8.0 Release
ds3d::GuardDataRender Class Reference
GuardDataRender is the safe access entry for abiDataRender.
Applications can use it to make C-based APIs safer. it would manage abiRefDataRender automatically. with that, App user do not need to refCopy_i or destroy abiRefDataRender manually.
For example: abiRefDataRender* rawRefRender = createRender(); GuardDataRender guardRender(rawRefRender, true); // take the ownership of rawRefRender guardRender.setUserData(userdata, [](void*){ ...free... }); guardRender.setErrorCallback([](ErrCode c, const char* msg){ stderr << msg; }); ErrCode c = guardRender.start(config, path); DS_ASSERT(isGood(c)); c = guardRender.start(config, path); // invoke abiDataRender::start_i(...) GuardDataMap data = ...; c = guardRender.preroll(data); // invoke abiDataRender::preroll_i(...) DS_ASSERT(isGood(c)); // invoke abiDataRender::render_i(...) c = guardRender.render(data, [](ErrCode c, const abiRefDataMap* d){ GuardDataMap doneData(*d); // check ErrCode and data. }); DS_ASSERT(isGood(c)); c = guardRender.flush(); // flush all data in queue c = guardRender.stop(); // invoke abiDataRender::stop_i(...) guardRender.reset(); // destroy abiRefDataRender, when all reference // destroyed, abiDataRender would be freed.
Definition at line 53 of file sources/includes/ds3d/common/hpp/datarender.hpp.
Inheritance diagram for ds3d::GuardDataRender:
Collaboration diagram for ds3d::GuardDataRender:
Public Types
using abiRefType = abiRefT< abiDataRender >
Public Member Functions
template<typename... Args>
 GuardDataRender (Args &&... args)
 ~GuardDataRender ()=default
ErrCode preroll (GuardDataMap datamap)
ErrCode render (GuardDataMap datamap, abiOnDataCB::CppFunc dataDoneCB)
GuardWindow getWindow () const
void setUserData (void *data, DelF delF)
virtual void * getUserData () const
void setErrorCallback (abiErrorCB::CppFunc errCb)
ErrCode start (const std::string &content, const std::string &path="")
ErrCode flush ()
ErrCode flush ()
ErrCode stop ()
ErrCode stop ()
State state () const
std::string getCaps (CapsPort port)
std::string getOutputCaps ()
std::string getInputCaps ()
GuardTy cast ()
GuardTy cast ()
abiDataRenderptr () const
abiDataRenderoperator-> () const
 operator bool () const
 operator ShrdPtr< abiDataRender > ()
abiRefT< abiDataRender > * release ()
void reset (abiRefT< abiDataRender > *abiref=nullptr)
abiRefT< abiDataRender > * abiRef () const
Member Typedef Documentation
◆ abiRefType [1/2]
◆ abiRefType [2/2]
◆ GuardDataRender() [1/2]
ds3d::GuardDataRender::GuardDataRender ( Args &&...  args)
inline
◆ ~GuardDataRender() [1/2]
ds3d::GuardDataRender::~GuardDataRender ( )
default
◆ GuardDataRender() [2/2]
inline
◆ ~GuardDataRender() [2/2]
default
Member Function Documentation
◆ abiRef() [1/2]
abiRefT< abiDataRender > * ds3d::GuardRef< abiRefT< abiDataRender > , >::abiRef
inlineinherited
Definition at line 269 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ abiRef() [2/2]
inlineinherited
◆ cast() [1/2]
GuardTy ds3d::GuardDataT< abiDataRender >::cast
inlineinherited
Definition at line 356 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ cast() [2/2]
inlineinherited
◆ flush() [1/2]
◆ flush() [2/2]
ErrCode ds3d::GuardDataProcess< abiDataRender , >::flush
inlineinherited
◆ getCaps() [1/2]
std::string ds3d::GuardDataProcess< abiDataRender , >::getCaps ( CapsPort  port)
inlineinherited
◆ getCaps() [2/2]
inlineinherited
◆ getInputCaps() [1/2]
std::string ds3d::GuardDataProcess< abiDataRender , >::getInputCaps
inlineinherited
◆ getInputCaps() [2/2]
inlineinherited
◆ getOutputCaps() [1/2]
std::string ds3d::GuardDataProcess< abiDataRender , >::getOutputCaps
inlineinherited
◆ getOutputCaps() [2/2]
inlineinherited
◆ getUserData() [1/2]
virtual void* ds3d::GuardDataProcess< abiDataRender , >::getUserData
inlinevirtualinherited
◆ getUserData() [2/2]
◆ getWindow() [1/2]
GuardWindow ds3d::GuardDataRender::getWindow ( ) const
inline
◆ getWindow() [2/2]
inline
◆ operator bool() [1/2]
ds3d::GuardDataT< abiDataRender >::operator bool
inlineinherited
Definition at line 370 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ operator bool() [2/2]
inlineinherited
◆ operator ShrdPtr< abiDataRender >() [1/2]
ds3d::GuardDataT< abiDataRender >::operator ShrdPtr< abiDataRender >
inlineinherited
◆ operator ShrdPtr< abiDataRender >() [2/2]
inlineinherited
Definition at line 372 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ operator->() [1/2]
abiDataRender * ds3d::GuardDataT< abiDataRender >::operator->
inlineinherited
◆ operator->() [2/2]
inlineinherited
Definition at line 368 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ preroll() [1/2]
◆ preroll() [2/2]
◆ ptr() [1/2]
abiDataRender * ds3d::GuardDataT< abiDataRender >::ptr
inlineinherited
◆ ptr() [2/2]
inlineinherited
Definition at line 361 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ release() [1/2]
abiRefT< abiDataRender > * ds3d::GuardRef< abiRefT< abiDataRender > , >::release
inlineinherited
Definition at line 253 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ release() [2/2]
inlineinherited
◆ render() [1/2]
◆ render() [2/2]
◆ reset() [1/2]
void ds3d::GuardRef< abiRefT< abiDataRender > , >::reset ( abiRefT< abiDataRender > *  abiref = nullptr)
inlineinherited
Definition at line 260 of file sources/includes/ds3d/common/hpp/obj.hpp.
◆ reset() [2/2]
inlineinherited
◆ setErrorCallback() [1/2]
void ds3d::GuardDataProcess< abiDataRender , >::setErrorCallback ( abiErrorCB::CppFunc  errCb)
inlineinherited
◆ setErrorCallback() [2/2]
inlineinherited
◆ setUserData() [1/2]
void ds3d::GuardDataProcess< abiDataRender , >::setUserData ( void *  data,
DelF  delF
inlineinherited
◆ setUserData() [2/2]
DelF  delF
inlineinherited
◆ start() [1/2]
ErrCode ds3d::GuardDataProcess< abiDataRender , >::start ( const std::string &  content,
const std::string &  path = ""
inlineinherited
◆ start() [2/2]
inlineinherited
◆ state() [1/2]
State ds3d::GuardDataProcess< abiDataRender , >::state
inlineinherited
◆ state() [2/2]
◆ stop() [1/2]
◆ stop() [2/2]
