 Rate limit modes. More...
typedef enum tritonserver_batchflag_enum TRITONSERVER_ModelBatchFlag
 TRITONSERVER_Server. More...
typedef enum tritonserver_modelindexflag_enum TRITONSERVER_ModelIndexFlag
 Model index flags. The enum values must be power-of-2 values. More...
typedef enum tritonserver_txn_property_flag_enum TRITONSERVER_ModelTxnPropertyFlag
 Model transaction policy flags. More...
typedef enum TRITONSERVER_metrickind_enum TRITONSERVER_MetricKind
 TRITONSERVER_MetricKind. More...
Enumerations
enum  TRITONSERVER_datatype_enum {
  TRITONSERVER_TYPE_INVALID,
  TRITONSERVER_TYPE_BOOL,
  TRITONSERVER_TYPE_UINT8,
  TRITONSERVER_TYPE_UINT16,
  TRITONSERVER_TYPE_UINT32,
  TRITONSERVER_TYPE_UINT64,
  TRITONSERVER_TYPE_INT8,
  TRITONSERVER_TYPE_INT16,
  TRITONSERVER_TYPE_INT32,
  TRITONSERVER_TYPE_INT64,
  TRITONSERVER_TYPE_FP16,
  TRITONSERVER_TYPE_FP32,
  TRITONSERVER_TYPE_FP64,
  TRITONSERVER_TYPE_BYTES,
  TRITONSERVER_TYPE_BF16,
enum  TRITONSERVER_memorytype_enum {
  TRITONSERVER_MEMORY_CPU,
  TRITONSERVER_MEMORY_CPU_PINNED,
  TRITONSERVER_MEMORY_GPU,
enum  TRITONSERVER_parametertype_enum {
  TRITONSERVER_PARAMETER_STRING,
  TRITONSERVER_PARAMETER_INT,
  TRITONSERVER_PARAMETER_BOOL,
  TRITONSERVER_PARAMETER_DOUBLE,
  TRITONSERVER_PARAMETER_BYTES,
enum  TRITONSERVER_instancegroupkind_enum {
  TRITONSERVER_INSTANCEGROUPKIND_AUTO,
  TRITONSERVER_INSTANCEGROUPKIND_CPU,
  TRITONSERVER_INSTANCEGROUPKIND_GPU,
  TRITONSERVER_INSTANCEGROUPKIND_MODEL,
enum  TRITONSERVER_loglevel_enum {
  TRITONSERVER_LOG_INFO,
  TRITONSERVER_LOG_WARN,
  TRITONSERVER_LOG_ERROR,
  TRITONSERVER_LOG_VERBOSE,
enum  TRITONSERVER_logformat_enum {
  TRITONSERVER_LOG_DEFAULT,
  TRITONSERVER_LOG_ISO8601,
enum  TRITONSERVER_errorcode_enum {
  TRITONSERVER_ERROR_UNKNOWN,
  TRITONSERVER_ERROR_INTERNAL,
  TRITONSERVER_ERROR_NOT_FOUND,
  TRITONSERVER_ERROR_INVALID_ARG,
  TRITONSERVER_ERROR_UNAVAILABLE,
  TRITONSERVER_ERROR_UNSUPPORTED,
  TRITONSERVER_ERROR_ALREADY_EXISTS,
  TRITONSERVER_ERROR_CANCELLED,
enum  tritonserver_metricformat_enum {
  TRITONSERVER_METRIC_PROMETHEUS,
enum  tritonserver_tracelevel_enum {
  TRITONSERVER_TRACE_LEVEL_DISABLED = 0,
  TRITONSERVER_TRACE_LEVEL_MIN = 1,
  TRITONSERVER_TRACE_LEVEL_MAX = 2,
  TRITONSERVER_TRACE_LEVEL_TIMESTAMPS = 0x4,
  TRITONSERVER_TRACE_LEVEL_TENSORS = 0x8,
enum  tritonserver_traceactivity_enum {
  TRITONSERVER_TRACE_REQUEST_START = 0,
  TRITONSERVER_TRACE_QUEUE_START = 1,
  TRITONSERVER_TRACE_COMPUTE_START = 2,
  TRITONSERVER_TRACE_COMPUTE_INPUT_END = 3,
  TRITONSERVER_TRACE_COMPUTE_OUTPUT_START = 4,
  TRITONSERVER_TRACE_COMPUTE_END = 5,
  TRITONSERVER_TRACE_REQUEST_END = 6,
  TRITONSERVER_TRACE_TENSOR_QUEUE_INPUT = 7,
  TRITONSERVER_TRACE_TENSOR_BACKEND_INPUT = 8,
  TRITONSERVER_TRACE_TENSOR_BACKEND_OUTPUT = 9,
  TRITONSERVER_TRACE_CUSTOM_ACTIVITY = 10,
enum  tritonserver_requestflag_enum {
  TRITONSERVER_REQUEST_FLAG_SEQUENCE_START = 1,
  TRITONSERVER_REQUEST_FLAG_SEQUENCE_END = 2,
enum  tritonserver_requestreleaseflag_enum {
  TRITONSERVER_REQUEST_RELEASE_ALL = 1,
  TRITONSERVER_REQUEST_RELEASE_RESCHEDULE = 2,
enum  tritonserver_responsecompleteflag_enum {
  TRITONSERVER_RESPONSE_COMPLETE_FINAL = 1,
enum  tritonserver_modelcontrolmode_enum {
  TRITONSERVER_MODEL_CONTROL_NONE,
  TRITONSERVER_MODEL_CONTROL_POLL,
  TRITONSERVER_MODEL_CONTROL_EXPLICIT,
enum  tritonserver_ratelimitmode_enum {
  TRITONSERVER_RATE_LIMIT_OFF,
  TRITONSERVER_RATE_LIMIT_EXEC_COUNT,
enum  tritonserver_batchflag_enum {
  TRITONSERVER_BATCH_UNKNOWN = 1,
  TRITONSERVER_BATCH_FIRST_DIM = 2,
enum  tritonserver_modelindexflag_enum {
  TRITONSERVER_INDEX_FLAG_READY = 1,
enum  tritonserver_txn_property_flag_enum {
  TRITONSERVER_TXN_ONE_TO_ONE = 1,
  TRITONSERVER_TXN_DECOUPLED = 2,
enum  TRITONSERVER_metrickind_enum {
  TRITONSERVER_METRIC_KIND_COUNTER,
  TRITONSERVER_METRIC_KIND_GAUGE,
  TRITONSERVER_METRIC_KIND_HISTOGRAM,
Functions
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ApiVersion (uint32_t *major, uint32_t *minor)
 Get the TRITONBACKEND API version supported by the Triton shared library. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_DataTypeString (TRITONSERVER_DataType datatype)
 Get the string representation of a data type. More...
TRITONSERVER_DECLSPEC TRITONSERVER_DataType TRITONSERVER_StringToDataType (const char *dtype)
 Get the Triton datatype corresponding to a string representation of a datatype. More...
TRITONSERVER_DECLSPEC uint32_t TRITONSERVER_DataTypeByteSize (TRITONSERVER_DataType datatype)
 Get the size of a Triton datatype in bytes. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_MemoryTypeString (TRITONSERVER_MemoryType memtype)
 Get the string representation of a memory type. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_ParameterTypeString (TRITONSERVER_ParameterType paramtype)
 Get the string representation of a parameter type. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter * TRITONSERVER_ParameterNew (const char *name, const TRITONSERVER_ParameterType type, const void *value)
 Create a new parameter object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter * TRITONSERVER_ParameterBytesNew (const char *name, const void *byte_ptr, const uint64_t size)
 Create a new parameter object with type TRITONSERVER_PARAMETER_BYTES. More...
TRITONSERVER_DECLSPEC void TRITONSERVER_ParameterDelete (struct TRITONSERVER_Parameter *parameter)
 Delete an parameter object. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_InstanceGroupKindString (TRITONSERVER_InstanceGroupKind kind)
 Get the string representation of an instance-group kind. More...
TRITONSERVER_DECLSPEC bool TRITONSERVER_LogIsEnabled (TRITONSERVER_LogLevel level)
 Is a log level enabled? More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_LogMessage (TRITONSERVER_LogLevel level, const char *filename, const int line, const char *msg)
 Log a message at a given log level if that level is enabled. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ErrorNew (TRITONSERVER_Error_Code code, const char *msg)
 Create a new error object. More...
TRITONSERVER_DECLSPEC void TRITONSERVER_ErrorDelete (struct TRITONSERVER_Error *error)
 Delete an error object. More...
TRITONSERVER_DECLSPEC TRITONSERVER_Error_Code TRITONSERVER_ErrorCode (struct TRITONSERVER_Error *error)
 Get the error code. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_ErrorCodeString (struct TRITONSERVER_Error *error)
 Get the string representation of an error code. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_ErrorMessage (struct TRITONSERVER_Error *error)
 Get the error message. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ResponseAllocatorNew (struct TRITONSERVER_ResponseAllocator **allocator, TRITONSERVER_ResponseAllocatorAllocFn_t alloc_fn, TRITONSERVER_ResponseAllocatorReleaseFn_t release_fn, TRITONSERVER_ResponseAllocatorStartFn_t start_fn)
 Create a new response allocator object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ResponseAllocatorSetBufferAttributesFunction (struct TRITONSERVER_ResponseAllocator *allocator, TRITONSERVER_ResponseAllocatorBufferAttributesFn_t buffer_attributes_fn)
 Set the buffer attributes function for a response allocator object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ResponseAllocatorSetQueryFunction (struct TRITONSERVER_ResponseAllocator *allocator, TRITONSERVER_ResponseAllocatorQueryFn_t query_fn)
 Set the query function to a response allocator object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ResponseAllocatorDelete (struct TRITONSERVER_ResponseAllocator *allocator)
 Delete a response allocator. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MessageNewFromSerializedJson (struct TRITONSERVER_Message **message, const char *base, size_t byte_size)
 TRITONSERVER_Message. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MessageDelete (struct TRITONSERVER_Message *message)
 Delete a message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MessageSerializeToJson (struct TRITONSERVER_Message *message, const char **base, size_t *byte_size)
 Get the base and size of the buffer containing the serialized message in JSON format. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricsDelete (struct TRITONSERVER_Metrics *metrics)
 Delete a metrics object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricsFormatted (struct TRITONSERVER_Metrics *metrics, TRITONSERVER_MetricFormat format, const char **base, size_t *byte_size)
 Get a buffer containing the metrics in the specified format. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_InferenceTraceLevelString (TRITONSERVER_InferenceTraceLevel level)
 Get the string representation of a trace level. More...
