deepstream::Buffer Class Reference
Base class of a buffer.
Buffer is the fundamental wrapper of data and metadata trunks that flows through the pipeline. Buffer is reference based and supports copying and moving, however both copying and moving only affects the reference and never transfers the data.
Definition at line 46 of file service-maker/includes/buffer.hpp.
Inheritance diagram for deepstream::Buffer:
Data Structures
struct  _Latency
 Unified definition of latency for a buffer. More...
Public Types
typedef struct deepstream::Buffer::_Latency Latency
using FreeFunction = void(*)(void *)
 Signature of customized function for freeing data in a buffer. More...
Public Member Functions
 Buffer ()
 empty buffer constructor More...
 Buffer (size_t length, void *data=nullptr, FreeFunction=nullptr)
 New buffer constructor. More...
 Buffer (const std::vector< uint8_t >)
 New Buffer constructor. More...
 Buffer (OpaqueBuffer *buffer)
 New buffer constructor for OpaqueBuffer. More...
 Buffer (const Buffer &)
 Copy constructor. More...
 Buffer (Buffer &&)
 Move constructor. More...
Bufferoperator= (const Buffer &)
 Copy assignment. More...
Bufferoperator= (Buffer &&)
 Move assignment. More...
virtual ~Buffer ()
 Destructor. More...
 operator bool () const
 If the buffer is null. More...
size_t size () const
 Size of the buffer in bytes. More...
uint64_t timestamp () const
 Timestamp of the buffer. More...
int32_t chunkId (unsigned int batchId) const
 Chunk id of the buffer. More...
std::vector< LatencymeasureLatency () const
 Return latency data of the buffer. More...
virtual size_t read (std::function< size_t(const void *data, size_t len)> callable)
 Read data from the buffer. More...
virtual size_t write (std::function< size_t(void *data, size_t len)> callable)
 Write data to the buffer. More...
OpaqueBuffergive ()
 Give up the ownership of this buffer and return the opaque buffer pointer. More...
virtual size_t batchSize ()
 get the batch size of the buffer, 1 for un-batched buffer More...
virtual Tensorextract (unsigned int batchId)
 create a tensor object with the buffer data More...
 Buffer ()
 Buffer (Buffer &&)
virtual ~Buffer ()
 Destructor. More...
OpaqueBuffergive ()
static void wrap (Tensor *)
 wrap the tensor to a new buffer More...
Protected Attributes
OpaqueBufferbuffer_
 opaque buffer pointer More...
std::vector< int > chunk_ids_ = { 0 }
 chunk ids, optional More...
Member Typedef Documentation
◆ FreeFunction [1/2]
using deepstream::Buffer::FreeFunction = void(*)(void*)
Definition at line 59 of file service-maker/includes/buffer.hpp.
◆ FreeFunction [2/2]
Definition at line 59 of file 9.0/service-maker/includes/buffer.hpp.
◆ Latency [1/2]
◆ Latency [2/2]
◆ Buffer() [1/12]
deepstream::Buffer::Buffer ( )
◆ Buffer() [2/12]
deepstream::Buffer::Buffer ( size_t  length,
void *  data = nullptr,
FreeFunction  = nullptr
Create a new buffer with given size. User can choose pass a raw data pointer or request the default allocation.
Parameters
[in]lengthnumber of bytes used by the buffer
[in]dataif set null, default allocation will be used, otherwise, the buffer will take and own the provided pointer.
◆ Buffer() [3/12]
deepstream::Buffer::Buffer ( const std::vector< uint8_t >  )
Create a new buffer from a byte vector, used by python mostly
Parameters
[in]bytesbyte vector
◆ Buffer() [4/12]
deepstream::Buffer::Buffer ( OpaqueBuffer buffer)
Create a new buffer from a OpaqueBuffer, for professionals who understands how Buffer Wrapper works
Parameters
[in]bufferpointer to a OpaqueBuffer
◆ Buffer() [5/12]
deepstream::Buffer::Buffer ( const Buffer )
Copy constructor.
◆ Buffer() [6/12]
deepstream::Buffer::Buffer ( Buffer &&  )
Move constructor.
◆ ~Buffer() [1/2]
virtual deepstream::Buffer::~Buffer ( )
virtual
Destructor.
◆ Buffer() [7/12]
◆ Buffer() [8/12]
Parameters
◆ Buffer() [9/12]
Parameters
◆ Buffer() [10/12]
Parameters
◆ Buffer() [11/12]
Copy constructor.
◆ Buffer() [12/12]
Move constructor.
◆ ~Buffer() [2/2]
virtual
Destructor.
Member Function Documentation
◆ batchSize() [1/2]
virtual size_t deepstream::Buffer::batchSize ( )
virtual
◆ batchSize() [2/2]
virtual
◆ chunkId() [1/2]
int32_t deepstream::Buffer::chunkId ( unsigned int  batchId) const
◆ chunkId() [2/2]
◆ extract() [1/2]
virtual Tensor* deepstream::Buffer::extract ( unsigned int  batchId)
virtual
◆ extract() [2/2]
virtual
◆ give() [1/2]
OpaqueBuffer* deepstream::Buffer::give ( )
Referenced by deepstream::EnsembleRender::consume().
◆ give() [2/2]
◆ measureLatency() [1/2]
std::vector<Latency> deepstream::Buffer::measureLatency ( ) const
◆ measureLatency() [2/2]
Referenced by deepstream::NvDsMeasureLatency::handleBuffer().
◆ operator bool() [1/2]
deepstream::Buffer::operator bool ( ) const
◆ operator bool() [2/2]
◆ operator=() [1/4]
Buffer& deepstream::Buffer::operator= ( Buffer &&  )
Move assignment.
◆ operator=() [2/4]
Move assignment.
◆ operator=() [3/4]
Buffer& deepstream::Buffer::operator= ( const Buffer )
Copy assignment.
◆ operator=() [4/4]
Copy assignment.
◆ read() [1/2]
virtual size_t deepstream::Buffer::read ( std::function< size_t(const void *data, size_t len)>  callable)
virtual
Parameters
[in]callablecallable provided by the caller to collect data
Reimplemented in deepstream::VideoBuffer, and deepstream::VideoBuffer.
◆ read() [2/2]
virtual
Parameters
◆ size() [1/2]
size_t deepstream::Buffer::size ( ) const
◆ size() [2/2]
◆ timestamp() [1/2]
uint64_t deepstream::Buffer::timestamp ( ) const
◆ timestamp() [2/2]
◆ wrap() [1/2]
static void deepstream::Buffer::wrap ( Tensor )
static
◆ wrap() [2/2]
static
◆ write() [1/2]
virtual size_t deepstream::Buffer::write ( std::function< size_t(void *data, size_t len)>  callable)
virtual
Parameters
[in]callablecallable provided by the caller to inject data
Referenced by deepstream::FileDataSource::read().
◆ write() [2/2]
virtual
Parameters
Field Documentation
◆ buffer_
OpaqueBuffer * deepstream::Buffer::buffer_
protected
Definition at line 164 of file service-maker/includes/buffer.hpp.
Referenced by deepstream::DS3DBuffer::DS3DBuffer().
◆ chunk_ids_
std::vector< int > deepstream::Buffer::chunk_ids_ = { 0 }
protected
chunk ids, optional
Definition at line 166 of file service-maker/includes/buffer.hpp.
