7.1 Release
gstnvstreampad.h File Reference
Data Structures
struct  _GstNvStreamPad
struct  _GstNvStreamPadClass
Macros
#define GST_TYPE_NVSTREAM_PAD   (gst_nvstream_pad_get_type())
#define GST_NVSTREAM_PAD(obj)   (G_TYPE_CHECK_INSTANCE_CAST ((obj), GST_TYPE_NVSTREAM_PAD, GstNvStreamPad))
#define GST_NVSTREAM_PAD_CLASS(klass)   (G_TYPE_CHECK_CLASS_CAST ((klass), GST_TYPE_NVSTREAM_PAD, GstNvStreamPadClass))
#define GST_IS_NVSTREAM_PAD(obj)   (G_TYPE_CHECK_INSTANCE_TYPE ((obj), GST_TYPE_NVSTREAM_PAD))
#define GST_IS_NVSTREAM_PAD_CLASS(klass)   (G_TYPE_CHECK_CLASS_TYPE ((klass), GST_TYPE_NVSTREAM_PAD))
#define GST_NVSTREAM_PAD_CAST(obj)   ((GstNvStreamPad *)(obj))
Typedefs
typedef struct _GstNvStreamPad GstNvStreamPad
typedef struct _GstNvStreamPadClass GstNvStreamPadClass
Functions
GType gst_nvstream_pad_get_type (void)
◆ GST_IS_NVSTREAM_PAD
#define GST_IS_NVSTREAM_PAD (   obj)    (G_TYPE_CHECK_INSTANCE_TYPE ((obj), GST_TYPE_NVSTREAM_PAD))
Definition at line 25 of file gstnvstreampad.h.
◆ GST_IS_NVSTREAM_PAD_CLASS
#define GST_IS_NVSTREAM_PAD_CLASS (   klass)    (G_TYPE_CHECK_CLASS_TYPE ((klass), GST_TYPE_NVSTREAM_PAD))
Definition at line 27 of file gstnvstreampad.h.
◆ GST_NVSTREAM_PAD
#define GST_NVSTREAM_PAD (   obj)    (G_TYPE_CHECK_INSTANCE_CAST ((obj), GST_TYPE_NVSTREAM_PAD, GstNvStreamPad))
Definition at line 21 of file gstnvstreampad.h.
◆ GST_NVSTREAM_PAD_CAST
#define GST_NVSTREAM_PAD_CAST (   obj)    ((GstNvStreamPad *)(obj))
Definition at line 29 of file gstnvstreampad.h.
◆ GST_NVSTREAM_PAD_CLASS
#define GST_NVSTREAM_PAD_CLASS (   klass)    (G_TYPE_CHECK_CLASS_CAST ((klass), GST_TYPE_NVSTREAM_PAD, GstNvStreamPadClass))
Definition at line 23 of file gstnvstreampad.h.
◆ GST_TYPE_NVSTREAM_PAD
Definition at line 19 of file gstnvstreampad.h.
Typedef Documentation
◆ GstNvStreamPad
Definition at line 32 of file gstnvstreampad.h.
◆ GstNvStreamPadClass
Definition at line 33 of file gstnvstreampad.h.
Function Documentation
◆ gst_nvstream_pad_get_type()
GType gst_nvstream_pad_get_type ( void  )
