8.0 Release
Specifies APIs relating to smart recording.
Data Structures
struct  NvDsSRInitParams
 Holds initializtion paramerters required to create NvDsSRContext. More...
struct  NvDsSRContext
 Holds information about smart record instance. More...
struct  NvDsSRRecordingInfo
 Hold information about video recorded. More...
Typedefs
typedef struct NvDsSRRecordingInfo NvDsSRRecordingInfo
typedef gpointer(* NvDsSRCallbackFunc) (NvDsSRRecordingInfo *info, gpointer userData)
typedef guint32 NvDsSRSessionId
typedef struct NvDsSRInitParams NvDsSRInitParams
typedef struct NvDsSRContext NvDsSRContext
Enumerations
enum  NvDsSRContainerType {
  NVDSSR_CONTAINER_MP4,
  NVDSSR_CONTAINER_MKV,
 Specifies container types. More...
enum  NvDsSRStatus {
  NVDSSR_STATUS_OK,
  NVDSSR_STATUS_INVALID_VAL,
  NVDSSR_STATUS_INVALID_OP,
  NVDSSR_STATUS_ERROR,
  NVDSSR_STATUS_CUSTOM1 = 100,
  NVDSSR_STATUS_CUSTOM2 = 101,
  NVDSSR_STATUS_CUSTOM3 = 102,
  NVDSSR_STATUS_OK,
 Specifies API return status. More...
enum  NvDsSRStatus {
  NVDSSR_STATUS_OK,
  NVDSSR_STATUS_OK,
Functions
NvDsSRStatus NvDsSRCreate (NvDsSRContext **ctx, NvDsSRInitParams *params)
 Creates the instance of smart record. More...
NvDsSRStatus NvDsSRStart (NvDsSRContext *ctx, NvDsSRSessionId *sessionId, guint startTime, guint duration, gpointer userData)
 Starts the video recording. More...
NvDsSRStatus NvDsSRStop (NvDsSRContext *ctx, NvDsSRSessionId sessionId)
 Stops the previously started recording. More...
NvDsSRStatus NvDsSRDestroy (NvDsSRContext *ctx)
 Destroys the instance of smart record. More...
Typedef Documentation
◆ NvDsSRCallbackFunc [1/2]
Definition at line 47 of file sources/includes/gst-nvdssr.h.
◆ NvDsSRCallbackFunc [2/2]
Definition at line 47 of file 9.0/sources/includes/gst-nvdssr.h.
◆ NvDsSRContext [1/2]
◆ NvDsSRContext [2/2]
◆ NvDsSRInitParams [1/2]
◆ NvDsSRInitParams [2/2]
◆ NvDsSRRecordingInfo [1/2]
Definition at line 45 of file sources/includes/gst-nvdssr.h.
◆ NvDsSRRecordingInfo [2/2]
Definition at line 45 of file 9.0/sources/includes/gst-nvdssr.h.
◆ NvDsSRSessionId [1/2]
Definition at line 49 of file sources/includes/gst-nvdssr.h.
◆ NvDsSRSessionId [2/2]
Definition at line 49 of file 9.0/sources/includes/gst-nvdssr.h.
◆ NvDsSRContainerType [1/2]
Enumerator
Definition at line 54 of file sources/includes/gst-nvdssr.h.
◆ NvDsSRContainerType [2/2]
Enumerator
Definition at line 54 of file 9.0/sources/includes/gst-nvdssr.h.
◆ NvDsSRStatus [1/2]
Enumerator
NVDSSR_STATUS_OK
NVDSSR_STATUS_ERROR
NVDSSR_STATUS_OK
NVDSSR_STATUS_ERROR
Definition at line 62 of file 9.0/sources/includes/gst-nvdssr.h.
◆ NvDsSRStatus [2/2]
Enumerator
NVDSSR_STATUS_OK
NVDSSR_STATUS_ERROR
NVDSSR_STATUS_OK
NVDSSR_STATUS_ERROR
Definition at line 62 of file sources/includes/gst-nvdssr.h.
Function Documentation
◆ NvDsSRCreate()
NvDsSRStatus NvDsSRCreate ( NvDsSRContext **  ctx,
NvDsSRInitParams params
This function creates the instance of smart record and returns the pointer to an allocated NvDsSRContext. The params structure must be filled with initialization parameters required to create the instance.
recordbin of NvDsSRContext is smart record bin which must be added to the pipeline. It expects encoded frames which will be muxed and saved to the file. Add this bin after parser element in the pipeline.
Call NvDsSRDestroy() to free resources allocated by this function.
Parameters
[out]ctxAn indirect pointer to the smart record instance.
[in]paramsA pointer to a NvDsSRInitParams structure.
Returns
NVDSSR_STATUS_OK if successful, or corresponding error otherwise.
◆ NvDsSRDestroy()
NvDsSRStatus NvDsSRDestroy ( NvDsSRContext ctx)
This function releases the resources previously allocated by NvDsSRCreate().
Parameters
[in]ctxA pointer to a NvDsSRContext to be freed.
Returns
◆ NvDsSRStart()
NvDsSRStatus NvDsSRStart ( NvDsSRContext ctx,
NvDsSRSessionId sessionId,
guint  startTime,
guint  duration,
gpointer  userData
This function starts writing the cached video data to a file. It returns the session id which later can be used in NvDsSRStop() to stop the corresponding recording.
Here startTime specifies the seconds before the current time and duration specifies the seconds after the start of recording. If current time is t1, content from t1 - startTime to t1 + duration will be saved to file. Therefore a total of startTime + duration seconds of data will be recorded.
Parameters
[in]ctxA pointer to a NvDsSRContext.
[out]sessionIdA pointer to a NvDsSRSessionId.
[in]startTimeSeconds before the current time. Should be less than video cache size.
[in]durationDuration value in seconds after the start of recording.
[in]userDataA pointer to user specified data.
Returns
◆ NvDsSRStop()
NvDsSRStatus NvDsSRStop ( NvDsSRContext ctx,
Parameters
[in]sessionIdId of seesion to stop.
Returns
