7.1 Release
Messages: Custom Message Functions API
Helper functions for custom GStreamer messages posted by DeepStream GStreamer plugins.
DeepStream GStreamer plugins post the following custom messages:
Functions
GstMessage * gst_nvmessage_new_stream_eos (GstObject *obj, guint eos_stream_id)
 Creates a new Stream EOS message. More...
gboolean gst_nvmessage_is_stream_eos (GstMessage *message)
 Determines whether a message is a stream EOS message. More...
gboolean gst_nvmessage_parse_stream_eos (GstMessage *message, guint *eos_stream_id)
 Parses the stream ID from a stream EOS message. More...
Function Documentation
◆ gst_nvmessage_is_stream_eos()
gboolean gst_nvmessage_is_stream_eos ( GstMessage *  message)
params[in] message A pointer to the message to be checked.
Returns
A Boolean; true if the message is a stream EOS message.
◆ gst_nvmessage_new_stream_eos()
GstMessage* gst_nvmessage_new_stream_eos ( GstObject *  obj,
guint  eos_stream_id
params[in] obj The GStreamer object creating the message. params[in] eos_stream_id Stream ID of the stream for which EOS has been received.
Returns
A pointer to the new message.
◆ gst_nvmessage_parse_stream_eos()
gboolean gst_nvmessage_parse_stream_eos ( GstMessage *  message,
guint *  eos_stream_id
The stream ID is the index of the stream which sent the EOS event to Gst-streammux.
params[in] message A pointer to a stream EOS message. params[out] eos_stream_id A pointer to an unsigned integer in which the stream ID is stored.
Returns
A Boolean; true if the message was successfully parsed.