const TRITONSERVER_DECLSPEC char * TRITONSERVER_InferenceTraceActivityString (TRITONSERVER_InferenceTraceActivity activity)
 Get the string representation of a trace activity. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceNew (struct TRITONSERVER_InferenceTrace **trace, TRITONSERVER_InferenceTraceLevel level, uint64_t parent_id, TRITONSERVER_InferenceTraceActivityFn_t activity_fn, TRITONSERVER_InferenceTraceReleaseFn_t release_fn, void *trace_userp)
 Create a new inference trace object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceTensorNew (struct TRITONSERVER_InferenceTrace **trace, TRITONSERVER_InferenceTraceLevel level, uint64_t parent_id, TRITONSERVER_InferenceTraceActivityFn_t activity_fn, TRITONSERVER_InferenceTraceTensorActivityFn_t tensor_activity_fn, TRITONSERVER_InferenceTraceReleaseFn_t release_fn, void *trace_userp)
TRITONSERVER_DECLSPEC TRITONSERVER_Error * TRITONSERVER_InferenceTraceReportActivity (TRITONSERVER_InferenceTrace *trace, uint64_t timestamp, const char *activity_name)
 Report a trace activity. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceDelete (struct TRITONSERVER_InferenceTrace *trace)
 Delete a trace object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceId (struct TRITONSERVER_InferenceTrace *trace, uint64_t *id)
 Get the id associated with a trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceParentId (struct TRITONSERVER_InferenceTrace *trace, uint64_t *parent_id)
 Get the parent id associated with a trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceModelName (struct TRITONSERVER_InferenceTrace *trace, const char **model_name)
 Get the name of the model associated with a trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceModelVersion (struct TRITONSERVER_InferenceTrace *trace, int64_t *model_version)
 Get the version of the model associated with a trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceRequestId (struct TRITONSERVER_InferenceTrace *trace, const char **request_id)
 Get the request id associated with a trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceSpawnChildTrace (struct TRITONSERVER_InferenceTrace *trace, struct TRITONSERVER_InferenceTrace **child_trace)
 Get the child trace, spawned from the parent trace. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceSetContext (struct TRITONSERVER_InferenceTrace *trace, const char *trace_context)
 Set TRITONSERVER_InferenceTrace context. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceTraceContext (struct TRITONSERVER_InferenceTrace *trace, const char **trace_context)
 Get TRITONSERVER_InferenceTrace context. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestNew (struct TRITONSERVER_InferenceRequest **inference_request, struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version)
 Create a new inference request object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestDelete (struct TRITONSERVER_InferenceRequest *inference_request)
 Delete an inference request object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestId (struct TRITONSERVER_InferenceRequest *inference_request, const char **id)
 Get the ID for a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetId (struct TRITONSERVER_InferenceRequest *inference_request, const char *id)
 Set the ID for a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestFlags (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t *flags)
 Get the flag(s) associated with a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetFlags (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t flags)
 Set the flag(s) associated with a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestCorrelationId (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *correlation_id)
 Get the correlation ID of the inference request as an unsigned integer. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestCorrelationIdString (struct TRITONSERVER_InferenceRequest *inference_request, const char **correlation_id)
 Get the correlation ID of the inference request as a string. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetCorrelationId (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t correlation_id)
 Set the correlation ID of the inference request to be an unsigned integer. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetCorrelationIdString (struct TRITONSERVER_InferenceRequest *inference_request, const char *correlation_id)
 Set the correlation ID of the inference request to be a string. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestCancel (struct TRITONSERVER_InferenceRequest *inference_request)
 Cancel an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestIsCancelled (struct TRITONSERVER_InferenceRequest *inference_request, bool *is_cancelled)
 Query whether the request is cancelled or not. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestPriority (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t *priority)
 Deprecated. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestPriorityUInt64 (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *priority)
 Get the priority for a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetPriority (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t priority)
 Deprecated. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetPriorityUInt64 (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t priority)
 Set the priority for a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestTimeoutMicroseconds (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *timeout_us)
 Get the timeout for a request, in microseconds. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetTimeoutMicroseconds (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t timeout_us)
 Set the timeout for a request, in microseconds. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAddInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const TRITONSERVER_DataType datatype, const int64_t *shape, uint64_t dim_count)
 Add an input to a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAddRawInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name)
 Add a raw input to a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestRemoveInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name)
 Remove an input from a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestRemoveAllInputs (struct TRITONSERVER_InferenceRequest *inference_request)
 Remove all inputs from a request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAppendInputData (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id)
 Assign a buffer of data to an input. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, const char *host_policy_name)
 Assign a buffer of data to an input for execution on all model instances with the specified host policy. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAppendInputDataWithBufferAttributes (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, struct TRITONSERVER_BufferAttributes *buffer_attributes)
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestRemoveAllInputData (struct TRITONSERVER_InferenceRequest *inference_request, const char *name)
 Clear all input data from an input, releasing ownership of the buffer(s) that were appended to the input with TRITONSERVER_InferenceRequestAppendInputData or TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestAddRequestedOutput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name)
 Add an output request to an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestRemoveRequestedOutput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name)
 Remove an output request from an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestRemoveAllRequestedOutputs (struct TRITONSERVER_InferenceRequest *inference_request)
 Remove all output requests from an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetReleaseCallback (struct TRITONSERVER_InferenceRequest *inference_request, TRITONSERVER_InferenceRequestReleaseFn_t request_release_fn, void *request_release_userp)
 Set the release callback for an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetResponseCallback (struct TRITONSERVER_InferenceRequest *inference_request, struct TRITONSERVER_ResponseAllocator *response_allocator, void *response_allocator_userp, TRITONSERVER_InferenceResponseCompleteFn_t response_fn, void *response_userp)
 Set the allocator and response callback for an inference request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetStringParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const char *value)
 Set a string parameter in the request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetIntParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const int64_t value)
 Set an integer parameter in the request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetBoolParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const bool value)
 Set a boolean parameter in the request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceRequestSetDoubleParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const double value)
 Set a double parameter in the request. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseDelete (struct TRITONSERVER_InferenceResponse *inference_response)
 TRITONSERVER_InferenceResponse. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseError (struct TRITONSERVER_InferenceResponse *inference_response)
 Return the error status of an inference response. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseModel (struct TRITONSERVER_InferenceResponse *inference_response, const char **model_name, int64_t *model_version)
 Get model used to produce a response. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseId (struct TRITONSERVER_InferenceResponse *inference_response, const char **request_id)
 Get the ID of the request corresponding to a response. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseParameterCount (struct TRITONSERVER_InferenceResponse *inference_response, uint32_t *count)
 Get the number of parameters available in the response. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseParameter (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const char **name, TRITONSERVER_ParameterType *type, const void **vvalue)
 Get all information about a parameter. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseOutputCount (struct TRITONSERVER_InferenceResponse *inference_response, uint32_t *count)
 Get the number of outputs available in the response. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseOutput (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const char **name, TRITONSERVER_DataType *datatype, const int64_t **shape, uint64_t *dim_count, const void **base, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id, void **userp)
 Get all information about an output tensor. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_InferenceResponseOutputClassificationLabel (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const size_t class_index, const char **label)
 Get a classification label associated with an output for a given index. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesNew (struct TRITONSERVER_BufferAttributes **buffer_attributes)
 TRITONSERVER_BufferAttributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesDelete (struct TRITONSERVER_BufferAttributes *buffer_attributes)
 Delete a buffer attributes object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesSetMemoryTypeId (struct TRITONSERVER_BufferAttributes *buffer_attributes, int64_t memory_type_id)
 Set the memory type id field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesSetMemoryType (struct TRITONSERVER_BufferAttributes *buffer_attributes, TRITONSERVER_MemoryType memory_type)
 Set the memory type field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesSetCudaIpcHandle (struct TRITONSERVER_BufferAttributes *buffer_attributes, void *cuda_ipc_handle)
 Set the CudaIpcHandle field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesSetByteSize (struct TRITONSERVER_BufferAttributes *buffer_attributes, size_t byte_size)
 Set the byte size field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesMemoryTypeId (struct TRITONSERVER_BufferAttributes *buffer_attributes, int64_t *memory_type_id)
 Get the memory type id field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesMemoryType (struct TRITONSERVER_BufferAttributes *buffer_attributes, TRITONSERVER_MemoryType *memory_type)
 Get the memory type field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesCudaIpcHandle (struct TRITONSERVER_BufferAttributes *buffer_attributes, void **cuda_ipc_handle)
 Get the CudaIpcHandle field of the buffer attributes object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_BufferAttributesByteSize (struct TRITONSERVER_BufferAttributes *buffer_attributes, size_t *byte_size)
 Get the byte size field of the buffer attributes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsNew (struct TRITONSERVER_ServerOptions **options)
 Create a new server options object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsDelete (struct TRITONSERVER_ServerOptions *options)
 Delete a server options object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetServerId (struct TRITONSERVER_ServerOptions *options, const char *server_id)
 Set the textual ID for the server in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelRepositoryPath (struct TRITONSERVER_ServerOptions *options, const char *model_repository_path)
 Set the model repository path in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelControlMode (struct TRITONSERVER_ServerOptions *options, TRITONSERVER_ModelControlMode mode)
 Set the model control mode in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetStartupModel (struct TRITONSERVER_ServerOptions *options, const char *model_name)
 Set the model to be loaded at startup in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetStrictModelConfig (struct TRITONSERVER_ServerOptions *options, bool strict)
 Enable or disable strict model configuration handling in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelConfigName (struct TRITONSERVER_ServerOptions *options, const char *model_config_name)
 Set the custom model configuration name to load for all models. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetRateLimiterMode (struct TRITONSERVER_ServerOptions *options, TRITONSERVER_RateLimitMode mode)
 Set the rate limit mode in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsAddRateLimiterResource (struct TRITONSERVER_ServerOptions *options, const char *resource_name, const size_t resource_count, const int device)
 Add resource count for rate limiting. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetPinnedMemoryPoolByteSize (struct TRITONSERVER_ServerOptions *options, uint64_t size)
 Set the total pinned memory byte size that the server can allocate in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetCudaMemoryPoolByteSize (struct TRITONSERVER_ServerOptions *options, int gpu_device, uint64_t size)
 Set the total CUDA memory byte size that the server can allocate on given GPU device in a server options. More...
TRITONSERVER_DECLSPEC TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetCudaVirtualAddressSize (TRITONSERVER_ServerOptions *options, int gpu_device, size_t cuda_virtual_address_size)
 Set the size of the virtual address space that will be used for growable memory in implicit state. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetResponseCacheByteSize (struct TRITONSERVER_ServerOptions *options, uint64_t size)
 Deprecated. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetCacheConfig (struct TRITONSERVER_ServerOptions *options, const char *cache_name, const char *config_json)
 Set the cache config that will be used to initialize the cache implementation for "cache_name". More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetCacheDirectory (struct TRITONSERVER_ServerOptions *options, const char *cache_dir)
 Set the directory containing cache shared libraries. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetMinSupportedComputeCapability (struct TRITONSERVER_ServerOptions *options, double cc)
 Set the minimum support CUDA compute capability in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetExitOnError (struct TRITONSERVER_ServerOptions *options, bool exit)
 Enable or disable exit-on-error in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetStrictReadiness (struct TRITONSERVER_ServerOptions *options, bool strict)
 Enable or disable strict readiness handling in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetExitTimeout (struct TRITONSERVER_ServerOptions *options, unsigned int timeout)
 Set the exit timeout, in seconds, for the server in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetBufferManagerThreadCount (struct TRITONSERVER_ServerOptions *options, unsigned int thread_count)
 Set the number of threads used in buffer manager in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelLoadThreadCount (struct TRITONSERVER_ServerOptions *options, unsigned int thread_count)
 Set the number of threads to concurrently load models in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelLoadRetryCount (struct TRITONSERVER_ServerOptions *options, unsigned int retry_count)
 Set the number of retry to load a model in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelNamespacing (struct TRITONSERVER_ServerOptions *options, bool enable_namespace)
 Enable model namespacing to allow serving models with the same name if they are in different namespaces. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetEnablePeerAccess (struct TRITONSERVER_ServerOptions *options, bool enable_peer_access)
 Enable peer access to allow GPU device to directly access the memory of another GPU device. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogFile (struct TRITONSERVER_ServerOptions *options, const char *file)
 Provide a log output file. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogInfo (struct TRITONSERVER_ServerOptions *options, bool log)
 Enable or disable info level logging. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogWarn (struct TRITONSERVER_ServerOptions *options, bool log)
 Enable or disable warning level logging. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogError (struct TRITONSERVER_ServerOptions *options, bool log)
 Enable or disable error level logging. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogFormat (struct TRITONSERVER_ServerOptions *options, const TRITONSERVER_LogFormat format)
 Set the logging format. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetLogVerbose (struct TRITONSERVER_ServerOptions *options, int level)
 Set verbose logging level. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetMetrics (struct TRITONSERVER_ServerOptions *options, bool metrics)
 Enable or disable metrics collection in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetGpuMetrics (struct TRITONSERVER_ServerOptions *options, bool gpu_metrics)
 Enable or disable GPU metrics collection in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetCpuMetrics (struct TRITONSERVER_ServerOptions *options, bool cpu_metrics)
 Enable or disable CPU metrics collection in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetMetricsInterval (struct TRITONSERVER_ServerOptions *options, uint64_t metrics_interval_ms)
 Set the interval for metrics collection in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetBackendDirectory (struct TRITONSERVER_ServerOptions *options, const char *backend_dir)
 Set the directory containing backend shared libraries. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetRepoAgentDirectory (struct TRITONSERVER_ServerOptions *options, const char *repoagent_dir)
 Set the directory containing repository agent shared libraries. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetModelLoadDeviceLimit (struct TRITONSERVER_ServerOptions *options, const TRITONSERVER_InstanceGroupKind kind, const int device_id, const double fraction)
 Specify the limit on memory usage as a fraction on the device identified by 'kind' and 'device_id'. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetBackendConfig (struct TRITONSERVER_ServerOptions *options, const char *backend_name, const char *setting, const char *value)
 Set a configuration setting for a named backend in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetHostPolicy (struct TRITONSERVER_ServerOptions *options, const char *policy_name, const char *setting, const char *value)
 Set a host policy setting for a given policy name in a server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerOptionsSetMetricsConfig (struct TRITONSERVER_ServerOptions *options, const char *name, const char *setting, const char *value)
 Set a configuration setting for metrics in server options. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerNew (struct TRITONSERVER_Server **server, struct TRITONSERVER_ServerOptions *options)
 Create a new server object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerDelete (struct TRITONSERVER_Server *server)
 Delete a server object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerStop (struct TRITONSERVER_Server *server)
 Stop a server object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerSetExitTimeout (struct TRITONSERVER_Server *server, unsigned int timeout)
 Set the exit timeout on the server object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerRegisterModelRepository (struct TRITONSERVER_Server *server, const char *repository_path, const struct TRITONSERVER_Parameter **name_mapping, const uint32_t mapping_count)
 Register a new model repository. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerUnregisterModelRepository (struct TRITONSERVER_Server *server, const char *repository_path)
 Unregister a model repository. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerPollModelRepository (struct TRITONSERVER_Server *server)
 Check the model repository for changes and update server state based on those changes. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerIsLive (struct TRITONSERVER_Server *server, bool *live)
 Is the server live? More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerIsReady (struct TRITONSERVER_Server *server, bool *ready)
 Is the server ready? More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelIsReady (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, bool *ready)
 Is the model ready? More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelBatchProperties (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, uint32_t *flags, void **voidp)
 Get the batch properties of the model. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelTransactionProperties (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, uint32_t *txn_flags, void **voidp)
 Get the transaction policy of the model. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerMetadata (struct TRITONSERVER_Server *server, struct TRITONSERVER_Message **server_metadata)
 Get the metadata of the server as a TRITONSERVER_Message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelMetadata (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, struct TRITONSERVER_Message **model_metadata)
 Get the metadata of a model as a TRITONSERVER_Message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelStatistics (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, struct TRITONSERVER_Message **model_stats)
 Get the statistics of a model as a TRITONSERVER_Message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelConfig (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, const uint32_t config_version, struct TRITONSERVER_Message **model_config)
 Get the configuration of a model as a TRITONSERVER_Message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerModelIndex (struct TRITONSERVER_Server *server, uint32_t flags, struct TRITONSERVER_Message **model_index)
 Get the index of all unique models in the model repositories as a TRITONSERVER_Message object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerLoadModel (struct TRITONSERVER_Server *server, const char *model_name)
 Load the requested model or reload the model if it is already loaded. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerLoadModelWithParameters (struct TRITONSERVER_Server *server, const char *model_name, const struct TRITONSERVER_Parameter **parameters, const uint64_t parameter_count)
 Load the requested model or reload the model if it is already loaded, with load parameters provided. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerUnloadModel (struct TRITONSERVER_Server *server, const char *model_name)
 Unload the requested model. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerUnloadModelAndDependents (struct TRITONSERVER_Server *server, const char *model_name)
 Unload the requested model, and also unload any dependent model that was loaded along with the requested model (for example, the models composing an ensemble). More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerMetrics (struct TRITONSERVER_Server *server, struct TRITONSERVER_Metrics **metrics)
 Get the current metrics for the server. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_ServerInferAsync (struct TRITONSERVER_Server *server, struct TRITONSERVER_InferenceRequest *inference_request, struct TRITONSERVER_InferenceTrace *trace)
 Perform inference using the meta-data and inputs supplied by the 'inference_request'. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricFamilyNew (struct TRITONSERVER_MetricFamily **family, const TRITONSERVER_MetricKind kind, const char *name, const char *description)
 Create a new metric family object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricFamilyDelete (struct TRITONSERVER_MetricFamily *family)
 Delete a metric family object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_GetMetricFamilyKind (struct TRITONSERVER_MetricFamily *family, TRITONSERVER_MetricKind *kind)
 Get the TRITONSERVER_MetricKind of the metric family. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricArgsNew (struct TRITONSERVER_MetricArgs **args)
 Create a new metric args object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricArgsSetHistogram (struct TRITONSERVER_MetricArgs *args, const double *buckets, const uint64_t buckets_count)
 Set metric args with histogram metric parameter. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricArgsDelete (struct TRITONSERVER_MetricArgs *args)
 Delete a metric args object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricNew (struct TRITONSERVER_Metric **metric, struct TRITONSERVER_MetricFamily *family, const struct TRITONSERVER_Parameter **labels, const uint64_t label_count)
 Create a new metric object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricNewWithArgs (struct TRITONSERVER_Metric **metric, struct TRITONSERVER_MetricFamily *family, const struct TRITONSERVER_Parameter **labels, const uint64_t label_count, const struct TRITONSERVER_MetricArgs *args)
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricDelete (struct TRITONSERVER_Metric *metric)
 Delete a metric object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricValue (struct TRITONSERVER_Metric *metric, double *value)
 Get the current value of a metric object. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricIncrement (struct TRITONSERVER_Metric *metric, double value)
 Increment the current value of metric by value. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricSet (struct TRITONSERVER_Metric *metric, double value)
 Set the current value of metric to value. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_MetricObserve (struct TRITONSERVER_Metric *metric, double value)
 Sample an observation and count it to the appropriate bucket of a metric. More...
