prometheus::Registry Class Reference
Manages the collection of a number of metrics.
The Registry is responsible to expose data to a class/method/function "bridge", which returns the metrics in a format Prometheus supports.
The key class is the Collectable. This has a method - called Collect() - that returns zero or more metrics and their samples. The metrics are represented by the class Family<>, which implements the Collectable interface. A new metric is registered with BuildCounter(), BuildGauge(), BuildHistogram(), BuildInfo() or BuildSummary().
The class is thread-safe. No concurrent call to any API of this type causes a data race.
Definition at line 41 of file sources/includes/prometheus/registry.h.
Inheritance diagram for prometheus::Registry:
Collaboration diagram for prometheus::Registry:
Public Types
enum  InsertBehavior {
  InsertBehavior::Merge,
  InsertBehavior::Throw,
 How to deal with repeatedly added family names for a type. More...
Public Member Functions
 Registry (InsertBehavior insert_behavior=InsertBehavior::Merge)
 name Create a new registry. More...
 Registry (const Registry &)=delete
 Deleted copy constructor. More...
Registryoperator= (const Registry &)=delete
 Deleted copy assignment. More...
 Registry (Registry &&)=delete
 Deleted move constructor. More...
Registryoperator= (Registry &&)=delete
 Deleted move assignment. More...
 ~Registry () override
 name Destroys a registry. More...
std::vector< MetricFamilyCollect () const override
 Returns a list of metrics and their samples. More...
template<typename T >
bool Remove (const Family< T > &family)
 Removes a metrics family from the registry. More...
Friends
class detail::Builder
Member Enumeration Documentation
◆ InsertBehavior [1/2]
Adding a family with the same name but different types is always an error and will lead to an exception.
Enumerator
Merge
If a family with the same name and labels already exists return the existing one.
If no family with that name exists create it. Otherwise throw.
Throw
Throws if a family with the same name already exists.
Merge
Throw
Definition at line 47 of file sources/includes/prometheus/registry.h.
◆ InsertBehavior [2/2]
Enumerator
Merge
Throw
Merge
Throw
Definition at line 47 of file 9.0/sources/includes/prometheus/registry.h.
◆ Registry() [1/6]
prometheus::Registry::Registry ( InsertBehavior  insert_behavior = InsertBehavior::Merge)
explicit
Parameters
insert_behaviorHow to handle families with the same name.
◆ Registry() [2/6]
prometheus::Registry::Registry ( const Registry )
delete
◆ Registry() [3/6]
prometheus::Registry::Registry ( Registry &&  )
delete
◆ ~Registry() [1/2]
prometheus::Registry::~Registry ( )
override
◆ Registry() [4/6]
explicit
Parameters
◆ Registry() [5/6]
delete
◆ Registry() [6/6]
delete
◆ ~Registry() [2/2]
override
Member Function Documentation
◆ Collect() [1/2]
std::vector<MetricFamily> prometheus::Registry::Collect ( ) const
overridevirtual
Every time the Registry is scraped it calls each of the metrics Collect function.
Returns
Zero or more metrics and their samples.
Implements prometheus::Collectable.
◆ Collect() [2/2]
overridevirtual
Returns
◆ operator=() [1/4]
Registry& prometheus::Registry::operator= ( const Registry )
delete
◆ operator=() [2/4]
delete
◆ operator=() [3/4]
Registry& prometheus::Registry::operator= ( Registry &&  )
delete
◆ operator=() [4/4]
delete
◆ Remove() [1/2]
bool prometheus::Registry::Remove ( const Family< T > &  family)
Please note that this operation invalidates the previously returned reference to the Family and all of their added metric objects.
Template Parameters
TOne of the metric types Counter, Gauge, Histogram or Summary.
Parameters
familyThe family to remove
Returns
True if the family was found and removed.
◆ Remove() [2/2]
Template Parameters
Parameters
Returns
Friends And Related Function Documentation
◆ detail::Builder [1/2]
friend class detail::Builder
friend
Definition at line 99 of file sources/includes/prometheus/registry.h.
◆ detail::Builder [2/2]
friend
Definition at line 99 of file 9.0/sources/includes/prometheus/registry.h.
