deepstream::SourceConfig Class Reference
Definition at line 56 of file service-maker/includes/source_config.hpp.
Public Member Functions
 SourceConfig (const std::string &config_file)
 Create a source config from a yaml config file. More...
uint32_t nSources () const
 Get the number of the sources. More...
uint32_t nCameraSources () const
 Get the number of the camera sources. More...
std::string listSensorIds () const
 List sensor ids in a string, separated by ';'. More...
std::string listSensorNames () const
 List sensor names in a string, separated by ';'. More...
std::string listUris () const
 List sensor uris in a string, separated by ';'. More...
SensorInfo getSensorInfo (uint32_t index) const
 Get sensor information for a specific source. More...
CameraInfo getCameraInfo (uint32_t index) const
 Get information for a specific camera source. More...
const YAML::Node & getProperties () const
 Get properties for setting the source bin(s) More...
bool useMultiUriSrcBin () const
 If using the nvmultiurisrcbin. More...
bool useUriSrcBin () const
 If using the nvurisrcbin. More...
bool useCameraBin () const
 If using the nvv4l2srcbin. More...
Protected Attributes
std::vector< SensorInfosensor_info_
std::vector< CameraInfocamera_info_
YAML::Node properties_
bool use_nvmultiurisrcbin_ = false
bool use_nvurisrcbin_ = false
bool use_camerabin_ = false
◆ SourceConfig() [1/2]
deepstream::SourceConfig::SourceConfig ( const std::string &  config_file)
◆ SourceConfig() [2/2]
Member Function Documentation
◆ getCameraInfo() [1/2]
CameraInfo deepstream::SourceConfig::getCameraInfo ( uint32_t  index) const
◆ getCameraInfo() [2/2]
◆ getProperties() [1/2]
const YAML::Node& deepstream::SourceConfig::getProperties ( ) const
◆ getProperties() [2/2]
◆ getSensorInfo() [1/2]
SensorInfo deepstream::SourceConfig::getSensorInfo ( uint32_t  index) const
◆ getSensorInfo() [2/2]
Referenced by deepstream::MsgMetaGenerator::handleData().
◆ listSensorIds() [1/2]
std::string deepstream::SourceConfig::listSensorIds ( ) const
◆ listSensorIds() [2/2]
◆ listSensorNames() [1/2]
std::string deepstream::SourceConfig::listSensorNames ( ) const
◆ listSensorNames() [2/2]
◆ listUris() [1/2]
std::string deepstream::SourceConfig::listUris ( ) const
◆ listUris() [2/2]
◆ nCameraSources() [1/2]
uint32_t deepstream::SourceConfig::nCameraSources ( ) const
◆ nCameraSources() [2/2]
◆ nSources() [1/2]
uint32_t deepstream::SourceConfig::nSources ( ) const
◆ nSources() [2/2]
◆ useCameraBin() [1/2]
bool deepstream::SourceConfig::useCameraBin ( ) const
◆ useCameraBin() [2/2]
◆ useMultiUriSrcBin() [1/2]
bool deepstream::SourceConfig::useMultiUriSrcBin ( ) const
◆ useMultiUriSrcBin() [2/2]
◆ useUriSrcBin() [1/2]
bool deepstream::SourceConfig::useUriSrcBin ( ) const
◆ useUriSrcBin() [2/2]
Field Documentation
◆ camera_info_
std::vector< CameraInfo > deepstream::SourceConfig::camera_info_
protected
Definition at line 120 of file service-maker/includes/source_config.hpp.
◆ properties_
YAML::Node deepstream::SourceConfig::properties_
protected
Definition at line 121 of file service-maker/includes/source_config.hpp.
◆ sensor_info_
std::vector< SensorInfo > deepstream::SourceConfig::sensor_info_
protected
Definition at line 119 of file service-maker/includes/source_config.hpp.
◆ use_camerabin_
bool deepstream::SourceConfig::use_camerabin_ = false
protected
Definition at line 124 of file service-maker/includes/source_config.hpp.
◆ use_nvmultiurisrcbin_
bool deepstream::SourceConfig::use_nvmultiurisrcbin_ = false
protected
Definition at line 122 of file service-maker/includes/source_config.hpp.
◆ use_nvurisrcbin_
bool deepstream::SourceConfig::use_nvurisrcbin_ = false
protected
Definition at line 123 of file service-maker/includes/source_config.hpp.
