Gets information such as the batch size and the number of streams.
Functions
GstQuery * gst_nvquery_batch_size_new (void)
 Creates a new batch-size query, which can be used by elements to query the number of buffers in upstream elements' batched buffers. More...
gboolean gst_nvquery_is_batch_size (GstQuery *query)
 Determines whether a query is a batch size query. More...
void gst_nvquery_batch_size_set (GstQuery *query, guint batch_size)
 Sets the batch size, used by the elements responding to the batch size query. More...
gboolean gst_nvquery_batch_size_parse (GstQuery *query, guint *batch_size)
 Parses batch size from a batch size query. More...
GstQuery * gst_nvquery_numStreams_size_new (void)
 Creates a number of streams query, used by elements to query upstream the number of input sources. More...
gboolean gst_nvquery_is_numStreams_size (GstQuery *query)
 Determines whether a query is a number-of-streams query. More...
void gst_nvquery_numStreams_size_set (GstQuery *query, guint numStreams_size)
 Sets the number of input sources. More...
gboolean gst_nvquery_numStreams_size_parse (GstQuery *query, guint *numStreams_size)
 Parses the number of streams from a number of streams query. More...
GstQuery * gst_nvquery_preprocess_poolsize_new (guint gieid)
 Creates a preprocess poolsize query, used by elements to query preprocess element for the size of buffer pool. More...
gboolean gst_nvquery_is_preprocess_poolsize (GstQuery *query)
 Determines whether a query is a preprocess poolsize query. More...
void gst_nvquery_preprocess_poolsize_set (GstQuery *query, guint preprocess_poolsize)
 Sets the preprocess poolsize as a reponse to query. More...
gboolean gst_nvquery_preprocess_poolsize_parse (GstQuery *query, guint *preprocess_poolsize)
 Parses the preprocess poolsize from a preprocess poolsize query. More...
gboolean gst_nvquery_preprocess_poolsize_gieid_parse (GstQuery *query, guint *gieId)
 Parses the preprocess gie id from a preprocess poolsize query. More...
gboolean gst_nvquery_is_update_caps (GstQuery *query)
 Checks if a query is update_caps query. More...
void gst_nvquery_parse_update_caps (GstQuery *query, guint *stream_index, const GValue *frame_rate)
 Parses the update_caps query. More...
gboolean gst_nvquery_update_caps_peer_query (GstPad *srcpad, GstStructure *str)
 Heterogeneous batching query for new streammux. More...
GstQuery * gst_nvquery_text_embedding_new (const gchar *text_input, const gchar *model)
 Creates a new text embedding query, which can be used to request text embedding information from the nvinfer plugin. More...
gboolean gst_nvquery_is_text_embedding (GstQuery *query)
 Determines whether a query is a text embedding query. More...
void gst_nvquery_text_embedding_set (GstQuery *query, const gchar *id, guint64 created, const gchar *model, const GValue *data)
 Sets the text embedding response data, used by elements responding to the text embedding query. More...
gboolean gst_nvquery_text_embedding_parse (GstQuery *query, const gchar **id, guint64 *created, const gchar **model, const GValue **data)
 Parses the text embedding response from a text embedding query. More...
gboolean gst_nvquery_text_embedding_parse_request (GstQuery *query, const gchar **text_input, const gchar **model)
 Parses the text embedding request parameters from a text embedding query. More...
Function Documentation
◆ gst_nvquery_batch_size_new()
GstQuery * gst_nvquery_batch_size_new ( void  )
Returns
A pointer to the new batch size query.
◆ gst_nvquery_batch_size_parse()
gboolean gst_nvquery_batch_size_parse ( GstQuery *  query,
guint *  batch_size
params[in] query A pointer to a batch size query. params[out] batch_size A pointer to an unsigned integer in which the batch size is stored.
Returns
True if the query was successfully parsed.
◆ gst_nvquery_batch_size_set()
void gst_nvquery_batch_size_set ( GstQuery *  query,
guint  batch_size
This function fails if the query is not a batch size query.
params[in] query A pointer to a batch size query. params[in] batch_size The batch size to be set.
◆ gst_nvquery_is_batch_size()
gboolean gst_nvquery_is_batch_size ( GstQuery *  query)
params[in] query A pointer to the query to be checked.
Returns
True if the query is a batch size query.
◆ gst_nvquery_is_numStreams_size()
gboolean gst_nvquery_is_numStreams_size ( GstQuery *  query)
Returns
A Boolean; true if the query is a number of streams query.
◆ gst_nvquery_is_preprocess_poolsize()
gboolean gst_nvquery_is_preprocess_poolsize ( GstQuery *  query)
Returns
A Boolean; true if the query is a preprocess poolsize query.
