8.0 Release
Utilities: Gstreamer utilities API
Specifies GStreamer utilities functions, used to configure the source to generate NTP Sync values.
Functions
void configure_source_for_ntp_sync (GstElement *src_elem)
 Configure the source to generate NTP sync values for RTSP sources. More...
Function Documentation
◆ configure_source_for_ntp_sync()
void configure_source_for_ntp_sync ( GstElement *  src_elem)
These values are used by the DeepStream GStreamer element NvStreamMux to calculate the NTP time of the frames at the source.
This functionality is dependent on the RTSP sending the RTCP Sender Reports. source.
This function only works for RTSP sources i.e. GStreamer elements "rtspsrc" or "uridecodebin" with an RTSP uri.
params[in] src_elem GStreamer source element to be configured.
