7.1 Release
DeepStream Yaml Parser API
Defines an API for the GStreamer NvDsYaml plugin.
Data Structures
struct  NvDsYamlCodecStatus
 Enum for codec type for the API call on a encoder. More...
Typedefs
typedef enum NvDsYamlParserStatus NvDsYamlParserStatus
 Enum for Yaml parsing status for the API call on a GstElement. More...
typedef struct NvDsYamlCodecStatus NvDsYamlCodecStatus
Enumerations
enum  NvDsYamlParserStatus {
  NVDS_YAML_PARSER_SUCCESS,
  NVDS_YAML_PARSER_DISABLED,
  NVDS_YAML_PARSER_ERROR
enum  NvDsGieType {
  NVDS_GIE_PLUGIN_INFER = 0,
  NVDS_GIE_PLUGIN_INFER_SERVER
 Enum for specifying the inference plugin type. More...
Functions
NvDsYamlParserStatus nvds_parse_file_source (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a filesrc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_uridecodebin (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a uridecodebin element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_rtsp_source (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a rtspsrc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_nvarguscamerasrc (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvarguscamerasrc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_v4l2src (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a v4l2src element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_multifilesrc (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a multifilesrc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_alsasrc (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a alsasrc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_source_list (GList **src_list, gchar *cfg_file_path, const char *group)
 Parse semicolon separated uri(s) in the source-list group and store it in a GList. More...
NvDsYamlParserStatus nvds_parse_streammux (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvstreammux element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_tracker (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvtracker element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_osd (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvdsosd element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_tiler (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvtiler element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_msgbroker (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvmsgbroker element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_msgconv (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvmsgconv element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_gie (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvinfer element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_gie_type (NvDsGieType *gie_type, gchar *cfg_file_path, const char *group)
 Get the GIE type, nvinfer or invinferserver, from the YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_egl_sink (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nveglglessink element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_3d_sink (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nv3dsink element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_file_sink (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a filesink element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_fake_sink (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a fakesink element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_codec_status (gchar *cfg_file_path, const char *group, NvDsYamlCodecStatus *codec_status)
 Parses codec type and enable status values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_nvv4l2h264enc (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvv4l2h264enc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_nvv4l2h265enc (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvv4l2h265enc element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_multiurisrcbin (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvmultiurisrcbin element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_nvxfer (GstElement *element, gchar *cfg_file_path, const char *group)
 Set properties of a nvdsxfer element from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_nvxfer_position (gchar *cfg_file_path, const char *group, guint *position)
 Parses nvdsxfer plugin position values specified in a YAML configuration file. More...
Typedef Documentation
◆ NvDsYamlCodecStatus
◆ NvDsYamlParserStatus
◆ NvDsGieType
Enumerator
Inference using nvinfer GIE.
Inference using nvinferserver GIE.
Definition at line 64 of file nvds_yml_parser.h.
Enumerator
Properties were set correctly.
Property group was disabled, properties were not set.
Encountered an error while setting properties.
Definition at line 41 of file nvds_yml_parser.h.
Function Documentation
◆ nvds_parse_3d_sink()
NvDsYamlParserStatus nvds_parse_3d_sink ( GstElement *  element,
gchar *  cfg_file_path,
const char *  group
Parameters
[in]elementGstreamer element on which properties are to be set.
[in]cfg_file_pathThe YAML config file used by an application.
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nv3dsink element.
Returns
Yaml parsing status for the API call.
◆ nvds_parse_alsasrc()
NvDsYamlParserStatus nvds_parse_alsasrc ( GstElement *  element,
const char *  group
Parameters
[in]elementGStreamer element on which properties are to be set.
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the alsasrc element.
Returns
◆ nvds_parse_codec_status()
NvDsYamlParserStatus nvds_parse_codec_status ( gchar *  cfg_file_path,
const char *  group,
NvDsYamlCodecStatus codec_status
Parameters
[in]groupGroup in the YAML config file to be parsed. The Group contains codec type parameter, based on which h264 or h265 encoder is used.
Returns
codec type and enable status of encoder as pair for the API call.