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * TRITONSERVER_GetMetricKind (struct TRITONSERVER_Metric *metric, TRITONSERVER_MetricKind *kind)
 Get the TRITONSERVER_MetricKind of metric of its corresponding family. More...
◆ TRITONSERVER_API_VERSION_MAJOR
The TRITONSERVER API is versioned with major and minor version numbers. Any change to the API that does not impact backwards compatibility (for example, adding a non-required function) increases the minor version number. Any change that breaks backwards compatibility (for example, deleting or changing the behavior of a function) increases the major version number. A client should check that the API version used to compile the client is compatible with the API version of the Triton shared library that it is linking against. This is typically done by code similar to the following which makes sure that the major versions are equal and that the minor version of the Triton shared library is >= the minor version used to build the client.
uint32_t api_version_major, api_version_minor; TRITONSERVER_ApiVersion(&api_version_major, &api_version_minor); if ((api_version_major != TRITONSERVER_API_VERSION_MAJOR) || (api_version_minor < TRITONSERVER_API_VERSION_MINOR)) { return TRITONSERVER_ErrorNew( TRITONSERVER_ERROR_UNSUPPORTED, "triton server API version does not support this client"); }
Definition at line 94 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_API_VERSION_MINOR
◆ TRITONSERVER_DECLSPEC
Typedef Documentation
◆ TRITONSERVER_DataType
Tensor data types recognized by TRITONSERVER.
◆ TRITONSERVER_Error_Code
TRITONSERVER_Error.
Errors are reported by a TRITONSERVER_Error object. A NULL TRITONSERVER_Error indicates no error, a non-NULL TRITONSERVER_Error indicates error and the code and message for the error can be retrieved from the object.
The caller takes ownership of a TRITONSERVER_Error object returned by the API and must call TRITONSERVER_ErrorDelete to release the object. The TRITONSERVER_Error error codes
◆ TRITONSERVER_InferenceRequestReleaseFn_t
The callback indicates what type of release is being performed on the request and for some of these the callback function takes ownership of the TRITONSERVER_InferenceRequest object. The 'userp' data is the data provided as 'request_release_userp' in the call to TRITONSERVER_InferenceRequestSetReleaseCallback.
One or more flags will be specified when the callback is invoked, and the callback must take the following actions:
  • TRITONSERVER_REQUEST_RELEASE_ALL: The entire inference request is being released and ownership is passed to the callback function. Triton will not longer access the 'request' object itself nor any input tensor data associated with the request. The callback should free or otherwise manage the 'request' object and all associated tensor data.
  • TRITONSERVER_REQUEST_RELEASE_RESCHEDULE: This flag is currently being consumed internally and the callback is not expected to receive nor process this kind of release. The backend will call TRITONBACKEND_RequestRelease with this flag when it wishes to reschedule the request back to the model. An example is that the model is recursively performing inference of the request and use the rescheduling to proceed the recursive execution.
Note that currently TRITONSERVER_REQUEST_RELEASE_ALL should always be set when the callback is invoked but in the future that may change, so the callback should explicitly check for the flag before taking ownership of the request object.
Definition at line 1004 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_InferenceResponseCompleteFn_t
The callback function takes ownership of the TRITONSERVER_InferenceResponse object. The 'userp' data is the data provided as 'response_userp' in the call to TRITONSERVER_InferenceRequestSetResponseCallback.
One or more flags may be specified when the callback is invoked:
  • TRITONSERVER_RESPONSE_COMPLETE_FINAL: Indicates that no more responses will be generated for a given request (more specifically, that no more responses will be generated for the inference request that set this callback and 'userp'). When this flag is set 'response' may be a response object or may be nullptr. If 'response' is not nullptr, then 'response' is the last response that Triton will produce for the request. If 'response' is nullptr then Triton is indicating that no more responses will be produced for the request.
Definition at line 1025 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_InferenceTraceActivity
◆ TRITONSERVER_InferenceTraceActivityFn_t
This callback function is used to report activity occurring for a trace. This function does not take ownership of 'trace' and so any information needed from that object must be copied before returning. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceNew.
Definition at line 755 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_InferenceTraceLevel
Object that represents tracing for an inference request. Trace levels. The trace level controls the type of trace activities that are reported for an inference request.
Trace level values are power-of-2 and can be combined to trace multiple types of activities. For example, use (TRITONSERVER_TRACE_LEVEL_TIMESTAMPS | TRITONSERVER_TRACE_LEVEL_TENSORS) to trace both timestamps and tensors for an inference request.
TRITONSERVER_TRACE_LEVEL_MIN and TRITONSERVER_TRACE_LEVEL_MAX are deprecated and should not be used.
◆ TRITONSERVER_InferenceTraceReleaseFn_t
This callback function is called when all activity for the trace has completed. The callback function takes ownership of the TRITONSERVER_InferenceTrace object. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceNew.
Definition at line 778 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_InferenceTraceTensorActivityFn_t
This callback function is used to report tensor activity occurring for a trace. This function does not take ownership of 'trace' and so any information needed from that object must be copied before returning. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceTensorNew.
Definition at line 766 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_InstanceGroupKind
Kinds of instance groups recognized by TRITONSERVER.
◆ TRITONSERVER_LogFormat
Logging Formats.
The TRITONSERVER API offers two logging formats. The formats have a common set of fields but differ in how the timestamp for a log entry is represented. Messages are serialized according to JSON encoding rules by default. This behavior can be disabled by setting the environment variable TRITON_SERVER_ESCAPE_LOG_MESSAGES to "0".
  1. TRITONSERVER_LOG_DEFAULT
<level><month><day><hour>:<min>:<sec>.<usec> <pid> <file>:<line>] <msg>
Example:
I0520 20:03:25.829575 3355 model_lifecycle.cc:441] "AsyncLoad() 'simple'"
  1. TRITONSERVER_LOG_ISO8601
<year>-<month>-<day>T<hour>:<min>:<sec>Z <level> <pid> <file>:<line>] <msg>
Example:
2024-05-20T20:03:26Z I 3415 model_lifecycle.cc:441] "AsyncLoad() 'simple'"
◆ TRITONSERVER_LogLevel
Types/levels of logging.
◆ TRITONSERVER_MemoryType
Types of memory recognized by TRITONSERVER.
◆ TRITONSERVER_MetricFormat
Object representing metrics. Metric format types
◆ TRITONSERVER_MetricKind
Types of metrics recognized by TRITONSERVER.
◆ TRITONSERVER_ModelBatchFlag
An inference server. Model batch flags. The enum values must be power-of-2 values.
◆ TRITONSERVER_ModelControlMode
Options to use when creating an inference server. Model control modes
◆ TRITONSERVER_ModelIndexFlag
◆ TRITONSERVER_ModelTxnPropertyFlag
◆ TRITONSERVER_ParameterType
Types of parameters recognized by TRITONSERVER.
◆ TRITONSERVER_RateLimitMode
◆ TRITONSERVER_RequestFlag
Object representing an inference request. The inference request provides the meta-data and input tensor values needed for an inference and returns the inference result meta-data and output tensors. An inference request object can be modified and reused multiple times. Inference request flags. The enum values must be power-of-2 values.
◆ TRITONSERVER_RequestReleaseFlag
◆ TRITONSERVER_ResponseAllocatorAllocFn_t
typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorAllocFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp, void **buffer, void **buffer_userp, TRITONSERVER_MemoryType *actual_memory_type, int64_t *actual_memory_type_id)
Object representing a memory allocator for output tensors in an inference response. Type for allocation function that allocates a buffer to hold an output tensor.
Parameters
allocatorThe allocator that is provided in the call to TRITONSERVER_InferenceRequestSetResponseCallback.
tensor_nameThe name of the output tensor to allocate for.
byte_sizeThe size of the buffer to allocate.
memory_typeThe type of memory that the caller prefers for the buffer allocation.
memory_type_idThe ID of the memory that the caller prefers for the buffer allocation.
userpThe user data pointer that is provided as 'response_allocator_userp' in the call to TRITONSERVER_InferenceRequestSetResponseCallback.
bufferReturns a pointer to the allocated memory.
buffer_userpReturns a user-specified value to associate with the buffer, or nullptr if no user-specified value should be associated with the buffer. This value will be provided in the call to TRITONSERVER_ResponseAllocatorReleaseFn_t when the buffer is released and will also be returned by TRITONSERVER_InferenceResponseOutput.
actual_memory_typeReturns the type of memory where the allocation resides. May be different than the type of memory requested by 'memory_type'.
actual_memory_type_idReturns the ID of the memory where the allocation resides. May be different than the ID of the memory requested by 'memory_type_id'.
Returns
a TRITONSERVER_Error object if a failure occurs while attempting an allocation. If an error is returned all other return values will be ignored.
Definition at line 414 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_ResponseAllocatorBufferAttributesFn_t
typedef struct TRITONSERVER_Error*( * TRITONSERVER_ResponseAllocatorBufferAttributesFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, struct TRITONSERVER_BufferAttributes *buffer_attributes, void *userp, void *buffer_userp)
The callback function must fill in the appropriate buffer attributes information related to this buffer. If set, this function is always called after TRITONSERVER_ResponseAllocatorAllocFn_t function.
Parameters
buffer_attributesThe buffer attributes associated with the buffer.
Returns
Definition at line 444 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_ResponseAllocatorQueryFn_t
typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorQueryFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp, const char *tensor_name, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id)
As much as possible, the allocator should attempt to return the same memory_type and memory_type_id values that will be returned by the subsequent call to TRITONSERVER_ResponseAllocatorAllocFn_t. But the allocator is not required to do so.
Parameters
tensor_nameThe name of the output tensor. This is optional and it should be set to nullptr to indicate that the tensor name has not determined.
byte_sizeThe expected size of the buffer. This is optional and it should be set to nullptr to indicate that the byte size has not determined.
memory_typeActs as both input and output. On input gives the memory type preferred by the caller. Returns memory type preferred by the allocator, taken account of the caller preferred type.
memory_type_idActs as both input and output. On input gives the memory type ID preferred by the caller. Returns memory type ID preferred by the allocator, taken account of the caller preferred type ID.
