7.1 Release
ds3d::impl::BaseImplDataMixer Class Referenceabstract
Any custom datamixer must derive from BaseImplDataMixer,.
For custom lib implementation, user need to implement the following virtual functions: startImpl(...), // user also need setCaps(port) in startImpl stopImpl(), // stop all resources for datamixer prepollImpl(data), // prepoll on 1st coming data renderImpl(data, dataConsumedCb), // rendering data. Once data is done, invoke dataConsumedCb(datamap) callback to notify application flushImpl(), // flush data in process
Definition at line 34 of file impl_datamixer.h.
Inheritance diagram for ds3d::impl::BaseImplDataMixer:
Collaboration diagram for ds3d::impl::BaseImplDataMixer:
Public Types
using OnGuardDataCBImpl = std::function< void(ErrCode, GuardDataMap)>
using OnGuardBridgeDataCBImpl = std::function< void(ErrCode, const struct VideoBridge2dInput *)>
using ImplMutex = std::recursive_mutex
Public Member Functions
 BaseImplDataMixer ()
 ~BaseImplDataMixer () override=default
ErrCode process_i (const int portId, const abiRefDataMap *inputData, const abiOnDataCB *inputDataConsumedCb) final
ErrCode setOutputCb_i (const abiOnDataCB *outputDataCb) final
ErrCode updateInput_i (int portId, MixerUpdate updateType)
void setUserData_i (const abiRefAny *userdata) final
const abiRefAnygetUserData_i () const final
virtual const abiRefAnygetUserData_i () const =0
void setErrorCallback_i (const abiErrorCB &cb) final
ErrCode start_i (const char *configStr, uint32_t strLen, const char *path) override
const char * getCaps_i (CapsPort p) const final
ErrCode flush_i () override
ErrCode stop_i () override
State state_i () const final
virtual State state_i () const =0
Protected Member Functions
virtual ErrCode processImpl (const int portId, GuardDataMap datamap, OnGuardDataCBImpl inputConsumedCb)=0
virtual ErrCode setOutputCbImpl (OnGuardDataCBImpl outputDataCb)=0
virtual ErrCode updateInputImpl (int portId, MixerUpdate updateType)=0
virtual ErrCode startImpl (const std::string &content, const std::string &path)=0
virtual ErrCode stopImpl ()=0
virtual ErrCode flushImpl ()=0
void setOutputCaps (const std::string &caps)
void setInputCaps (const std::string &caps)
void emitError (ErrCode code, const std::string &msg)
State getStateSafe () const
void setStateSafe (State flag)
ImplMutexmutex () const
Member Typedef Documentation
◆ ImplMutex
using ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::ImplMutex = std::recursive_mutex
inherited
Definition at line 31 of file impl_dataprocess.h.
◆ OnGuardBridgeDataCBImpl
using ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::OnGuardBridgeDataCBImpl = std::function<void(ErrCode, const struct VideoBridge2dInput*)>
inherited
Definition at line 30 of file impl_dataprocess.h.
◆ OnGuardDataCBImpl
Definition at line 29 of file impl_dataprocess.h.
◆ BaseImplDataMixer()
ds3d::impl::BaseImplDataMixer::BaseImplDataMixer ( )
inline
Definition at line 36 of file impl_datamixer.h.
◆ ~BaseImplDataMixer()
ds3d::impl::BaseImplDataMixer::~BaseImplDataMixer ( )
overridedefault
Member Function Documentation
◆ emitError()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::emitError ( ErrCode  code,
const std::string &  msg
inlineprotectedinherited
Definition at line 105 of file impl_dataprocess.h.
◆ flush_i()
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::flush_i
inlineoverridevirtualinherited
Implements ds3d::abiProcess.
Definition at line 72 of file impl_dataprocess.h.
◆ flushImpl()
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::flushImpl
protectedpure virtualinherited
◆ getCaps_i()
const char* ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::getCaps_i ( CapsPort  p) const
inlinefinalvirtualinherited
Definition at line 62 of file impl_dataprocess.h.
◆ getStateSafe()
State ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::getStateSafe
Definition at line 112 of file impl_dataprocess.h.
◆ getUserData_i() [1/2]
virtual const abiRefAny* ds3d::abiProcess::getUserData_i ( ) const
◆ getUserData_i() [2/2]
const abiRefAny* ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::getUserData_i
inlinefinalinherited
Definition at line 48 of file impl_dataprocess.h.
◆ mutex()
ImplMutex& ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::mutex
Definition at line 125 of file impl_dataprocess.h.
◆ process_i()
ErrCode ds3d::impl::BaseImplDataMixer::process_i ( const int  portId,
const abiRefDataMap inputData,
const abiOnDataCB inputDataConsumedCb
inlinefinalvirtual
◆ processImpl()
virtual ErrCode ds3d::impl::BaseImplDataMixer::processImpl ( const int  portId,
Referenced by process_i().
◆ setErrorCallback_i()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::setErrorCallback_i ( const abiErrorCB cb)
Definition at line 49 of file impl_dataprocess.h.
◆ setInputCaps()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::setInputCaps ( const std::string &  caps)
Definition at line 103 of file impl_dataprocess.h.
◆ setOutputCaps()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::setOutputCaps ( const std::string &  caps)
Definition at line 101 of file impl_dataprocess.h.
◆ setOutputCb_i()
ErrCode ds3d::impl::BaseImplDataMixer::setOutputCb_i ( const abiOnDataCB outputDataCb)
inlinefinalvirtual
◆ setOutputCbImpl()
virtual ErrCode ds3d::impl::BaseImplDataMixer::setOutputCbImpl ( OnGuardDataCBImpl  outputDataCb)
Referenced by setOutputCb_i().
◆ setStateSafe()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::setStateSafe ( State  flag)
Definition at line 118 of file impl_dataprocess.h.
◆ setUserData_i()
void ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::setUserData_i ( const abiRefAny userdata)
Definition at line 40 of file impl_dataprocess.h.
◆ start_i()
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::start_i ( const char *  configStr,
uint32_t  strLen,
const char *  path
Definition at line 50 of file impl_dataprocess.h.
◆ startImpl()
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::startImpl ( const std::string &  content,
const std::string &  path
◆ state_i() [1/2]
virtual State ds3d::abiProcess::state_i ( ) const
◆ state_i() [2/2]
State ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::state_i
Definition at line 92 of file impl_dataprocess.h.
◆ stop_i()
ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::stop_i
Definition at line 80 of file impl_dataprocess.h.
◆ stopImpl()
virtual ErrCode ds3d::impl::BaseImplDataProcessor< abiDataMixer , >::stopImpl
◆ updateInput_i()
ErrCode ds3d::impl::BaseImplDataMixer::updateInput_i ( int  portId,
inlinevirtual
Implements ds3d::abiDataMixer.
Definition at line 74 of file impl_datamixer.h.
References updateInputImpl().
◆ updateInputImpl()
virtual ErrCode ds3d::impl::BaseImplDataMixer::updateInputImpl ( int  portId,
Referenced by updateInput_i().
