| enum | {
PROP_0,
PROP_URI,
PROP_NUM_EXTRA_SURF,
PROP_GPU_DEVICE_ID,
PROP_DEC_SKIP_FRAMES,
PROP_SOURCE_TYPE,
PROP_CUDADEC_MEM_TYPE,
PROP_DROP_FRAME_INTERVAL,
PROP_BUFFER_MODE,
PROP_LEAKY,
PROP_MAX_SIZE_BUFFERS,
PROP_RTP_PROTOCOL,
PROP_FILE_LOOP,
PROP_SMART_RECORD,
PROP_SMART_RECORD_DIR_PATH,
PROP_SMART_RECORD_FILE_PREFIX,
PROP_SMART_RECORD_VIDEO_CACHE,
PROP_SMART_RECORD_CACHE,
PROP_SMART_RECORD_CONTAINER,
PROP_SMART_RECORD_MODE,
PROP_SMART_RECORD_DEFAULT_DURATION,
PROP_SMART_RECORD_STATUS,
PROP_RTSP_RECONNECT_INTERVAL,
PROP_RTSP_INIT_RECONNECT_INTERVAL,
PROP_RTSP_RECONNECT_ATTEMPTS,
PROP_LATENCY,
PROP_SOURCE_ID,
PROP_UDP_BUFFER_SIZE,
PROP_DISABLE_PASSTHROUGH,
PROP_DISABLE_AUDIO,
PROP_EXTRACT_SEI_TYPE5_DATA,
PROP_LOW_LATENCY_MODE,
PROP_SEI_UUID,
PROP_DROP_ON_LATENCY,
PROP_IPC_BUFFER_TIMESTAMP_COPY,
PROP_IPC_SOCKET_PATH,
PROP_IPC_CONNECTION_ATTEMPTS,
PROP_IPC_CONNECTION_INTERVAL,
PROP_LAST
◆ GST_DS_NVURISRC_BIN
◆ GST_DS_NVURISRC_BIN_CAST
◆ GST_DS_NVURISRC_BIN_CLASS
◆ GST_DS_NVURISRC_BIN_GET_CLASS
◆ GST_IS_DS_NVURISRC_BIN
◆ GST_IS_DS_NVURISRC_BIN_CLASS
◆ GST_TYPE_DS_NVURISRC_BIN
◆ GstDsNvUriSrcBin
◆ GstDsNvUriSrcBinClass
◆ anonymous enum
| Enumerator |
| PROP_0 | |
| PROP_URI | |
| PROP_NUM_EXTRA_SURF | |
| PROP_GPU_DEVICE_ID | |
| PROP_DEC_SKIP_FRAMES | |
| PROP_SOURCE_TYPE | |
| PROP_CUDADEC_MEM_TYPE | |
| PROP_DROP_FRAME_INTERVAL | |
| PROP_BUFFER_MODE | |
| PROP_LEAKY | |
| PROP_MAX_SIZE_BUFFERS | |
| PROP_RTP_PROTOCOL | |
| PROP_FILE_LOOP | |
| PROP_SMART_RECORD | |
| PROP_SMART_RECORD_DIR_PATH | |
| PROP_SMART_RECORD_FILE_PREFIX | |
| PROP_SMART_RECORD_VIDEO_CACHE | |
| PROP_SMART_RECORD_CACHE | |
| PROP_SMART_RECORD_CONTAINER | |
| PROP_SMART_RECORD_MODE | |
| PROP_SMART_RECORD_DEFAULT_DURATION | |
| PROP_SMART_RECORD_STATUS | |
| PROP_RTSP_RECONNECT_INTERVAL | |
| PROP_RTSP_INIT_RECONNECT_INTERVAL | |
| PROP_RTSP_RECONNECT_ATTEMPTS | |
| PROP_LATENCY | |
| PROP_SOURCE_ID | |
| PROP_UDP_BUFFER_SIZE | |
| PROP_DISABLE_PASSTHROUGH | |
| PROP_DISABLE_AUDIO | |
| PROP_EXTRACT_SEI_TYPE5_DATA | |
| PROP_LOW_LATENCY_MODE | |
| PROP_SEI_UUID | |
| PROP_DROP_ON_LATENCY | |
| PROP_IPC_BUFFER_TIMESTAMP_COPY | |
| PROP_IPC_SOCKET_PATH | |
| PROP_IPC_CONNECTION_ATTEMPTS | |
| PROP_IPC_CONNECTION_INTERVAL | |
| PROP_LAST | |
Definition at line 22 of file gst-nvurisrcbin/gstdsnvurisrcbin.h.
◆ gst_ds_nvurisrc_bin_get_type()
| GType gst_ds_nvurisrc_bin_get_type |
void |