◆ gst_nvquery_is_text_embedding()
gboolean gst_nvquery_is_text_embedding ( GstQuery *  query)
Returns
True if the query is a text embedding query.
◆ gst_nvquery_is_update_caps()
gboolean gst_nvquery_is_update_caps ( GstQuery *  query)
params[in] query A pointer to a query.
Returns
True if the query was update_caps query.
◆ gst_nvquery_numStreams_size_new()
GstQuery * gst_nvquery_numStreams_size_new ( void  )
Returns
A pointer to the new query.
◆ gst_nvquery_numStreams_size_parse()
gboolean gst_nvquery_numStreams_size_parse ( GstQuery *  query,
guint *  numStreams_size
params[in] query A pointer to a number-of-streams query. params[out] batch_size A pointer to an unsigned integer in which the number of streams is stored.
Returns
◆ gst_nvquery_numStreams_size_set()
void gst_nvquery_numStreams_size_set ( GstQuery *  query,
This function is used by elements responding to a number of streams query. It fails if the query is not of the correct type.
params[in] query A pointer to a number-of-streams query. params[in] numStreams_size The number of input sources.
◆ gst_nvquery_parse_update_caps()
void gst_nvquery_parse_update_caps ( GstQuery *  query,
guint *  stream_index,
const GValue frame_rate
params[in] query A pointer to a update_caps query. params[out] stream_index A pointer to an unsigned integer in which the stream_index is stored. params[out] frame_rate A pointer to an GValue string in which the frame_rate is stored.
Returns
Void.
◆ gst_nvquery_preprocess_poolsize_gieid_parse()
gboolean gst_nvquery_preprocess_poolsize_gieid_parse ( GstQuery *  query,
guint *  gieId
params[in] query A pointer to a nv-preprocess-poolsize query. params[out] gieid A pointer to an unsigned integer in which the preprocess gie id is stored.
Returns
◆ gst_nvquery_preprocess_poolsize_new()
GstQuery * gst_nvquery_preprocess_poolsize_new ( guint  gieid)
params[in] gieid An unsigned integer in which the preprocess gie id is stored.
Returns
◆ gst_nvquery_preprocess_poolsize_parse()
gboolean gst_nvquery_preprocess_poolsize_parse ( GstQuery *  query,
guint *  preprocess_poolsize
params[in] query A pointer to a nv-preprocess-poolsize query. params[out] preprocess_poolsize A pointer to an unsigned integer in which the preprocess poolsize is stored.
Returns
◆ gst_nvquery_preprocess_poolsize_set()
void gst_nvquery_preprocess_poolsize_set ( GstQuery *  query,
params[in] query A pointer to a nv-preprocess-poolsize query. params[in] preprocess_poolsize The preprocess poolsize to be set.
◆ gst_nvquery_text_embedding_new()
GstQuery * gst_nvquery_text_embedding_new ( const gchar *  text_input,
const gchar *  model
params[in] text_input A pointer to the input text string. params[in] model A pointer to the model name string.
Returns
A pointer to the new text embedding query.
◆ gst_nvquery_text_embedding_parse()
gboolean gst_nvquery_text_embedding_parse ( GstQuery *  query,
const gchar **  id,
guint64 *  created,
const gchar **  model,
const GValue **  data
params[in] query A pointer to a text embedding query. params[out] id A pointer to store the unique identifier string. params[out] created A pointer to store the creation timestamp. params[out] model A pointer to store the model name string. params[out] data A pointer to store the GValue containing embedding data.
Returns
◆ gst_nvquery_text_embedding_parse_request()
gboolean gst_nvquery_text_embedding_parse_request ( GstQuery *  query,
const gchar **  text_input,
params[in] query A pointer to a text embedding query. params[out] text_input A pointer to store the input text string. params[out] model A pointer to store the model name string.
Returns
◆ gst_nvquery_text_embedding_set()
void gst_nvquery_text_embedding_set ( GstQuery *  query,
const gchar *  id,
guint64  created,
const gchar *  model,
const GValue data
params[in] query A pointer to a text embedding query. params[in] id A pointer to the unique identifier string. params[in] created The creation timestamp (epoch). params[in] model A pointer to the model name string. params[in] data A pointer to a GValue containing the embedding data array.
◆ gst_nvquery_update_caps_peer_query()
gboolean gst_nvquery_update_caps_peer_query ( GstPad *  srcpad,
GstStructure *  str
params[in] srcpad A pointer to a srcpad. params[in] str A pointer to a str of update_caps query.
Returns
True if the query was successfully pushed.
