7.1 Release
INFER_EXPORT_API::GuardQueue< Container > Class Template Reference
template<typename Container>
class INFER_EXPORT_API::GuardQueue< Container >
Template class for creating a thread safe queue for the given container class.
Template Parameters
ContainerThe container class for the queue, e.g. std::queue, std::list.
Definition at line 203 of file infer_utils.h.
Inheritance diagram for INFER_EXPORT_API::GuardQueue< Container >:
Public Types
typedef Container::value_type T
Public Member Functions
void push (T data)
 Push an item to the queue. More...
T pop ()
 Pop an item from the queue. More...
void wakeupOnce ()
 Send the wakeup trigger to the queue thread. More...
void clear ()
 Clear the queue. More...
int size ()
 Current size of the queue. More...
Member Typedef Documentation
◆ T
template<typename Container >
typedef Container::value_type INFER_EXPORT_API::GuardQueue< Container >::T
Definition at line 205 of file infer_utils.h.
Member Function Documentation
◆ clear()
void INFER_EXPORT_API::GuardQueue< Container >::clear ( )
inline
Clear the queue.
Definition at line 246 of file infer_utils.h.
◆ pop()
T INFER_EXPORT_API::GuardQueue< Container >::pop ( )
inline
Blocking call. Returns when there is an item in queue or on wakeup trigger. Throws exception on wakeup trigger.
Definition at line 220 of file infer_utils.h.
◆ push()
void INFER_EXPORT_API::GuardQueue< Container >::push ( T  data)
inline
Definition at line 209 of file infer_utils.h.
◆ size()
int INFER_EXPORT_API::GuardQueue< Container >::size ( )
inline
Definition at line 255 of file infer_utils.h.
◆ wakeupOnce()
void INFER_EXPORT_API::GuardQueue< Container >::wakeupOnce ( )
inline
Definition at line 237 of file infer_utils.h.
