ds3d::GuardDataLoader Class Reference
GuardDataLoader is the safe access entry for abiDataLoader.
Applications can use it to make C-based APIs safer. it would manage abiRefDataLoader automatically. with that, App user do not need to refCopy_i or destroy abiRefDataLoader manually.
For example: abiRefDataLoader* rawRefLoader = creator(); GuardDataLoader guardLoader(rawRefLoader, true); // take the ownership of rawRefLoader guardLoader.setUserData(userdata, [](void*){ ...free... }); guardLoader.setErrorCallback([](ErrCode c, const char* msg){ stderr << msg; }); ErrCode c = guardLoader.start(config, path); DS_ASSERT(isGood(c)); c = guardLoader.start(config, path); // invoke abiDataLoader::start_i(...) GuardDataMap data; c = guardLoader.read(data); // invoke abiDataLoader::read_i(...) DS_ASSERT(isGood(c)); DS_ASSERT(data); ... // access data c = guardLoader.stop(); // invoke abiDataLoader::stop_i(...) guardLoader.reset(); // destroy abiRefDataLoader, when all reference // destroyed, abiDataLoader would be freed.
Definition at line 46 of file sources/includes/ds3d/common/hpp/dataloader.hpp.
Inheritance diagram for ds3d::GuardDataLoader:
Collaboration diagram for ds3d::GuardDataLoader:
Public Types
using abiRefType = abiRefT< abiDataLoader >
Public Member Functions
template<typename... Args>
 GuardDataLoader (Args &&... args)
 ~GuardDataLoader ()=default
std::string getOutputCaps ()
ErrCode readData (GuardDataMap &datamap)
ErrCode readDataAsync (abiOnDataCB::CppFunc dataReadyCB)
void setUserData (void *data, DelF delF)
virtual void * getUserData () const
void setErrorCallback (abiErrorCB::CppFunc errCb)
ErrCode start (const std::string &content, const std::string &path="")
ErrCode flush ()
ErrCode flush ()
ErrCode stop ()
ErrCode stop ()
State state () const
std::string getCaps (CapsPort port)
std::string getInputCaps ()
GuardTy cast ()
GuardTy cast ()
abiDataLoaderptr () const
abiDataLoaderoperator-> () const
 operator bool () const
 operator ShrdPtr< abiDataLoader > ()
abiRefT< abiDataLoader > * release ()
void reset (abiRefT< abiDataLoader > *abiref=nullptr)
abiRefT< abiDataLoader > * abiRef () const
Member Typedef Documentation
◆ abiRefType [1/2]
◆ abiRefType [2/2]
◆ GuardDataLoader() [1/2]
ds3d::GuardDataLoader::GuardDataLoader ( Args &&...  args)
inline
◆ ~GuardDataLoader() [1/2]
ds3d::GuardDataLoader::~GuardDataLoader ( )
default
◆ GuardDataLoader() [2/2]
inline
◆ ~GuardDataLoader() [2/2]
default
Member Function Documentation
◆ abiRef() [1/2]
abiRefT< abiDataLoader > * ds3d::GuardRef< abiRefT< abiDataLoader > , >::abiRef
inlineinherited
Definition at line 269 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ abiRef() [2/2]
inlineinherited
◆ cast() [1/2]
GuardTy ds3d::GuardDataT< abiDataLoader >::cast
inlineinherited
Definition at line 356 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ cast() [2/2]
inlineinherited
◆ flush() [1/2]
◆ flush() [2/2]
ErrCode ds3d::GuardDataProcess< abiDataLoader , >::flush
inlineinherited
◆ getCaps() [1/2]
std::string ds3d::GuardDataProcess< abiDataLoader , >::getCaps ( CapsPort  port)
inlineinherited
◆ getCaps() [2/2]
inlineinherited
◆ getInputCaps() [1/2]
std::string ds3d::GuardDataProcess< abiDataLoader , >::getInputCaps
inlineinherited
◆ getInputCaps() [2/2]
inlineinherited
◆ getOutputCaps() [1/2]
std::string ds3d::GuardDataLoader::getOutputCaps ( )
inline
◆ getOutputCaps() [2/2]
inline
◆ getUserData() [1/2]
virtual void* ds3d::GuardDataProcess< abiDataLoader , >::getUserData
inlinevirtualinherited
◆ getUserData() [2/2]
◆ operator bool() [1/2]
ds3d::GuardDataT< abiDataLoader >::operator bool
inlineinherited
◆ operator bool() [2/2]
inlineinherited
Definition at line 370 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ operator ShrdPtr< abiDataLoader >() [1/2]
ds3d::GuardDataT< abiDataLoader >::operator ShrdPtr< abiDataLoader >
inlineinherited
Definition at line 372 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ operator ShrdPtr< abiDataLoader >() [2/2]
inlineinherited
◆ operator->() [1/2]
abiDataLoader * ds3d::GuardDataT< abiDataLoader >::operator->
inlineinherited
◆ operator->() [2/2]
inlineinherited
Definition at line 368 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ ptr() [1/2]
abiDataLoader * ds3d::GuardDataT< abiDataLoader >::ptr
inlineinherited
Definition at line 361 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ ptr() [2/2]
inlineinherited
◆ readData() [1/2]
◆ readData() [2/2]
◆ readDataAsync() [1/2]
◆ readDataAsync() [2/2]
◆ release() [1/2]
abiRefT< abiDataLoader > * ds3d::GuardRef< abiRefT< abiDataLoader > , >::release
inlineinherited
◆ release() [2/2]
inlineinherited
Definition at line 253 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ reset() [1/2]
void ds3d::GuardRef< abiRefT< abiDataLoader > , >::reset ( abiRefT< abiDataLoader > *  abiref = nullptr)
inlineinherited
Definition at line 260 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ reset() [2/2]
inlineinherited
◆ setErrorCallback() [1/2]
void ds3d::GuardDataProcess< abiDataLoader , >::setErrorCallback ( abiErrorCB::CppFunc  errCb)
inlineinherited
◆ setErrorCallback() [2/2]
inlineinherited
◆ setUserData() [1/2]
void ds3d::GuardDataProcess< abiDataLoader , >::setUserData ( void *  data,
DelF  delF
inlineinherited
◆ setUserData() [2/2]
DelF  delF
inlineinherited
◆ start() [1/2]
ErrCode ds3d::GuardDataProcess< abiDataLoader , >::start ( const std::string &  content,
const std::string &  path = ""
inlineinherited
◆ start() [2/2]
inlineinherited
◆ state() [1/2]
◆ state() [2/2]
State ds3d::GuardDataProcess< abiDataLoader , >::state
inlineinherited
◆ stop() [1/2]
◆ stop() [2/2]