Returns
a TRITONSERVER_Error object if a failure occurs.
Definition at line 473 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_ResponseAllocatorReleaseFn_t
typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorReleaseFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *buffer, void *buffer_userp, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id)
In practice this function is typically called when the response object associated with the buffer is deleted by TRITONSERVER_InferenceResponseDelete.
Parameters
bufferPointer to the buffer to be freed.
buffer_userpThe user-specified value associated with the buffer in TRITONSERVER_ResponseAllocatorAllocFn_t.
byte_sizeThe size of the buffer.
memory_typeThe type of memory holding the buffer.
memory_type_idThe ID of the memory holding the buffer.
Returns
a TRITONSERVER_Error object if a failure occurs while attempting the release. If an error is returned Triton will not attempt to release the buffer again.
Definition at line 495 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_ResponseAllocatorStartFn_t
typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorStartFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp)
Parameters
Returns
Definition at line 509 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_ResponseCompleteFlag
◆ tritonserver_batchflag_enum
Enumerator
Definition at line 2270 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_datatype_enum
TRITONSERVER_DataType.
Enumerator
Definition at line 115 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_errorcode_enum
TRITONSERVER_Error.
Enumerator
Definition at line 324 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_instancegroupkind_enum
TRITONSERVER_InstanceGroupKind.
Enumerator
Definition at line 236 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_logformat_enum
Logging Formats.
Example:
Example:
Enumerator
Definition at line 289 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_loglevel_enum
TRITONSERVER_Logging.
Enumerator
Definition at line 256 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_memorytype_enum
TRITONSERVER_MemoryType.
Enumerator
Definition at line 163 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_metricformat_enum
Enumerator
Definition at line 652 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_metrickind_enum
Enumerator
Definition at line 2617 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_modelcontrolmode_enum
Enumerator
Definition at line 1761 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_modelindexflag_enum
Enumerator
Definition at line 2276 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ TRITONSERVER_parametertype_enum
TRITONSERVER_ParameterType.
Enumerator
Definition at line 182 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_ratelimitmode_enum
Rate limit modes.
Enumerator
Definition at line 1768 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_requestflag_enum
Enumerator
Definition at line 957 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_requestreleaseflag_enum
Enumerator
Definition at line 964 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_responsecompleteflag_enum
Enumerator
Definition at line 971 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_traceactivity_enum
Trace activities.
Enumerator
Definition at line 726 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_tracelevel_enum
TRITONSERVER_InferenceTrace.
Enumerator
Tracing disabled. No trace activities are reported.
Deprecated. Use TRITONSERVER_TRACE_LEVEL_TIMESTAMPS.
Record timestamps for the inference request.
Record input and output tensor values for the inference request.
Definition at line 703 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
◆ tritonserver_txn_property_flag_enum
Enumerator
Definition at line 2282 of file 9.0/sources/libs/nvdsinferserver/tritonserver_include/tritonserver.h.
Function Documentation
◆ TRITONSERVER_ApiVersion()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ApiVersion ( uint32_t *  major,
uint32_t *  minor
This value can be compared against the TRITONSERVER_API_VERSION_MAJOR and TRITONSERVER_API_VERSION_MINOR used to build the client to ensure that Triton shared library is compatible with the client.
Parameters
majorReturns the TRITONSERVER API major version supported by Triton.
minorReturns the TRITONSERVER API minor version supported by Triton.
Returns
a TRITONSERVER_Error indicating success or failure.
◆ TRITONSERVER_BufferAttributesByteSize()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesByteSize ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
size_t *  byte_size
Parameters
buffer_attributesThe buffer attributes object.
byte_sizeReturns the byte size associated with the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesCudaIpcHandle()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesCudaIpcHandle ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
void **  cuda_ipc_handle
Parameters
cuda_ipc_handleReturns the memory type associated with the buffer attributes object. If the cudaIpcHandle does not exist for the buffer, nullptr will be returned.
Returns
◆ TRITONSERVER_BufferAttributesDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesDelete ( struct TRITONSERVER_BufferAttributes *  buffer_attributes)
Parameters
buffer_attributesThe buffer_attributes object.
Returns
◆ TRITONSERVER_BufferAttributesMemoryType()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesMemoryType ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
Parameters
memory_typeReturns the memory type associated with the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesMemoryTypeId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesMemoryTypeId ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
int64_t *  memory_type_id
Parameters
memory_type_idReturns the memory type id associated with the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesNew ( struct TRITONSERVER_BufferAttributes **  buffer_attributes)
API to create, modify, or retrieve attributes associated with a buffer. Create a new buffer attributes object. The caller takes ownership of the TRITONSERVER_BufferAttributes object and must call TRITONSERVER_BufferAttributesDelete to release the object.
Parameters
buffer_attributesReturns the new buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesSetByteSize()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetByteSize ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
size_t  byte_size
Parameters
byte_sizeByte size to assign to the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesSetCudaIpcHandle()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetCudaIpcHandle ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
void *  cuda_ipc_handle
Parameters
cuda_ipc_handleThe CudaIpcHandle to assign to the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesSetMemoryType()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetMemoryType ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
Parameters
memory_typeMemory type to assign to the buffer attributes object.
Returns
◆ TRITONSERVER_BufferAttributesSetMemoryTypeId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetMemoryTypeId ( struct TRITONSERVER_BufferAttributes *  buffer_attributes,
Parameters
memory_type_idMemory type id to assign to the buffer attributes object.
Returns
◆ TRITONSERVER_DataTypeByteSize()
TRITONSERVER_DECLSPEC uint32_t TRITONSERVER_DataTypeByteSize ( TRITONSERVER_DataType  datatype)
Zero is returned for TRITONSERVER_TYPE_BYTES because it have variable size. Zero is returned for TRITONSERVER_TYPE_INVALID.
Parameters
dtypeThe datatype.
Returns
The size of the datatype.
◆ TRITONSERVER_DataTypeString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_DataTypeString ( TRITONSERVER_DataType  datatype)
Get the string representation of a data type.
The returned string is not owned by the caller and so should not be modified or freed.
Parameters
datatypeThe data type.
Returns
The string representation of the data type.
◆ TRITONSERVER_ErrorCode()
TRITONSERVER_DECLSPEC TRITONSERVER_Error_Code TRITONSERVER_ErrorCode ( struct TRITONSERVER_Error *  error)
Get the error code.
Parameters
errorThe error object.
Returns
The error code.
◆ TRITONSERVER_ErrorCodeString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_ErrorCodeString ( struct TRITONSERVER_Error *  error)
The returned string is not owned by the caller and so should not be modified or freed. The lifetime of the returned string extends only as long as 'error' and must not be accessed once 'error' is deleted.
Parameters
Returns
The string representation of the error code.
◆ TRITONSERVER_ErrorDelete()
TRITONSERVER_DECLSPEC void TRITONSERVER_ErrorDelete ( struct TRITONSERVER_Error *  error)
Parameters
◆ TRITONSERVER_ErrorMessage()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_ErrorMessage ( struct TRITONSERVER_Error *  error)
Parameters
Returns
The error message.
◆ TRITONSERVER_ErrorNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ErrorNew ( TRITONSERVER_Error_Code  code,
const char *  msg
The caller takes ownership of the TRITONSERVER_Error object and must call TRITONSERVER_ErrorDelete to release the object.
Parameters
codeThe error code.
msgThe error message.
Returns
A new TRITONSERVER_Error object.
◆ TRITONSERVER_GetMetricFamilyKind()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_GetMetricFamilyKind ( struct TRITONSERVER_MetricFamily *  family,
Parameters
familyThe metric family object to query.
kindReturns the TRITONSERVER_MetricKind of metric.
Returns
◆ TRITONSERVER_GetMetricKind()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_GetMetricKind ( struct TRITONSERVER_Metric *  metric,
Parameters
metricThe metric object to query.
Returns
◆ TRITONSERVER_InferenceRequestAddInput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddInput ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name,
const int64_t *  shape,
uint64_t  dim_count
Parameters
inference_requestThe request object.
nameThe name of the input.
datatypeThe type of the input. Valid type names are BOOL, UINT8, UINT16, UINT32, UINT64, INT8, INT16, INT32, INT64, FP16, FP32, FP64, and BYTES.
shapeThe shape of the input.
dim_countThe number of dimensions of 'shape'.
Returns
◆ TRITONSERVER_InferenceRequestAddRawInput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddRawInput ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name
The name recognized by the model, data type and shape of the input will be deduced from model configuration. This function must be called at most once on request with no other input to ensure the deduction is accurate.
Parameters
nameThe name of the input. This name is only used as a reference of the raw input in other Tritonserver APIs. It doesn't associate with the name used in the model.
Returns
◆ TRITONSERVER_InferenceRequestAddRequestedOutput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddRequestedOutput ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name
Parameters
nameThe name of the output.
Returns
◆ TRITONSERVER_InferenceRequestAppendInputData()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputData ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name,
const void *  base,
size_t  byte_size,
The buffer will be appended to any existing buffers for that input. The 'inference_request' object takes ownership of the buffer and so the caller should not modify or free the buffer until that ownership is released by 'inference_request' being deleted or by the input being removed from 'inference_request'.
Parameters
baseThe base address of the input data.
byte_sizeThe size, in bytes, of the input data.
memory_typeThe memory type of the input data.
memory_type_idThe memory type id of the input data.
Returns
◆ TRITONSERVER_InferenceRequestAppendInputDataWithBufferAttributes()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputDataWithBufferAttributes ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name,
const void *  base,
Parameters
buffer_attributesThe buffer attributes of the input.
Returns
◆ TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name,
const void *  base,
size_t  byte_size,
const char *  host_policy_name
The buffer will be appended to any existing buffers for that input on all devices with this host policy. The 'inference_request' object takes ownership of the buffer and so the caller should not modify or free the buffer until that ownership is released by 'inference_request' being deleted or by the input being removed from 'inference_request'. If the execution is scheduled on a device that does not have a input buffer specified using this function, then the input buffer specified with TRITONSERVER_InferenceRequestAppendInputData will be used so a non-host policy specific version of data must be added using that API.
Parameters
host_policy_nameAll model instances executing with this host_policy will use this input buffer for execution.
Returns
◆ TRITONSERVER_InferenceRequestCancel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCancel ( struct TRITONSERVER_InferenceRequest *  inference_request)
Requests are canceled on a best effort basis and no guarantee is provided that cancelling a request will result in early termination. Note that the inference request cancellation status will be reset after TRITONSERVER_InferAsync is run. This means that if you cancel the request before calling TRITONSERVER_InferAsync the request will not be cancelled.
Parameters
Returns
◆ TRITONSERVER_InferenceRequestCorrelationId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCorrelationId ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t *  correlation_id
Default is 0, which indicates that the request has no correlation ID. If the correlation id associated with the inference request is a string, this function will return a failure. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
Parameters
correlation_idReturns the correlation ID.
Returns
◆ TRITONSERVER_InferenceRequestCorrelationIdString()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCorrelationIdString ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char **  correlation_id
Default is empty "", which indicates that the request has no correlation ID. If the correlation id associated with the inference request is an unsigned integer, then this function will return a failure. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
Parameters
Returns
◆ TRITONSERVER_InferenceRequestDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestDelete ( struct TRITONSERVER_InferenceRequest *  inference_request)
Parameters
Returns
◆ TRITONSERVER_InferenceRequestFlags()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestFlags ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint32_t *  flags
On return 'flags' holds a bitwise-or of all flag values, see TRITONSERVER_RequestFlag for available flags.
Parameters
flagsReturns the flags.
Returns
◆ TRITONSERVER_InferenceRequestId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestId ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char **  id
The returned ID is owned by 'inference_request' and must not be modified or freed by the caller.
Parameters
idReturns the ID.
Returns
◆ TRITONSERVER_InferenceRequestIsCancelled()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestIsCancelled ( struct TRITONSERVER_InferenceRequest *  inference_request,
bool *  is_cancelled
If possible the backend should terminate any processing and send an error response with cancelled status.
Parameters
is_cancelledReturns whether the inference request is cancelled or not.
Returns
◆ TRITONSERVER_InferenceRequestNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestNew ( struct TRITONSERVER_InferenceRequest **  inference_request,
struct TRITONSERVER_Server *  server,
const char *  model_name,
Create a new inference request object.
Parameters
inference_requestReturns the new request object.
serverthe inference server object.
model_nameThe name of the model to use for the request.
model_versionThe version of the model to use for the request. If -1 then the server will choose a version based on the model's policy.
Returns
◆ TRITONSERVER_InferenceRequestPriority()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestPriority ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint32_t *  priority
Deprecated.
See TRITONSERVER_InferenceRequestPriorityUInt64 instead.
Get the priority for a request. The default is 0 indicating that the request does not specify a priority and so will use the model's default priority.
Parameters
priorityReturns the priority level.
