Messaging API
Defines an API for exchanging messages with remote entities and services.
Typedefs
typedef void * NvDsMsgApiHandle
 Defines the handle used by messaging API functions. More...
typedef void(* nvds_msgapi_send_cb_t) (void *user_ptr, NvDsMsgApiErrorType completion_flag)
 Type definition for a "send" callback. More...
typedef void(* nvds_msgapi_subscribe_request_cb_t) (NvDsMsgApiErrorType flag, void *msg, int msg_len, char *topic, void *user_ptr)
 Type definition for callback registered during subscribe. More...
typedef void(* nvds_msgapi_connect_cb_t) (NvDsMsgApiHandle h_ptr, NvDsMsgApiEventType ds_evt)
 Type definition for a "handle" callback. More...
Enumerations
enum  NvDsMsgApiEventType {
  NVDS_MSGAPI_EVT_SUCCESS,
  NVDS_MSGAPI_EVT_DISCONNECT,
  NVDS_MSGAPI_EVT_SERVICE_DOWN,
 Defines events associated with connections to remote entities. More...
enum  NvDsMsgApiErrorType {
  NVDS_MSGAPI_OK,
  NVDS_MSGAPI_ERR,
  NVDS_MSGAPI_UNKNOWN_TOPIC,
  NVDS_MSGAPI_OK,
  NVDS_MSGAPI_ERR,
 Defines completion codes for operations in the messaging API. More...
  NVDS_MSGAPI_OK,
  NVDS_MSGAPI_ERR,
  NVDS_MSGAPI_OK,
  NVDS_MSGAPI_ERR,
Functions
NvDsMsgApiHandle nvds_msgapi_connect (char *connection_str, nvds_msgapi_connect_cb_t connect_cb, char *config_path)
 Connects to a remote agent by calling into protocol adapter. More...
NvDsMsgApiErrorType nvds_msgapi_send (NvDsMsgApiHandle h_ptr, char *topic, const uint8_t *payload, size_t nbuf)
 Sends a message synchronously over a connection. More...
NvDsMsgApiErrorType nvds_msgapi_send_async (NvDsMsgApiHandle h_ptr, char *topic, const uint8_t *payload, size_t nbuf, nvds_msgapi_send_cb_t send_callback, void *user_ptr)
 Sends message asynchronously over a connection. More...
NvDsMsgApiErrorType nvds_msgapi_subscribe (NvDsMsgApiHandle h_ptr, char **topics, int num_topics, nvds_msgapi_subscribe_request_cb_t cb, void *user_ctx)
 Subscribe to a remote entity for receiving messages on a particular topic(s) More...
void nvds_msgapi_do_work (NvDsMsgApiHandle h_ptr)
 Calls into the adapter to allow for execution of undnerlying protocol logic. More...
NvDsMsgApiErrorType nvds_msgapi_disconnect (NvDsMsgApiHandle h_ptr)
 Terminates a connection. More...
char * nvds_msgapi_getversion (void)
 Gets the version number of the messaging API interface supported by the protocol adapter. More...
char * nvds_msgapi_get_protocol_name (void)
 Gets the name of the protocol used in the adapter. More...
NvDsMsgApiErrorType nvds_msgapi_connection_signature (char *broker_str, char *cfg, char *output_str, int max_len)
 Fetch the connection signature by parsing broker_connection string and cfg file. More...
Typedef Documentation
◆ nvds_msgapi_connect_cb_t [1/2]
This callback reports any event (success or error) during a call to nvds_msgapi_connect().
Parameters
[in]h_ptrA handle for the event.
[in]ds_evtType of the event.
Definition at line 98 of file sources/includes/nvds_msgapi.h.
◆ nvds_msgapi_connect_cb_t [2/2]
Parameters
Definition at line 98 of file 9.0/sources/includes/nvds_msgapi.h.
◆ nvds_msgapi_send_cb_t [1/2]
Parameters
[in]user_ptrA context pointer passed by async_send. The pointer may refer to any type of information that is useful to the callback.
[in]completion_flagThe completion code from a send operation.
Definition at line 71 of file sources/includes/nvds_msgapi.h.
◆ nvds_msgapi_send_cb_t [2/2]
Parameters
Definition at line 71 of file 9.0/sources/includes/nvds_msgapi.h.
◆ nvds_msgapi_subscribe_request_cb_t [1/2]
This callback reports any event (success or error) that occurs when a message is consumed. If the event is success, the callback reports the consumed message on a subscribed topic.
Parameters
[in]flagMessage consumption status.
[in]msgA pointer to the message or payload received.
[in]msg_lenLength of the message or payload.
[in]topicA pointer to the name of the topic where the message was received
[in]user_ptrA pointer to a context, passed by subscribe().