◆ nvds_parse_egl_sink()
NvDsYamlParserStatus nvds_parse_egl_sink ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nveglglessink element.
Returns
◆ nvds_parse_fake_sink()
NvDsYamlParserStatus nvds_parse_fake_sink ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the fakesink element.
Returns
◆ nvds_parse_file_sink()
NvDsYamlParserStatus nvds_parse_file_sink ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the filesink element.
Returns
◆ nvds_parse_file_source()
NvDsYamlParserStatus nvds_parse_file_source ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the filesrc element.
Returns
◆ nvds_parse_gie()
NvDsYamlParserStatus nvds_parse_gie ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvinfer element.
Returns
◆ nvds_parse_gie_type()
NvDsYamlParserStatus nvds_parse_gie_type ( NvDsGieType gie_type,
const char *  group
Parameters
[out]gie_typePointer to variable of NvDSGieType to be updated if the plugin type is specified.
Returns
◆ nvds_parse_msgbroker()
NvDsYamlParserStatus nvds_parse_msgbroker ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nmvsgbroker element.
Returns
◆ nvds_parse_msgconv()
NvDsYamlParserStatus nvds_parse_msgconv ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvmsgconv element.
Returns
◆ nvds_parse_multifilesrc()
NvDsYamlParserStatus nvds_parse_multifilesrc ( GstElement *  element,
const char *  group
Parameters
[in]TheYAML config file used by an application.
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the multifilesrc element.
Returns
◆ nvds_parse_multiurisrcbin()
NvDsYamlParserStatus nvds_parse_multiurisrcbin ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvv4l2h265enc element.
Returns
◆ nvds_parse_nvarguscamerasrc()
NvDsYamlParserStatus nvds_parse_nvarguscamerasrc ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvarguscamerasrc element.
Returns
◆ nvds_parse_nvv4l2h264enc()
NvDsYamlParserStatus nvds_parse_nvv4l2h264enc ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvv4l2h264enc element.
Returns
◆ nvds_parse_nvv4l2h265enc()
NvDsYamlParserStatus nvds_parse_nvv4l2h265enc ( GstElement *  element,
const char *  group
Parameters
Returns
◆ nvds_parse_nvxfer()
NvDsYamlParserStatus nvds_parse_nvxfer ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvdsxfer element.
Returns
◆ nvds_parse_nvxfer_position()
NvDsYamlParserStatus nvds_parse_nvxfer_position ( gchar *  cfg_file_path,
const char *  group,
guint *  position
Parameters
[out]positionPointer to variable holding position value.
Returns
◆ nvds_parse_osd()
NvDsYamlParserStatus nvds_parse_osd ( GstElement *  element,
const char *  group
Parameters
[in]elementThe gst element on which properties are to be set.
[in]groupThe group in the YAML config file on which parsing is done and corresponding properties are set on the nvdsosd element.
Returns
◆ nvds_parse_rtsp_source()
NvDsYamlParserStatus nvds_parse_rtsp_source ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the rtspsrc element.
Returns
◆ nvds_parse_source_list()
NvDsYamlParserStatus nvds_parse_source_list ( GList **  src_list,
const char *  group
Parameters
[in]src_listThe empty GList address.
[in]groupGroup in the YAML config file on which parsing is done A key "list" is present in the group which contains semicolon separated uri(s). Once the API call finishes, the GList contains the uris(s).
Returns
◆ nvds_parse_streammux()
NvDsYamlParserStatus nvds_parse_streammux ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvstreammux element.
Returns
◆ nvds_parse_tiler()
NvDsYamlParserStatus nvds_parse_tiler ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvmultistreamtiler element.
Returns
◆ nvds_parse_tracker()
NvDsYamlParserStatus nvds_parse_tracker ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the nvtracker element.
Returns
◆ nvds_parse_uridecodebin()
NvDsYamlParserStatus nvds_parse_uridecodebin ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the uridecodebin element.
Returns
◆ nvds_parse_v4l2src()
NvDsYamlParserStatus nvds_parse_v4l2src ( GstElement *  element,
const char *  group
Parameters
[in]groupGroup in the YAML config file to be parsed and corresponding properties set on the v4l2src element.
Returns