Returns
◆ TRITONSERVER_InferenceRequestPriorityUInt64()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestPriorityUInt64 ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t *  priority
Parameters
Returns
◆ TRITONSERVER_InferenceRequestRemoveAllInputData()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllInputData ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name
Parameters
◆ TRITONSERVER_InferenceRequestRemoveAllInputs()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllInputs ( struct TRITONSERVER_InferenceRequest *  inference_request)
Parameters
Returns
◆ TRITONSERVER_InferenceRequestRemoveAllRequestedOutputs()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllRequestedOutputs ( struct TRITONSERVER_InferenceRequest *  inference_request)
Parameters
Returns
◆ TRITONSERVER_InferenceRequestRemoveInput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveInput ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name
Parameters
Returns
◆ TRITONSERVER_InferenceRequestRemoveRequestedOutput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveRequestedOutput ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  name
Parameters
Returns
◆ TRITONSERVER_InferenceRequestSetBoolParameter()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetBoolParameter ( struct TRITONSERVER_InferenceRequest *  request,
const char *  key,
const bool  value
Parameters
requestThe request.
keyThe name of the parameter.
valueThe value of the parameter.
Returns
◆ TRITONSERVER_InferenceRequestSetCorrelationId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetCorrelationId ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t  correlation_id
Set the correlation ID of the inference request to be an unsigned integer.
Default is 0, which indicates that the request has no correlation ID. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
Parameters
correlation_idThe correlation ID.
Returns
◆ TRITONSERVER_InferenceRequestSetCorrelationIdString()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetCorrelationIdString ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  correlation_id
Set the correlation ID of the inference request to be a string.
Parameters
Returns
◆ TRITONSERVER_InferenceRequestSetDoubleParameter()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetDoubleParameter ( struct TRITONSERVER_InferenceRequest *  request,
const char *  key,
const double  value
Parameters
requestThe request.
Returns
◆ TRITONSERVER_InferenceRequestSetFlags()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetFlags ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint32_t  flags
Set the flag(s) associated with a request.
'flags' should hold a bitwise-or of all flag values, see TRITONSERVER_RequestFlag for available flags.
Parameters
flagsThe flags.
Returns
◆ TRITONSERVER_InferenceRequestSetId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetId ( struct TRITONSERVER_InferenceRequest *  inference_request,
const char *  id
Set the ID for a request.
Parameters
idThe ID.
Returns
◆ TRITONSERVER_InferenceRequestSetIntParameter()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetIntParameter ( struct TRITONSERVER_InferenceRequest *  request,
const char *  key,
const int64_t  value
Parameters
requestThe request.
Returns
◆ TRITONSERVER_InferenceRequestSetPriority()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetPriority ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint32_t  priority
Deprecated.
See TRITONSERVER_InferenceRequestSetPriorityUInt64 instead.
Set the priority for a request. The default is 0 indicating that the request does not specify a priority and so will use the model's default priority.
Parameters
priorityThe priority level.
Returns
◆ TRITONSERVER_InferenceRequestSetPriorityUInt64()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetPriorityUInt64 ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t  priority
Parameters
Returns
◆ TRITONSERVER_InferenceRequestSetReleaseCallback()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetReleaseCallback ( struct TRITONSERVER_InferenceRequest *  inference_request,
void *  request_release_userp
The release callback is called by Triton to return ownership of the request object.
Parameters
request_release_fnThe function called to return ownership of the 'inference_request' object.
request_release_userpUser-provided pointer that is delivered to the 'request_release_fn' callback.
Returns
◆ TRITONSERVER_InferenceRequestSetResponseCallback()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetResponseCallback ( struct TRITONSERVER_InferenceRequest *  inference_request,
struct TRITONSERVER_ResponseAllocator *  response_allocator,
void *  response_allocator_userp,
TRITONSERVER_InferenceResponseCompleteFn_t  response_fn,
void *  response_userp
Set the allocator and response callback for an inference request.
The allocator is used to allocate buffers for any output tensors included in responses that are produced for this request. The response callback is called to return response objects representing responses produced for this request. Typically 'response_allocator_userp' and 'response_userp' will no longer be referenced after 'response_fn' is invoked with 'TRITONSERVER_RESPONSE_COMPLETE_FINAL' flag, therefore the user may release 'response_allocator_userp' and 'response_userp' at that point.
Parameters
response_allocatorThe TRITONSERVER_ResponseAllocator to use to allocate buffers to hold inference results.
response_allocator_userpUser-provided pointer that is delivered to the response allocator's start and allocation functions.
response_fnThe function called to deliver an inference response for this request.
response_userpUser-provided pointer that is delivered to the 'response_fn' callback.
Returns
◆ TRITONSERVER_InferenceRequestSetStringParameter()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetStringParameter ( struct TRITONSERVER_InferenceRequest *  request,
const char *  key,
const char *  value
Set a string parameter in the request.
Parameters
requestThe request.
Returns
◆ TRITONSERVER_InferenceRequestSetTimeoutMicroseconds()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetTimeoutMicroseconds ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t  timeout_us
Set the timeout for a request, in microseconds.
The default is 0 which indicates that the request has no timeout.
Parameters
timeout_usThe timeout, in microseconds.
Returns
◆ TRITONSERVER_InferenceRequestTimeoutMicroseconds()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestTimeoutMicroseconds ( struct TRITONSERVER_InferenceRequest *  inference_request,
uint64_t *  timeout_us
Get the timeout for a request, in microseconds.
Parameters
timeout_usReturns the timeout, in microseconds.
Returns
◆ TRITONSERVER_InferenceResponseDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseDelete ( struct TRITONSERVER_InferenceResponse *  inference_response)
TRITONSERVER_InferenceResponse.
Object representing an inference response. The inference response provides the meta-data and output tensor values calculated by the inference. Delete an inference response object.
Parameters
inference_responseThe response object.
Returns
◆ TRITONSERVER_InferenceResponseError()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseError ( struct TRITONSERVER_InferenceResponse *  inference_response)
Return the error status of an inference response.
Return a TRITONSERVER_Error object on failure, return nullptr on success. The returned error object is owned by 'inference_response' and so should not be deleted by the caller.
Parameters
Returns
a TRITONSERVER_Error indicating the success or failure status of the response.
◆ TRITONSERVER_InferenceResponseId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseId ( struct TRITONSERVER_InferenceResponse *  inference_response,
const char **  request_id
Get the ID of the request corresponding to a response.
The caller does not own the returned ID and must not modify or delete it. The lifetime of all returned values extends until 'inference_response' is deleted.
Parameters
request_idReturns the ID of the request corresponding to this response.
Returns
◆ TRITONSERVER_InferenceResponseModel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseModel ( struct TRITONSERVER_InferenceResponse *  inference_response,
const char **  model_name,
int64_t *  model_version
Get model used to produce a response.
The caller does not own the returned model name value and must not modify or delete it. The lifetime of all returned values extends until 'inference_response' is deleted.
Parameters
model_nameReturns the name of the model.
model_versionReturns the version of the model. this response.
Returns
◆ TRITONSERVER_InferenceResponseOutput()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutput ( struct TRITONSERVER_InferenceResponse *  inference_response,
const uint32_t  index,
const char **  name,
TRITONSERVER_DataType datatype,
const int64_t **  shape,
uint64_t *  dim_count,
const void **  base,
size_t *  byte_size,
int64_t *  memory_type_id,
void **  userp
Get all information about an output tensor.
The tensor data is returned as the base pointer to the data and the size, in bytes, of the data. The caller does not own any of the returned values and must not modify or delete them. The lifetime of all returned values extends until 'inference_response' is deleted.
Parameters
indexThe index of the output tensor, must be 0 <= index < count, where 'count' is the value returned by TRITONSERVER_InferenceResponseOutputCount.
nameReturns the name of the output.
datatypeReturns the type of the output.
shapeReturns the shape of the output.
dim_countReturns the number of dimensions of the returned shape.
baseReturns the tensor data for the output.
byte_sizeReturns the size, in bytes, of the data.
memory_typeReturns the memory type of the data.
memory_type_idReturns the memory type id of the data.
Returns
◆ TRITONSERVER_InferenceResponseOutputClassificationLabel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutputClassificationLabel ( struct TRITONSERVER_InferenceResponse *  inference_response,
const size_t  class_index,
const char **  label
Get a classification label associated with an output for a given index.
The caller does not own the returned label and must not modify or delete it. The lifetime of all returned label extends until 'inference_response' is deleted.
Parameters
class_indexThe index of the class.
nameReturns the label corresponding to 'class_index' or nullptr if no label.
Returns
◆ TRITONSERVER_InferenceResponseOutputCount()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutputCount ( struct TRITONSERVER_InferenceResponse *  inference_response,
uint32_t *  count
Get the number of outputs available in the response.
Parameters
countReturns the number of output tensors.
Returns
◆ TRITONSERVER_InferenceResponseParameter()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseParameter ( struct TRITONSERVER_InferenceResponse *  inference_response,
const char **  name,
TRITONSERVER_ParameterType type,
const void **  vvalue
Get all information about a parameter.
The 'vvalue' returns a void* pointer that must be cast appropriately based on 'type'. For example:
void* vvalue; TRITONSERVER_ParameterType type; TRITONSERVER_InferenceResponseParameter( response, index, &name, &type, &vvalue); switch (type) { case TRITONSERVER_PARAMETER_BOOL: bool value = *(reinterpret_cast<bool*>(vvalue)); ... case TRITONSERVER_PARAMETER_INT: int64_t value = *(reinterpret_cast<int64_t*>(vvalue)); ... case TRITONSERVER_PARAMETER_STRING: const char* value = reinterpret_cast<const char*>(vvalue); ...
Parameters
indexThe index of the parameter, must be 0 <= index < count, where 'count' is the value returned by TRITONSERVER_InferenceResponseParameterCount.
nameReturns the name of the parameter.
typeReturns the type of the parameter.
vvalueReturns a pointer to the parameter value.
Returns
◆ TRITONSERVER_InferenceResponseParameterCount()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseParameterCount ( struct TRITONSERVER_InferenceResponse *  inference_response,
uint32_t *  count
Get the number of parameters available in the response.
Parameters
countReturns the number of parameters.
Returns
◆ TRITONSERVER_InferenceTraceActivityString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_InferenceTraceActivityString ( TRITONSERVER_InferenceTraceActivity  activity)
Get the string representation of a trace activity.
Parameters
activityThe trace activity.
Returns
The string representation of the trace activity.
◆ TRITONSERVER_InferenceTraceContext()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceContext ( struct TRITONSERVER_InferenceTrace *  trace,
const char **  trace_context
Get TRITONSERVER_InferenceTrace context.
Parameters
traceThe trace.
trace_contextReturns the context associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceDelete ( struct TRITONSERVER_InferenceTrace *  trace)
Delete a trace object.
Parameters
traceThe trace object.
Returns
◆ TRITONSERVER_InferenceTraceId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceId ( struct TRITONSERVER_InferenceTrace *  trace,
uint64_t *  id
Get the id associated with a trace.
Every trace is assigned an id that is unique across all traces created for a Triton server.
Parameters
traceThe trace.
idReturns the id associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceLevelString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_InferenceTraceLevelString ( TRITONSERVER_InferenceTraceLevel  level)
Get the string representation of a trace level.
Parameters
levelThe trace level.
Returns
The string representation of the trace level.
◆ TRITONSERVER_InferenceTraceModelName()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceModelName ( struct TRITONSERVER_InferenceTrace *  trace,
Get the name of the model associated with a trace.
The caller does not own the returned string and must not modify or delete it. The lifetime of the returned string extends only as long as 'trace'.
Parameters
traceThe trace.
model_nameReturns the name of the model associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceModelVersion()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceModelVersion ( struct TRITONSERVER_InferenceTrace *  trace,
Get the version of the model associated with a trace.
Parameters
traceThe trace.
model_versionReturns the version of the model associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceNew ( struct TRITONSERVER_InferenceTrace **  trace,
TRITONSERVER_InferenceTraceLevel  level,
uint64_t  parent_id,
TRITONSERVER_InferenceTraceActivityFn_t  activity_fn,
TRITONSERVER_InferenceTraceReleaseFn_t  release_fn,
void *  trace_userp
Create a new inference trace object.
The caller takes ownership of the TRITONSERVER_InferenceTrace object and must call TRITONSERVER_InferenceTraceDelete to release the object.
The activity callback function will be called to report activity for 'trace' as well as for any child traces that are spawned by 'trace', and so the activity callback must check the trace object to determine specifically what activity is being reported.
The release callback is called for both 'trace' and for any child traces spawned by 'trace'.
Parameters
traceReturns the new inference trace object.
levelThe tracing level.
parent_idThe parent trace id for this trace. A value of 0 indicates that there is not parent trace.
activity_fnThe callback function where activity for the trace is reported.
release_fnThe callback function called when all activity is complete for the trace.
trace_userpUser-provided pointer that is delivered to the activity and release callback functions.
Returns
◆ TRITONSERVER_InferenceTraceParentId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceParentId ( struct TRITONSERVER_InferenceTrace *  trace,
uint64_t *  parent_id
Get the parent id associated with a trace.
The parent id indicates a parent-child relationship between two traces. A parent id value of 0 indicates that there is no parent trace.
Parameters
traceThe trace.
idReturns the parent id associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceReportActivity()
TRITONSERVER_DECLSPEC TRITONSERVER_Error* TRITONSERVER_InferenceTraceReportActivity ( TRITONSERVER_InferenceTrace *  trace,
uint64_t  timestamp,
const char *  activity_name
Report a trace activity.
All the traces reported using this API will be using TRITONSERVER_TRACE_CUSTOM_ACTIVITY type.
Parameters
timestampThe timestamp associated with the trace activity.
nameThe trace activity name.
