Data Structures | |
| struct | TextLocation |
| struct | cuOSDContextCommand |
| struct | CircleCommand |
| struct | RectangleCommand |
| struct | BoxBlurCommand |
| struct | TextCommand |
| struct | SegmentCommand |
| struct | PolyFillCommand |
| struct | RGBASourceCommand |
| struct | NV12SourceCommand |
Enumerations | |
| enum | ImageFormat : int { ImageFormat::None = 0, ImageFormat::RGB = 1, ImageFormat::RGBA = 2, ImageFormat::BlockLinearNV12 = 3, ImageFormat::PitchLinearNV12 = 4 } |
| enum | CommandType : int { CommandType::None = 0, CommandType::Circle = 1, CommandType::Rectangle = 2, CommandType::Text = 3, CommandType::Segment = 4, CommandType::PolyFill = 5, CommandType::RGBASource = 6, CommandType::NV12Source = 7, CommandType::BoxBlur = 8 } |
Functions | |
| void | cuosd_launch_kernel (void *image_data0, void *image_data1, int width, int stride, int height, ImageFormat format, const TextLocation *text_location, const unsigned char *text_bitmap, int text_bitmap_width, const int *line_location_base, const unsigned char *commands, const int *commands_offset, int num_commands, int bounding_left, int bounding_top, int bounding_right, int bounding_bottom, bool have_rotatebox, const unsigned char *blur_commands, int num_blur_commands, void *stream) |
strong |
| Enumerator | |
| None | |
| Circle | |
| Rectangle | |
| Text | |
| Segment | |
| PolyFill | |
| RGBASource | |
| NV12Source | |
| BoxBlur | |
Definition at line 24 of file cuosd_kernel.h.
strong |
| Enumerator | |
| None | |
| RGB | |
| RGBA | |
| BlockLinearNV12 | |
| PitchLinearNV12 | |
Definition at line 16 of file cuosd_kernel.h.
| void cuosd_launch_kernel | ( | void * | image_data0, |
| void * | image_data1, | ||
| int | width, | ||
| int | stride, | ||
| int | height, | ||
| ImageFormat | format, | ||
| const TextLocation * | text_location, | ||
| const unsigned char * | text_bitmap, | ||
| int | text_bitmap_width, | ||
| const int * | line_location_base, | ||
| const unsigned char * | commands, | ||
| const int * | commands_offset, | ||
| int | num_commands, | ||
| int | bounding_left, | ||
| int | bounding_top, | ||
| int | bounding_right, | ||
| int | bounding_bottom, | ||
| bool | have_rotatebox, | ||
| const unsigned char * | blur_commands, | ||
| int | num_blur_commands, | ||
| void * | stream | ||
