8.0 Release
ds3d::impl::BaseImplDataBridge Class Referenceabstract
Any custom datafilter must derive from BaseImplDataBridge,.
For custom lib implementation, user need to implement the following virtual functions: startImpl(...), // user also need setCaps(port) in startImpl stopImpl(), // stop all resources for datafilter prepollImpl(data), // prepoll on 1st coming data renderImpl(data, dataConsumedCb), // rendering data. Once data is done, invoke dataConsumedCb(datamap) callback to notify application flushImpl(), // flush data in process
Definition at line 34 of file sources/includes/ds3d/common/impl/impl_databridge.h.
Inheritance diagram for ds3d::impl::BaseImplDataBridge:
Collaboration diagram for ds3d::impl::BaseImplDataBridge:
Public Types
using OnGuardDataCBImpl = std::function< void(ErrCode, GuardDataMap)>
using OnGuardBridgeDataCBImpl = std::function< void(ErrCode, const struct VideoBridge2dInput *)>
using ImplMutex = std::recursive_mutex
Public Member Functions
 BaseImplDataBridge ()
 ~BaseImplDataBridge () override=default
ErrCode process_i (const struct VideoBridge2dInput *inputData, const abiOnDataCB *outputDataCb, const abiOnBridgeDataCB *inputDataConsumedCb) final
void setUserData_i (const abiRefAny *userdata) final
const abiRefAnygetUserData_i () const final
virtual const abiRefAnygetUserData_i () const =0
void setErrorCallback_i (const abiErrorCB &cb) final
ErrCode start_i (const char *configStr, uint32_t strLen, const char *path) override
const char * getCaps_i (CapsPort p) const final
ErrCode flush_i () override
ErrCode stop_i () override
State state_i () const final
virtual State state_i () const =0
Protected Member Functions
virtual ErrCode processImpl (const struct VideoBridge2dInput *inputData, OnGuardDataCBImpl outputDataCb, OnGuardBridgeDataCBImpl inputConsumedCb)=0
virtual ErrCode startImpl (const std::string &content, const std::string &path)=0
virtual ErrCode stopImpl ()=0
virtual ErrCode flushImpl ()=0
void setOutputCaps (const std::string &caps)
void setInputCaps (const std::string &caps)
void emitError (ErrCode code, const std::string &msg)
State getStateSafe () const
void setStateSafe (State flag)
ImplMutexmutex () const
Member Typedef Documentation
◆ ImplMutex [1/2]
using ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::ImplMutex = std::recursive_mutex
inherited
◆ ImplMutex [2/2]
inherited
◆ OnGuardBridgeDataCBImpl [1/2]
◆ OnGuardBridgeDataCBImpl [2/2]
◆ OnGuardDataCBImpl [1/2]
◆ OnGuardDataCBImpl [2/2]
◆ BaseImplDataBridge() [1/2]
ds3d::impl::BaseImplDataBridge::BaseImplDataBridge ( )
inline
◆ ~BaseImplDataBridge() [1/2]
ds3d::impl::BaseImplDataBridge::~BaseImplDataBridge ( )
overridedefault
◆ BaseImplDataBridge() [2/2]
inline
◆ ~BaseImplDataBridge() [2/2]
overridedefault
Member Function Documentation
◆ emitError() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::emitError ( ErrCode  code,
const std::string &  msg
inlineprotectedinherited
◆ emitError() [2/2]
◆ flush_i() [1/2]
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::flush_i
inlineoverridevirtualinherited
◆ flush_i() [2/2]
◆ flushImpl() [1/2]
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::flushImpl
protectedpure virtualinherited
◆ flushImpl() [2/2]
◆ getCaps_i() [1/2]
const char* ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::getCaps_i ( CapsPort  p) const
inlinefinalvirtualinherited
◆ getCaps_i() [2/2]
◆ getStateSafe() [1/2]
State ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::getStateSafe
◆ getStateSafe() [2/2]
◆ getUserData_i() [1/3]
virtual const abiRefAny* ds3d::abiProcess::getUserData_i ( ) const
◆ getUserData_i() [2/3]
const abiRefAny* ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::getUserData_i
inlinefinalinherited
◆ getUserData_i() [3/3]
◆ mutex() [1/2]
◆ mutex() [2/2]
◆ process_i() [1/2]
ErrCode ds3d::impl::BaseImplDataBridge::process_i ( const struct VideoBridge2dInput inputData,
const abiOnDataCB outputDataCb,
const abiOnBridgeDataCB inputDataConsumedCb
inlinefinalvirtual
◆ process_i() [2/2]
inlinefinalvirtual
◆ processImpl() [1/2]
virtual ErrCode ds3d::impl::BaseImplDataBridge::processImpl ( const struct VideoBridge2dInput inputData,
◆ processImpl() [2/2]
Referenced by process_i().
◆ setErrorCallback_i() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::setErrorCallback_i ( const abiErrorCB cb)
◆ setErrorCallback_i() [2/2]
◆ setInputCaps() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::setInputCaps ( const std::string &  caps)
◆ setInputCaps() [2/2]
◆ setOutputCaps() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::setOutputCaps ( const std::string &  caps)
◆ setOutputCaps() [2/2]
◆ setStateSafe() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::setStateSafe ( State  flag)
◆ setStateSafe() [2/2]
◆ setUserData_i() [1/2]
void ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::setUserData_i ( const abiRefAny userdata)
◆ setUserData_i() [2/2]
◆ start_i() [1/2]
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::start_i ( const char *  configStr,
uint32_t  strLen,
const char *  path
◆ start_i() [2/2]
uint32_t  strLen,
const char *  path
◆ startImpl() [1/2]
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::startImpl ( const std::string &  content,
const std::string &  path
◆ startImpl() [2/2]
◆ state_i() [1/3]
virtual State ds3d::abiProcess::state_i ( ) const
◆ state_i() [2/3]
◆ state_i() [3/3]
◆ stop_i() [1/2]
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::stop_i
◆ stop_i() [2/2]
◆ stopImpl() [1/2]
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataBridge , >::stopImpl
◆ stopImpl() [2/2]