Returns
◆ TRITONSERVER_InferenceTraceRequestId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceRequestId ( struct TRITONSERVER_InferenceTrace *  trace,
Get the request id associated with a trace.
Parameters
traceThe trace.
request_idReturns the version of the model associated with the trace.
Returns
◆ TRITONSERVER_InferenceTraceSetContext()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceSetContext ( struct TRITONSERVER_InferenceTrace *  trace,
const char *  trace_context
Set TRITONSERVER_InferenceTrace context.
Parameters
traceThe trace.
trace_contextA new trace context to associate with the trace.
Returns
◆ TRITONSERVER_InferenceTraceSpawnChildTrace()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceSpawnChildTrace ( struct TRITONSERVER_InferenceTrace *  trace,
struct TRITONSERVER_InferenceTrace **  child_trace
Get the child trace, spawned from the parent trace.
The caller owns the returned object and must call TRITONSERVER_InferenceTraceDelete to release the object, unless ownership is transferred through other APIs (see TRITONSERVER_ServerInferAsync).
Parameters
traceThe trace.
child_traceReturns the child trace, spawned from the trace.
Returns
◆ TRITONSERVER_InferenceTraceTensorNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceTensorNew ( struct TRITONSERVER_InferenceTrace **  trace,
uint64_t  parent_id,
TRITONSERVER_InferenceTraceTensorActivityFn_t  tensor_activity_fn,
void *  trace_userp
The timeline and tensor activity callback function will be called to report activity for 'trace' as well as for any child traces that are spawned by 'trace', and so the activity callback must check the trace object to determine specifically what activity is being reported.
Parameters
activity_fnThe callback function where timeline activity for the trace is reported.
tensor_activity_fnThe callback function where tensor activity for the trace is reported.
Returns
◆ TRITONSERVER_InstanceGroupKindString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_InstanceGroupKindString ( TRITONSERVER_InstanceGroupKind  kind)
Get the string representation of an instance-group kind.
Parameters
kindThe instance-group kind.
Returns
The string representation of the kind.
◆ TRITONSERVER_LogIsEnabled()
TRITONSERVER_DECLSPEC bool TRITONSERVER_LogIsEnabled ( TRITONSERVER_LogLevel  level)
Is a log level enabled?
Parameters
levelThe log level.
Returns
True if the log level is enabled, false if not enabled.
◆ TRITONSERVER_LogMessage()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_LogMessage ( TRITONSERVER_LogLevel  level,
const char *  filename,
const int  line,
const char *  msg
Log a message at a given log level if that level is enabled.
Parameters
levelThe log level.
filenameThe file name of the location of the log message.
lineThe line number of the log message.
msgThe log message.
Returns
◆ TRITONSERVER_MemoryTypeString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_MemoryTypeString ( TRITONSERVER_MemoryType  memtype)
Get the string representation of a memory type.
Parameters
memtypeThe memory type.
Returns
The string representation of the memory type.
◆ TRITONSERVER_MessageDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageDelete ( struct TRITONSERVER_Message *  message)
Delete a message object.
Parameters
messageThe message object.
Returns
◆ TRITONSERVER_MessageNewFromSerializedJson()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageNewFromSerializedJson ( struct TRITONSERVER_Message **  message,
const char *  base,
size_t  byte_size
TRITONSERVER_Message.
Object representing a Triton Server message. Create a new message object from serialized JSON string.
Parameters
baseThe base of the serialized JSON.
byte_sizeThe size, in bytes, of the serialized message.
Returns
◆ TRITONSERVER_MessageSerializeToJson()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageSerializeToJson ( struct TRITONSERVER_Message *  message,
const char **  base,
size_t *  byte_size
Get the base and size of the buffer containing the serialized message in JSON format.
The buffer is owned by the TRITONSERVER_Message object and should not be modified or freed by the caller. The lifetime of the buffer extends only as long as 'message' and must not be accessed once 'message' is deleted.
Parameters
baseReturns the base of the serialized message.
byte_sizeReturns the size, in bytes, of the serialized message.
Returns
◆ TRITONSERVER_MetricArgsDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsDelete ( struct TRITONSERVER_MetricArgs *  args)
Parameters
argsThe metric args object.
Returns
◆ TRITONSERVER_MetricArgsNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsNew ( struct TRITONSERVER_MetricArgs **  args)
The caller takes ownership of the TRITONSERVER_MetricArgs object and must call TRITONSERVER_MetricArgsDelete to release the object.
Parameters
argsReturns the new metric args object.
Returns
◆ TRITONSERVER_MetricArgsSetHistogram()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsSetHistogram ( struct TRITONSERVER_MetricArgs *  args,
const double *  buckets,
Parameters
argsThe metric args object to set.
bucketsThe array of bucket boundaries for the expected range of observed values.
buckets_countThe number of bucket boundaries.
Returns
◆ TRITONSERVER_MetricDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricDelete ( struct TRITONSERVER_Metric *  metric)
All TRITONSERVER_Metric* objects should be deleted BEFORE their corresponding TRITONSERVER_MetricFamily* objects have been deleted. If a family is deleted before its metrics, an error will be returned.
Parameters
metricThe metric object to delete.
Returns
◆ TRITONSERVER_MetricFamilyDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricFamilyDelete ( struct TRITONSERVER_MetricFamily *  family)
A TRITONSERVER_MetricFamily* object should be deleted AFTER its corresponding TRITONSERVER_Metric* objects have been deleted. Attempting to delete a family before its metrics will return an error.
Parameters
familyThe metric family object to delete.
Returns
◆ TRITONSERVER_MetricFamilyNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricFamilyNew ( struct TRITONSERVER_MetricFamily **  family,
const char *  name,
const char *  description
The caller takes ownership of the TRITONSERVER_MetricFamily object and must call TRITONSERVER_MetricFamilyDelete to release the object.
Parameters
familyReturns the new metric family object.
kindThe type of metric family to create.
nameThe name of the metric family seen when calling the metrics endpoint.
descriptionThe description of the metric family seen when calling the metrics endpoint.
Returns
◆ TRITONSERVER_MetricIncrement()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricIncrement ( struct TRITONSERVER_Metric *  metric,
double  value
Supports metrics of kind TRITONSERVER_METRIC_KIND_GAUGE for any value, and TRITONSERVER_METRIC_KIND_COUNTER for non-negative values. Returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind and TRITONSERVER_ERROR_INVALID_ARG for negative values on a TRITONSERVER_METRIC_KIND_COUNTER metric.
Parameters
metricThe metric object to update.
valueThe amount to increment the metric's value by.
Returns
◆ TRITONSERVER_MetricNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricNew ( struct TRITONSERVER_Metric **  metric,
const struct TRITONSERVER_Parameter **  labels,
The caller takes ownership of the TRITONSERVER_Metric object and must call TRITONSERVER_MetricDelete to release the object. The caller is also responsible for ownership of the labels passed in. Each label can be deleted immediately after creating the metric with TRITONSERVER_ParameterDelete if not re-using the labels.
Parameters
metricReturns the new metric object.
familyThe metric family to add this new metric to.
labelsThe array of labels to associate with this new metric.
label_countThe number of labels.
Returns
◆ TRITONSERVER_MetricNewWithArgs()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricNewWithArgs ( struct TRITONSERVER_Metric **  metric,
const struct TRITONSERVER_MetricArgs *  args
The caller takes ownership of the TRITONSERVER_Metric object and must call TRITONSERVER_MetricDelete to release the object. The caller is also responsible for ownership of the labels passed in. Each label can be deleted immediately after creating the metric with TRITONSERVER_ParameterDelete if not re-using the labels. Metric args can be deleted immediately after creating the metric with TRITONSERVER_MetricArgsDelete if not re-using the metric args.
Parameters
argsMetric args that store additional arguments to construct particular metric types, e.g. histogram.
Returns
◆ TRITONSERVER_MetricObserve()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricObserve ( struct TRITONSERVER_Metric *  metric,
double  value
Supports metrics of kind TRITONSERVER_METRIC_KIND_HISTOGRAM and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
Parameters
valueThe amount for metric to sample observation.
Returns
◆ TRITONSERVER_MetricsDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricsDelete ( struct TRITONSERVER_Metrics *  metrics)
Delete a metrics object.
Parameters
metricsThe metrics object.
Returns
◆ TRITONSERVER_MetricSet()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricSet ( struct TRITONSERVER_Metric *  metric,
double  value
Supports metrics of kind TRITONSERVER_METRIC_KIND_GAUGE and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
Parameters
valueThe amount to set metric's value to.
Returns
◆ TRITONSERVER_MetricsFormatted()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricsFormatted ( struct TRITONSERVER_Metrics *  metrics,
TRITONSERVER_MetricFormat  format,
const char **  base,
size_t *  byte_size
Get a buffer containing the metrics in the specified format.
For each format the buffer contains the following:
TRITONSERVER_METRIC_PROMETHEUS: 'base' points to a single multiline string (char*) that gives a text representation of the metrics in prometheus format. 'byte_size' returns the length of the string in bytes.
The buffer is owned by the 'metrics' object and should not be modified or freed by the caller. The lifetime of the buffer extends only as long as 'metrics' and must not be accessed once 'metrics' is deleted.
Parameters
formatThe format to use for the returned metrics.
baseReturns a pointer to the base of the formatted metrics, as described above.
byte_sizeReturns the size, in bytes, of the formatted metrics.
Returns
◆ TRITONSERVER_MetricValue()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricValue ( struct TRITONSERVER_Metric *  metric,
double *  value
Get the current value of a metric object.
Supports metrics of kind TRITONSERVER_METRIC_KIND_COUNTER and TRITONSERVER_METRIC_KIND_GAUGE, and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
Parameters
valueReturns the current value of the metric object.
Returns
◆ TRITONSERVER_ParameterBytesNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter* TRITONSERVER_ParameterBytesNew ( const char *  name,
const void *  byte_ptr,
const uint64_t  size
Create a new parameter object with type TRITONSERVER_PARAMETER_BYTES.
The caller takes ownership of the TRITONSERVER_Parameter object and must call TRITONSERVER_ParameterDelete to release the object. The object only maintains a shallow copy of the 'byte_ptr' so the data content must be valid until the parameter object is deleted.
Parameters
nameThe parameter name.
byte_ptrThe pointer to the data content.
sizeThe size of the data content.
Returns
◆ TRITONSERVER_ParameterDelete()
TRITONSERVER_DECLSPEC void TRITONSERVER_ParameterDelete ( struct TRITONSERVER_Parameter *  parameter)
Delete an parameter object.
Parameters
parameterThe parameter object.
◆ TRITONSERVER_ParameterNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter* TRITONSERVER_ParameterNew ( const char *  name,
const TRITONSERVER_ParameterType  type,
const void *  value
Create a new parameter object.
The caller takes ownership of the TRITONSERVER_Parameter object and must call TRITONSERVER_ParameterDelete to release the object. The object will maintain its own copy of the 'value'
Parameters
typeThe parameter type.
valueThe pointer to the value.
Returns
A new TRITONSERVER_Parameter object. 'nullptr' will be returned if 'type' is 'TRITONSERVER_PARAMETER_BYTES'. The caller should use TRITONSERVER_ParameterBytesNew to create parameter with bytes type.
◆ TRITONSERVER_ParameterTypeString()
const TRITONSERVER_DECLSPEC char* TRITONSERVER_ParameterTypeString ( TRITONSERVER_ParameterType  paramtype)
Get the string representation of a parameter type.
Parameters
paramtypeThe parameter type.
Returns
The string representation of the parameter type.
◆ TRITONSERVER_ResponseAllocatorDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorDelete ( struct TRITONSERVER_ResponseAllocator *  allocator)
Delete a response allocator.
Parameters
allocatorThe response allocator object.
Returns
◆ TRITONSERVER_ResponseAllocatorNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorNew ( struct TRITONSERVER_ResponseAllocator **  allocator,
TRITONSERVER_ResponseAllocatorAllocFn_t  alloc_fn,
TRITONSERVER_ResponseAllocatorReleaseFn_t  release_fn,
TRITONSERVER_ResponseAllocatorStartFn_t  start_fn
Create a new response allocator object.
The response allocator object is used by Triton to allocate buffers to hold the output tensors in inference responses. Most models generate a single response for each inference request (TRITONSERVER_TXN_ONE_TO_ONE). For these models the order of callbacks will be:
TRITONSERVER_ServerInferAsync called
  • start_fn : optional (and typically not required)
  • alloc_fn : called once for each output tensor in response TRITONSERVER_InferenceResponseDelete called
  • release_fn: called once for each output tensor in response
For models that generate multiple responses for each inference request (TRITONSERVER_TXN_DECOUPLED), the start_fn callback can be used to determine sets of alloc_fn callbacks that belong to the same response:
  • start_fn
  • start_fn
  • alloc_fn : called once for each output tensor in response ... For each response, TRITONSERVER_InferenceResponseDelete called
  • release_fn: called once for each output tensor in the response
In all cases the start_fn, alloc_fn and release_fn callback functions must be thread-safe. Typically making these functions thread-safe does not require explicit locking. The recommended way to implement these functions is to have each inference request provide a 'response_allocator_userp' object that is unique to that request with TRITONSERVER_InferenceRequestSetResponseCallback. The callback functions then operate only on this unique state. Locking is required only when the callback function needs to access state that is shared across inference requests (for example, a common allocation pool).
