7.1 Release
deepstream_tiled_display.h File Reference
Data Structures
struct  NvDsTiledDisplayBin
struct  NvDsTiledDisplayConfig
Enumerations
enum  NvDsTiledDisplayEnable {
  NV_DS_TILED_DISPLAY_DISABLE = 0,
  NV_DS_TILED_DISPLAY_ENABLE = 1,
  NV_DS_TILED_DISPLAY_ENABLE_WITH_PARALLEL_DEMUX = 2
Functions
gboolean create_tiled_display_bin (NvDsTiledDisplayConfig *config, NvDsTiledDisplayBin *bin)
 Initialize NvDsTiledDisplayBin. More...
◆ NvDsTiledDisplayEnable
Enumerator
When user sets tiler group enable=2, all sinks with the key: link-only-to-demux=1 shall be linked to demuxer's src_[source_id] pad where source_id is the key set in this corresponding [sink] group.
Definition at line 31 of file deepstream_tiled_display.h.
Function Documentation
◆ create_tiled_display_bin()
gboolean create_tiled_display_bin ( NvDsTiledDisplayConfig config,
NvDsTiledDisplayBin bin
It creates and adds tiling and other elements needed for processing to the bin. It also sets properties mentioned in the configuration file under group CONFIG_GROUP_TILED_DISPLAY
Parameters
[in]configpointer of type NvDsTiledDisplayConfig parsed from configuration file.
[in]binpointer to NvDsTiledDisplayBin to be filled.
Returns
true if bin created successfully.