Definition at line 87 of file 9.0/sources/includes/nvds_msgapi.h.
◆ nvds_msgapi_subscribe_request_cb_t [2/2]
Parameters
Definition at line 87 of file sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiHandle [1/2]
typedef void* NvDsMsgApiHandle
Definition at line 40 of file sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiHandle [2/2]
Definition at line 40 of file 9.0/sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiErrorType [1/2]
Enumerator
NVDS_MSGAPI_OK
NVDS_MSGAPI_ERR
NVDS_MSGAPI_OK
NVDS_MSGAPI_ERR
Definition at line 57 of file sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiErrorType [2/2]
Enumerator
NVDS_MSGAPI_OK
NVDS_MSGAPI_ERR
NVDS_MSGAPI_OK
NVDS_MSGAPI_ERR
Definition at line 57 of file 9.0/sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiEventType [1/2]
Enumerator
Specifies that a connection attempt was successful.
Specifies disconnection of a connection handle.
Specifies that the remote service is down.
Definition at line 45 of file 9.0/sources/includes/nvds_msgapi.h.
◆ NvDsMsgApiEventType [2/2]
Enumerator
Definition at line 45 of file sources/includes/nvds_msgapi.h.
Function Documentation
◆ nvds_msgapi_connect()
NvDsMsgApiHandle nvds_msgapi_connect ( char *  connection_str,
char *  config_path
Parameters
[in]connection_strA connection string with format "url;port;topic".
[in]connect_cbA pointer to a callback function for events associated with the connection.
[in]config_pathA pointer to the pathname of a configuration file passed to the protocol adapter.
Returns
A connection handle.
◆ nvds_msgapi_connection_signature()
NvDsMsgApiErrorType nvds_msgapi_connection_signature ( char *  broker_str,
char *  cfg,
char *  output_str,
int  max_len
A connection signature is a unique string used to identify a connection. It is generated by parsing all the connection params provided in broker_str and cfg file
Connection signature can be retreived only if the cfg option share-connection = 1
Parameters
[in]broker_strBroker connection string used to create connection
[in]cfgPath to config file
[out]output_strconnection signature
[in]max_lenmax len of output_str
Returns
Valid connection signature if success Empty string("") in case of errors or if share-connection cfg option is not set to 1
◆ nvds_msgapi_disconnect()
NvDsMsgApiErrorType nvds_msgapi_disconnect ( NvDsMsgApiHandle  h_ptr)
Parameters
[in]h_ptrThe connection handle.
Returns
A completion code for the "terminate" operation.
◆ nvds_msgapi_do_work()
void nvds_msgapi_do_work ( NvDsMsgApiHandle  h_ptr)
In this call the adapter is expected to service pending incoming and outgoing messages. It can also perform periodic housekeeping tasks such as sending heartbeats.
This design gives the client control over when protocol logic gets executed. The client must call it periodically, according to the individual adapter's requirements.
Parameters
[in]h_ptrA connection handle.
◆ nvds_msgapi_get_protocol_name()
char * nvds_msgapi_get_protocol_name ( void  )
Returns
A pointer to a string
◆ nvds_msgapi_getversion()
char * nvds_msgapi_getversion ( void  )
Returns
A pointer to a string that contains version number in "major.minor" format.
◆ nvds_msgapi_send()
NvDsMsgApiErrorType nvds_msgapi_send ( NvDsMsgApiHandle  h_ptr,
char *  topic,
const uint8_t *  payload,
size_t  nbuf
Parameters
[in]topicA pointer to a string which specifies the topic to which to send the message.
[in]payloadA pointer to a byte array containing the message. The message may but need not be a NULL-terminated string.
[in]nbufThe number of bytes of data to send, including the terminating NULL if the message is a string.
Returns
A completion code for the send operation.
◆ nvds_msgapi_send_async()
NvDsMsgApiErrorType nvds_msgapi_send_async ( NvDsMsgApiHandle  h_ptr,
char *  topic,
size_t  nbuf,
void *  user_ptr
Parameters
[in]send_callbackA callback to be invoked when operation completes.
[in]user_ptrA context pointer to pass to callback.
Returns
◆ nvds_msgapi_subscribe()
NvDsMsgApiErrorType nvds_msgapi_subscribe ( NvDsMsgApiHandle  h_ptr,
char **  topics,
int  num_topics,
void *  user_ctx
Parameters
[in]h_ptrConnection handle
[in]topicsArray of topics to subscribe for messages
[in]num_topicsnum of topics
[in]cbA pointer to a callback function for notifying the DS event handler
[in]user_ctxuser ptr to be passed to callback for context
Returns
Status of the subscribe operation.