Parameters
allocatorReturns the new response allocator object.
alloc_fnThe function to call to allocate buffers for result tensors.
release_fnThe function to call when the server no longer holds a reference to an allocated buffer.
start_fnThe function to call to indicate that the subsequent 'alloc_fn' calls are for a new response. This callback is optional (use nullptr to indicate that it should not be invoked).
Returns
◆ TRITONSERVER_ResponseAllocatorSetBufferAttributesFunction()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorSetBufferAttributesFunction ( struct TRITONSERVER_ResponseAllocator *  allocator,
TRITONSERVER_ResponseAllocatorBufferAttributesFn_t  buffer_attributes_fn
Set the buffer attributes function for a response allocator object.
The function will be called after alloc_fn to set the buffer attributes associated with the output buffer.
The thread-safy requirement for buffer_attributes_fn is the same as other allocator callbacks.
Parameters
buffer_attributes_fnThe function to call to get the buffer attributes information for an allocated buffer.
Returns
◆ TRITONSERVER_ResponseAllocatorSetQueryFunction()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorSetQueryFunction ( struct TRITONSERVER_ResponseAllocator *  allocator,
TRITONSERVER_ResponseAllocatorQueryFn_t  query_fn
Set the query function to a response allocator object.
Usually the function will be called before alloc_fn to understand what is the allocator's preferred memory type and memory type ID at the current situation to make different execution decision.
The thread-safy requirement for query_fn is the same as other allocator callbacks.
Parameters
query_fnThe function to call to query allocator's preferred memory type and memory type ID.
Returns
◆ TRITONSERVER_ServerDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerDelete ( struct TRITONSERVER_Server *  server)
Delete a server object.
If server is not already stopped it is stopped before being deleted.
Parameters
serverThe inference server object.
Returns
◆ TRITONSERVER_ServerInferAsync()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerInferAsync ( struct TRITONSERVER_Server *  server,
Perform inference using the meta-data and inputs supplied by the 'inference_request'.
If the function returns success, then the caller releases ownership of 'inference_request' and must not access it in any way after this call, until ownership is returned via the 'request_release_fn' callback registered in the request object with TRITONSERVER_InferenceRequestSetReleaseCallback.
The function unconditionally takes ownership of 'trace' and so the caller must not access it in any way after this call (except in the trace activity callbacks) until ownership is returned via the trace's release_fn callback.
Responses produced for this request are returned using the allocator and callback registered with the request by TRITONSERVER_InferenceRequestSetResponseCallback.
Parameters
traceThe trace object for this request, or nullptr if no tracing.
Returns
◆ TRITONSERVER_ServerIsLive()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerIsLive ( struct TRITONSERVER_Server *  server,
bool *  live
Is the server live?
Parameters
liveReturns true if server is live, false otherwise.
Returns
◆ TRITONSERVER_ServerIsReady()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerIsReady ( struct TRITONSERVER_Server *  server,
bool *  ready
Is the server ready?
Parameters
readyReturns true if server is ready, false otherwise.
Returns
◆ TRITONSERVER_ServerLoadModel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerLoadModel ( struct TRITONSERVER_Server *  server,
Load the requested model or reload the model if it is already loaded.
The function does not return until the model is loaded or fails to load. Returned error indicates if model loaded successfully or not.
Parameters
model_nameThe name of the model.
Returns
◆ TRITONSERVER_ServerLoadModelWithParameters()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerLoadModelWithParameters ( struct TRITONSERVER_Server *  server,
const struct TRITONSERVER_Parameter **  parameters,
const uint64_t  parameter_count
Load the requested model or reload the model if it is already loaded, with load parameters provided.
The function does not return until the model is loaded or fails to load. Returned error indicates if model loaded successfully or not. Currently the below parameter names are recognized:
  • "config" : string parameter that contains a JSON representation of the model configuration. This config will be used for loading the model instead of the one in the model directory.
Parameters
parametersThe array of load parameters.
parameter_countThe number of parameters.
Returns
◆ TRITONSERVER_ServerMetadata()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerMetadata ( struct TRITONSERVER_Server *  server,
struct TRITONSERVER_Message **  server_metadata
Get the metadata of the server as a TRITONSERVER_Message object.
The caller takes ownership of the message object and must call TRITONSERVER_MessageDelete to release the object.
Parameters
server_metadataReturns the server metadata message.
Returns
◆ TRITONSERVER_ServerMetrics()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerMetrics ( struct TRITONSERVER_Server *  server,
struct TRITONSERVER_Metrics **  metrics
Get the current metrics for the server.
The caller takes ownership of the metrics object and must call TRITONSERVER_MetricsDelete to release the object.
Parameters
metricsReturns the metrics.
Returns
◆ TRITONSERVER_ServerModelBatchProperties()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelBatchProperties ( struct TRITONSERVER_Server *  server,
const int64_t  model_version,
uint32_t *  flags,
void **  voidp
Get the batch properties of the model.
The properties are communicated by a flags value and an (optional) object returned by 'voidp'.
  • TRITONSERVER_BATCH_UNKNOWN: Triton cannot determine the batching properties of the model. This means that the model does not support batching in any way that is usable by Triton. The returned 'voidp' value is nullptr.
  • TRITONSERVER_BATCH_FIRST_DIM: The model supports batching along the first dimension of every input and output tensor. Triton schedulers that perform batching can automatically batch inference requests along this dimension. The returned 'voidp' value is nullptr.
Parameters
model_versionThe version of the model. If -1 then the server will choose a version based on the model's policy.
flagsReturns flags indicating the batch properties of the model.
voidpIf non-nullptr, returns a point specific to the 'flags' value.
Returns
◆ TRITONSERVER_ServerModelConfig()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelConfig ( struct TRITONSERVER_Server *  server,
const uint32_t  config_version,
struct TRITONSERVER_Message **  model_config
Get the configuration of a model as a TRITONSERVER_Message object.
Parameters
config_versionThe model configuration will be returned in a format matching this version. If the configuration cannot be represented in the requested version's format then an error will be returned. Currently only version 1 is supported.
model_configReturns the model config message.
Returns
◆ TRITONSERVER_ServerModelIndex()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelIndex ( struct TRITONSERVER_Server *  server,
uint32_t  flags,
struct TRITONSERVER_Message **  model_index
Get the index of all unique models in the model repositories as a TRITONSERVER_Message object.
If TRITONSERVER_INDEX_FLAG_READY is set in 'flags' only the models that are loaded into the server and ready for inferencing are returned.
Parameters
flagsTRITONSERVER_ModelIndexFlag flags that control how to collect the index.
model_indexReturn the model index message that holds the index of all models contained in the server's model repository(s).
Returns
◆ TRITONSERVER_ServerModelIsReady()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelIsReady ( struct TRITONSERVER_Server *  server,
bool *  ready
Is the model ready?
Parameters
model_nameThe name of the model to get readiness for.
model_versionThe version of the model to get readiness for. If -1 then the server will choose a version based on the model's policy.
Returns
◆ TRITONSERVER_ServerModelMetadata()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelMetadata ( struct TRITONSERVER_Server *  server,
struct TRITONSERVER_Message **  model_metadata
Get the metadata of a model as a TRITONSERVER_Message object.
Parameters
model_metadataReturns the model metadata message.
Returns
◆ TRITONSERVER_ServerModelStatistics()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelStatistics ( struct TRITONSERVER_Server *  server,
struct TRITONSERVER_Message **  model_stats
Get the statistics of a model as a TRITONSERVER_Message object.
The caller takes ownership of the object and must call TRITONSERVER_MessageDelete to release the object.
Parameters
model_nameThe name of the model. If empty, then statistics for all available models will be returned, and the server will choose a version based on those models' policies.
model_statsReturns the model statistics message.
Returns
◆ TRITONSERVER_ServerModelTransactionProperties()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelTransactionProperties ( struct TRITONSERVER_Server *  server,
uint32_t *  txn_flags,
void **  voidp
Get the transaction policy of the model.
The policy is communicated by a flags value.
  • TRITONSERVER_TXN_ONE_TO_ONE: The model generates exactly one response per request.
  • TRITONSERVER_TXN_DECOUPLED: The model may generate zero to many responses per request.
Parameters
txn_flagsReturns flags indicating the transaction policy of the model.
Returns
◆ TRITONSERVER_ServerNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerNew ( struct TRITONSERVER_Server **  server,
struct TRITONSERVER_ServerOptions *  options
Create a new server object.
The caller takes ownership of the TRITONSERVER_Server object and must call TRITONSERVER_ServerDelete to release the object.
Parameters
serverReturns the new inference server object.
optionsThe inference server options object.
Returns
◆ TRITONSERVER_ServerOptionsAddRateLimiterResource()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsAddRateLimiterResource ( struct TRITONSERVER_ServerOptions *  options,
const char *  resource_name,
const size_t  resource_count,
const int  device
Add resource count for rate limiting.
Parameters
optionsThe server options object.
nameThe name of the resource.
countThe count of the resource.
deviceThe device identifier for the resource. A value of -1 indicates that the specified number of resources are available on every device. The device value is ignored for a global resource. The server will use the rate limiter configuration specified for instance groups in model config to determine whether resource is global. In case of conflicting resource type in different model configurations, server will raise an appropriate error while loading model.
Returns
◆ TRITONSERVER_ServerOptionsDelete()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsDelete ( struct TRITONSERVER_ServerOptions *  options)
Delete a server options object.
Parameters
Returns
◆ TRITONSERVER_ServerOptionsNew()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsNew ( struct TRITONSERVER_ServerOptions **  options)
Create a new server options object.
The caller takes ownership of the TRITONSERVER_ServerOptions object and must call TRITONSERVER_ServerOptionsDelete to release the object.
Parameters
optionsReturns the new server options object.
Returns
◆ TRITONSERVER_ServerOptionsSetBackendConfig()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBackendConfig ( struct TRITONSERVER_ServerOptions *  options,
const char *  backend_name,
const char *  setting,
const char *  value
Set a configuration setting for a named backend in a server options.
Parameters
backend_nameThe name of the backend.
settingThe name of the setting.
valueThe setting value.
Returns
◆ TRITONSERVER_ServerOptionsSetBackendDirectory()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBackendDirectory ( struct TRITONSERVER_ServerOptions *  options,
const char *  backend_dir
Set the directory containing backend shared libraries.
This directory is searched last after the version and model directory in the model repository when looking for the backend shared library for a model. If the backend is named 'be' the directory searched is 'backend_dir'/be/libtriton_be.so.
Parameters
backend_dirThe full path of the backend directory.
Returns
◆ TRITONSERVER_ServerOptionsSetBufferManagerThreadCount()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBufferManagerThreadCount ( struct TRITONSERVER_ServerOptions *  options,
unsigned int  thread_count
Set the number of threads used in buffer manager in a server options.
Parameters
thread_countThe number of threads.
Returns
a TRITONSERVER_Error indicating success or failure.
◆ TRITONSERVER_ServerOptionsSetCacheConfig()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCacheConfig ( struct TRITONSERVER_ServerOptions *  options,
const char *  cache_name,
const char *  config_json
Set the cache config that will be used to initialize the cache implementation for "cache_name".
It is expected that the "cache_name" provided matches a directory inside the "cache_dir" used for TRITONSERVER_ServerOptionsSetCacheDirectory. The default "cache_dir" is "/opt/tritonserver/caches", so for a "cache_name" of "local", Triton would expect to find the "local" cache implementation at "/opt/tritonserver/caches/local/libtritoncache_local.so"
Altogether an example for the "local" cache implementation would look like: std::string cache_name = "local"; std::string config_json = R"({"size": 1048576})" auto err = TRITONSERVER_ServerOptionsSetCacheConfig( options, cache_name, config_json);
Parameters
cache_nameThe name of the cache. Example names would be "local", "redis", or the name of a custom cache implementation.
config_jsonThe string representation of config JSON that is used to initialize the cache implementation.
Returns
◆ TRITONSERVER_ServerOptionsSetCacheDirectory()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCacheDirectory ( struct TRITONSERVER_ServerOptions *  options,
const char *  cache_dir
Set the directory containing cache shared libraries.
This directory is searched when looking for cache implementations.
Parameters
cache_dirThe full path of the cache directory.
Returns
◆ TRITONSERVER_ServerOptionsSetCpuMetrics()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCpuMetrics ( struct TRITONSERVER_ServerOptions *  options,
bool  cpu_metrics
Enable or disable CPU metrics collection in a server options.
CPU metrics are collected if both this option and TRITONSERVER_ServerOptionsSetMetrics are true.
Parameters
cpu_metricsTrue to enable CPU metrics, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetCudaMemoryPoolByteSize()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCudaMemoryPoolByteSize ( struct TRITONSERVER_ServerOptions *  options,
int  gpu_device,
uint64_t  size
Set the total CUDA memory byte size that the server can allocate on given GPU device in a server options.
The pinned memory pool will be shared across Triton itself and the backends that use TRITONBACKEND_MemoryManager to allocate memory.
Parameters
gpu_deviceThe GPU device to allocate the memory pool.
sizeThe CUDA memory pool byte size.
Returns
◆ TRITONSERVER_ServerOptionsSetCudaVirtualAddressSize()
TRITONSERVER_DECLSPEC TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCudaVirtualAddressSize ( TRITONSERVER_ServerOptions *  options,
int  gpu_device,
size_t  cuda_virtual_address_size
Set the size of the virtual address space that will be used for growable memory in implicit state.
Parameters
gpu_deviceThe GPU device to set the CUDA virtual address space size
sizeThe size of the CUDA virtual address space.
Returns
◆ TRITONSERVER_ServerOptionsSetEnablePeerAccess()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetEnablePeerAccess ( struct TRITONSERVER_ServerOptions *  options,
bool  enable_peer_access
Enable peer access to allow GPU device to directly access the memory of another GPU device.
Note that even when this option is set to True, Triton will only try to enable peer access and might fail to enable it if the underlying system doesn't support peer access.
Parameters
enable_peer_accessWhether to enable peer access or not.
Returns
◆ TRITONSERVER_ServerOptionsSetExitOnError()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetExitOnError ( struct TRITONSERVER_ServerOptions *  options,
bool  exit
Enable or disable exit-on-error in a server options.
Parameters
exitTrue to enable exiting on initialization error, false to continue.
Returns
◆ TRITONSERVER_ServerOptionsSetExitTimeout()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetExitTimeout ( struct TRITONSERVER_ServerOptions *  options,
unsigned int  timeout
Set the exit timeout, in seconds, for the server in a server options.
Parameters
timeoutThe exit timeout, in seconds.
Returns
◆ TRITONSERVER_ServerOptionsSetGpuMetrics()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetGpuMetrics ( struct TRITONSERVER_ServerOptions *  options,
bool  gpu_metrics
Enable or disable GPU metrics collection in a server options.
GPU metrics are collected if both this option and TRITONSERVER_ServerOptionsSetMetrics are true.
Parameters
gpu_metricsTrue to enable GPU metrics, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetHostPolicy()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetHostPolicy ( struct TRITONSERVER_ServerOptions *  options,
const char *  policy_name,
const char *  value
Set a host policy setting for a given policy name in a server options.
Parameters
policy_nameThe name of the policy.
Returns
◆ TRITONSERVER_ServerOptionsSetLogError()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogError ( struct TRITONSERVER_ServerOptions *  options,
bool  log
Enable or disable error level logging.
Parameters
logTrue to enable error logging, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetLogFile()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogFile ( struct TRITONSERVER_ServerOptions *  options,
const char *  file
Provide a log output file.
Parameters
filea string defining the file where the log outputs will be saved. An empty string for the file name will cause triton to direct logging facilities to the console
Returns
◆ TRITONSERVER_ServerOptionsSetLogFormat()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogFormat ( struct TRITONSERVER_ServerOptions *  options,
const TRITONSERVER_LogFormat  format
Set the logging format.
Parameters
formatThe logging format.
Returns
◆ TRITONSERVER_ServerOptionsSetLogInfo()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogInfo ( struct TRITONSERVER_ServerOptions *  options,
bool  log
Enable or disable info level logging.
Parameters
logTrue to enable info logging, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetLogVerbose()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogVerbose ( struct TRITONSERVER_ServerOptions *  options,
int  level
Set verbose logging level.
Level zero disables verbose logging.
Parameters
levelThe verbose logging level.
Returns
◆ TRITONSERVER_ServerOptionsSetLogWarn()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogWarn ( struct TRITONSERVER_ServerOptions *  options,
bool  log
Enable or disable warning level logging.
Parameters
logTrue to enable warning logging, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetMetrics()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetrics ( struct TRITONSERVER_ServerOptions *  options,
bool  metrics
Enable or disable metrics collection in a server options.
Parameters
metricsTrue to enable metrics, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetMetricsConfig()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetricsConfig ( struct TRITONSERVER_ServerOptions *  options,
const char *  name,
const char *  value
Set a configuration setting for metrics in server options.
Parameters
nameThe name of the configuration group. An empty string indicates a global configuration option.
Returns
◆ TRITONSERVER_ServerOptionsSetMetricsInterval()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetricsInterval ( struct TRITONSERVER_ServerOptions *  options,
uint64_t  metrics_interval_ms
Set the interval for metrics collection in a server options.
This is 2000 milliseconds by default.
Parameters
metrics_interval_msThe time interval in ms between successive metrics updates.
Returns
◆ TRITONSERVER_ServerOptionsSetMinSupportedComputeCapability()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMinSupportedComputeCapability ( struct TRITONSERVER_ServerOptions *  options,
double  cc
Set the minimum support CUDA compute capability in a server options.
Parameters
ccThe minimum CUDA compute capability.
Returns
◆ TRITONSERVER_ServerOptionsSetModelConfigName()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelConfigName ( struct TRITONSERVER_ServerOptions *  options,
const char *  model_config_name
Set the custom model configuration name to load for all models.
Fall back to default config file if empty.
Parameters
config_nameThe name of the config file to load for all models.
Returns
◆ TRITONSERVER_ServerOptionsSetModelControlMode()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelControlMode ( struct TRITONSERVER_ServerOptions *  options,
TRITONSERVER_ModelControlMode  mode
Set the model control mode in a server options.
For each mode the models will be managed as the following:
TRITONSERVER_MODEL_CONTROL_NONE: the models in model repository will be loaded on startup. After startup any changes to the model repository will be ignored. Calling TRITONSERVER_ServerPollModelRepository will result in an error.
TRITONSERVER_MODEL_CONTROL_POLL: the models in model repository will be loaded on startup. The model repository can be polled periodically using TRITONSERVER_ServerPollModelRepository and the server will load, unload, and updated models according to changes in the model repository.
TRITONSERVER_MODEL_CONTROL_EXPLICIT: the models in model repository will not be loaded on startup. The corresponding model control APIs must be called to load / unload a model in the model repository.
Parameters
modeThe mode to use for the model control.
Returns
◆ TRITONSERVER_ServerOptionsSetModelLoadDeviceLimit()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadDeviceLimit ( struct TRITONSERVER_ServerOptions *  options,
const TRITONSERVER_InstanceGroupKind  kind,
const int  device_id,
const double  fraction
Specify the limit on memory usage as a fraction on the device identified by 'kind' and 'device_id'.
If model loading on the device is requested and the current memory usage exceeds the limit, the load will be rejected. If not specified, the limit will not be set.
Currently support TRITONSERVER_INSTANCEGROUPKIND_GPU
Parameters
kindThe kind of the device.
device_idThe id of the device.
fractionThe limit on memory usage as a fraction
Returns
◆ TRITONSERVER_ServerOptionsSetModelLoadRetryCount()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadRetryCount ( struct TRITONSERVER_ServerOptions *  options,
unsigned int  retry_count
Set the number of retry to load a model in a server options.
Parameters
retry_countThe number of retry.
Returns
◆ TRITONSERVER_ServerOptionsSetModelLoadThreadCount()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadThreadCount ( struct TRITONSERVER_ServerOptions *  options,
Set the number of threads to concurrently load models in a server options.
Parameters
Returns
◆ TRITONSERVER_ServerOptionsSetModelNamespacing()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelNamespacing ( struct TRITONSERVER_ServerOptions *  options,
bool  enable_namespace
Enable model namespacing to allow serving models with the same name if they are in different namespaces.
Parameters
enable_namespaceWhether to enable model namespacing or not.
Returns
◆ TRITONSERVER_ServerOptionsSetModelRepositoryPath()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelRepositoryPath ( struct TRITONSERVER_ServerOptions *  options,
const char *  model_repository_path
Set the model repository path in a server options.
The path must be the full absolute path to the model repository. This function can be called multiple times with different paths to set multiple model repositories. Note that if a model is not unique across all model repositories at any time, the model will not be available.
Parameters
model_repository_pathThe full path to the model repository.
Returns
◆ TRITONSERVER_ServerOptionsSetPinnedMemoryPoolByteSize()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetPinnedMemoryPoolByteSize ( struct TRITONSERVER_ServerOptions *  options,
uint64_t  size
Set the total pinned memory byte size that the server can allocate in a server options.
Parameters
sizeThe pinned memory pool byte size.
Returns
◆ TRITONSERVER_ServerOptionsSetRateLimiterMode()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetRateLimiterMode ( struct TRITONSERVER_ServerOptions *  options,
TRITONSERVER_RateLimitMode  mode
Set the rate limit mode in a server options.
TRITONSERVER_RATE_LIMIT_EXEC_COUNT: The rate limiting prioritizes the inference execution using the number of times each instance has got a chance to run. The execution gets to run only when its resource constraints are satisfied.
TRITONSERVER_RATE_LIMIT_OFF: The rate limiting is turned off and the inference gets executed whenever an instance is available.
Parameters
modeThe mode to use for the rate limiting. By default, execution count is used to determine the priorities.
Returns
◆ TRITONSERVER_ServerOptionsSetRepoAgentDirectory()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetRepoAgentDirectory ( struct TRITONSERVER_ServerOptions *  options,
const char *  repoagent_dir
Set the directory containing repository agent shared libraries.
This directory is searched when looking for the repository agent shared library for a model. If the repo agent is named 'ra' the directory searched is 'repoagent_dir'/ra/libtritonrepoagent_ra.so.
Parameters
repoagent_dirThe full path of the repository agent directory.
Returns
◆ TRITONSERVER_ServerOptionsSetResponseCacheByteSize()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetResponseCacheByteSize ( struct TRITONSERVER_ServerOptions *  options,
uint64_t  size
Deprecated.
See TRITONSERVER_ServerOptionsSetCacheConfig instead.
Set the total response cache byte size that the server can allocate in CPU memory. The response cache will be shared across all inference requests and across all models.
Parameters
sizeThe total response cache byte size.
Returns
◆ TRITONSERVER_ServerOptionsSetServerId()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetServerId ( struct TRITONSERVER_ServerOptions *  options,
const char *  server_id
Set the textual ID for the server in a server options.
The ID is a name that identifies the server.
Parameters
server_idThe server identifier.
Returns
◆ TRITONSERVER_ServerOptionsSetStartupModel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStartupModel ( struct TRITONSERVER_ServerOptions *  options,
const char *  model_name
Set the model to be loaded at startup in a server options.
The model must be present in one, and only one, of the specified model repositories. This function can be called multiple times with different model name to set multiple startup models. Note that it only takes affect on TRITONSERVER_MODEL_CONTROL_EXPLICIT mode.
Parameters
mode_nameThe name of the model to load on startup.
Returns
◆ TRITONSERVER_ServerOptionsSetStrictModelConfig()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStrictModelConfig ( struct TRITONSERVER_ServerOptions *  options,
bool  strict
Enable or disable strict model configuration handling in a server options.
Parameters
strictTrue to enable strict model configuration handling, false to disable.
Returns
◆ TRITONSERVER_ServerOptionsSetStrictReadiness()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStrictReadiness ( struct TRITONSERVER_ServerOptions *  options,
bool  strict
Enable or disable strict readiness handling in a server options.
Parameters
strictTrue to enable strict readiness handling, false to disable.
Returns
◆ TRITONSERVER_ServerPollModelRepository()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerPollModelRepository ( struct TRITONSERVER_Server *  server)
Check the model repository for changes and update server state based on those changes.
Parameters
Returns
◆ TRITONSERVER_ServerRegisterModelRepository()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerRegisterModelRepository ( struct TRITONSERVER_Server *  server,
const char *  repository_path,
const struct TRITONSERVER_Parameter **  name_mapping,
const uint32_t  mapping_count
Register a new model repository.
Not available in polling mode.
Parameters
name_mappingList of name_mapping parameters. Each mapping has the model directory name as its key, overridden model name as its value.
model_countNumber of mappings provided.
Returns
◆ TRITONSERVER_ServerSetExitTimeout()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerSetExitTimeout ( struct TRITONSERVER_Server *  server,
Set the exit timeout on the server object.
This value overrides the value initially set through server options and provides a mechanism to update the exit timeout while the serving is running.
Parameters
Returns
◆ TRITONSERVER_ServerStop()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerStop ( struct TRITONSERVER_Server *  server)
Stop a server object.
A server can't be restarted once it is stopped.
Parameters
Returns
◆ TRITONSERVER_ServerUnloadModel()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnloadModel ( struct TRITONSERVER_Server *  server,
Unload the requested model.
Unloading a model that is not loaded on server has no affect and success code will be returned. The function does not wait for the requested model to be fully unload and success code will be returned. Returned error indicates if model unloaded successfully or not.
Parameters
Returns
◆ TRITONSERVER_ServerUnloadModelAndDependents()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnloadModelAndDependents ( struct TRITONSERVER_Server *  server,
Unload the requested model, and also unload any dependent model that was loaded along with the requested model (for example, the models composing an ensemble).
Unloading a model that is not loaded on server has no affect and success code will be returned. The function does not wait for the requested model and all dependent models to be fully unload and success code will be returned. Returned error indicates if model unloaded successfully or not.
Parameters
Returns
◆ TRITONSERVER_ServerUnregisterModelRepository()
TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnregisterModelRepository ( struct TRITONSERVER_Server *  server,
Unregister a model repository.
Parameters
Returns
◆ TRITONSERVER_StringToDataType()
TRITONSERVER_DECLSPEC TRITONSERVER_DataType TRITONSERVER_StringToDataType ( const char *  dtype)
Get the Triton datatype corresponding to a string representation of a datatype.
Parameters
dtypeThe datatype string representation.
Returns
The Triton data type or TRITONSERVER_TYPE_INVALID if the string does not represent a data type.
