7.1 Release
libs/nvds_rest_server/nvds_rest_server.h File Reference
Data Structures
struct  NvDsServerErrorInfo
struct  NvDsServerDecInfo
struct  NvDsServerEncInfo
struct  NvDsServerConvInfo
struct  NvDsServerMuxInfo
struct  NvDsServerRoiInfo
struct  NvDsServerStreamInfo
struct  NvDsGetRequestInfo
struct  NvDsServerInferInfo
struct  NvDsServerOsdInfo
struct  NvDsServerAppInstanceInfo
struct  NvDsServerInferServerInfo
struct  NvDsServerResponseInfo
struct  NvDsServerConfig
struct  NvDsServerCallbacks
Macros
#define UNKNOWN_STRING   "unknown"
#define EMPTY_STRING   ""
Typedefs
typedef struct NvDsServerErrorInfo NvDsServerErrorInfo
typedef struct NvDsServerDecInfo NvDsServerDecInfo
typedef struct NvDsServerEncInfo NvDsServerEncInfo
typedef struct NvDsServerConvInfo NvDsServerConvInfo
typedef struct NvDsServerMuxInfo NvDsServerMuxInfo
typedef struct NvDsServerRoiInfo NvDsServerRoiInfo
typedef struct NvDsServerStreamInfo NvDsServerStreamInfo
typedef struct NvDsGetRequestInfo NvDsServerGetRequestInfo
typedef struct NvDsServerInferInfo NvDsServerInferInfo
typedef struct NvDsServerOsdInfo NvDsServerOsdInfo
typedef struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo
typedef struct NvDsServerInferServerInfo NvDsServerInferServerInfo
typedef struct NvDsServerResponseInfo NvDsServerResponseInfo
typedef struct NvDsServerConfig NvDsServerConfig
using cb_func = std::function< NvDsServerStatusCode(const Json::Value &req_info, const Json::Value &in, Json::Value &out, struct mg_connection *conn, void *ctx)>
typedef struct NvDsServerCallbacks NvDsServerCallbacks
Enumerations
enum  NvDsServerDecPropFlag {
  DROP_FRAME_INTERVAL = 1 << 0,
  SKIP_FRAMES = 1 << 1,
  LOW_LATENCY_MODE = 1 << 2,
enum  NvDsServerEncPropFlag {
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
  FORCE_INTRA = 1 << 2,
  IFRAME_INTERVAL = 1 << 3,
  BITRATE = 1 << 0,
  FORCE_IDR = 1 << 1,
enum  NvDsServerConvPropFlag {
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
  FLIP_METHOD = 1 << 2,
  INTERPOLATION_METHOD = 1 << 3,
  SRC_CROP = 1 << 0,
  DEST_CROP = 1 << 1,
enum  NvDsServerMuxPropFlag {
  BATCHED_PUSH_TIMEOUT = 1 << 0,
  MAX_LATENCY = 1 << 1,
enum  NvDsServerInferPropFlag {
  INFER_INTERVAL = 1 << 0,
enum  NvDsServerInferServerPropFlag {
  INFERSERVER_INTERVAL = 1 << 0,
enum  NvDsServerGetRequestPropFlag {
  GET_LIVE_STREAM_INFO = 1 << 0,
enum  NvDsServerOsdPropFlag {
  PROCESS_MODE = 1 << 0,
enum  NvDsServerRoiPropFlag {
  ROI_UPDATE = 1 << 0,
  ROI_UPDATE = 1 << 0
enum  NvDsServerAppInstanceFlag {
  QUIT_APP = 1 << 0,
  QUIT_APP = 1 << 0
enum  NvDsServerAppInstanceStatus {
  QUIT_SUCCESS = 0,
  QUIT_FAIL,
  QUIT_SUCCESS = 0,
  QUIT_FAIL
enum  NvDsServerStreamStatus {
  STREAM_ADD_SUCCESS = 0,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_SUCCESS,
  STREAM_REMOVE_FAIL,
  STREAM_ADD_FAIL,
  STREAM_REMOVE_FAIL
enum  NvDsServerGetRequestStatus {
  GET_LIVE_STREAM_INFO_SUCCESS = 0,
  GET_LIVE_STREAM_INFO_FAIL,
enum  NvDsServerRoiStatus {
  ROI_UPDATE_SUCCESS = 0,
  ROI_UPDATE_FAIL,
  ROI_UPDATE_FAIL
enum  NvDsServerDecStatus {
  DROP_FRAME_INTERVAL_UPDATE_SUCCESS = 0,
  DROP_FRAME_INTERVAL_UPDATE_FAIL,
  SKIP_FRAMES_UPDATE_SUCCESS,
  SKIP_FRAMES_UPDATE_FAIL,
  LOW_LATENCY_MODE_UPDATE_SUCCESS,
  LOW_LATENCY_MODE_UPDATE_FAIL,
enum  NvDsServerEncStatus {
  BITRATE_UPDATE_SUCCESS = 0,
  BITRATE_UPDATE_FAIL,
  FORCE_IDR_UPDATE_SUCCESS,
  FORCE_IDR_UPDATE_FAIL,
  FORCE_INTRA_UPDATE_SUCCESS,
  FORCE_INTRA_UPDATE_FAIL,
  IFRAME_INTERVAL_UPDATE_SUCCESS,
  IFRAME_INTERVAL_UPDATE_FAIL,
enum  NvDsServerConvStatus {
  DEST_CROP_UPDATE_SUCCESS = 0,
  DEST_CROP_UPDATE_FAIL,
  SRC_CROP_UPDATE_SUCCESS,
  SRC_CROP_UPDATE_FAIL,
  INTERPOLATION_METHOD_UPDATE_SUCCESS,
  INTERPOLATION_METHOD_UPDATE_FAIL,
  FLIP_METHOD_UPDATE_SUCCESS,
  FLIP_METHOD_UPDATE_FAIL,
enum  NvDsServerMuxStatus {
  BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS = 0,
  BATCHED_PUSH_TIMEOUT_UPDATE_FAIL,
  MAX_LATENCY_UPDATE_SUCCESS,
  MAX_LATENCY_UPDATE_FAIL,
enum  NvDsServerInferStatus {
  INFER_INTERVAL_UPDATE_SUCCESS = 0,
  INFER_INTERVAL_UPDATE_FAIL,
enum  NvDsServerInferServerStatus {
  INFERSERVER_INTERVAL_UPDATE_SUCCESS = 0,
  INFERSERVER_INTERVAL_UPDATE_FAIL,
enum  NvDsServerOsdStatus {
  PROCESS_MODE_UPDATE_SUCCESS = 0,
  PROCESS_MODE_UPDATE_FAIL,
enum  NvDsServerStatusCode {
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusMethodNotAllowed,
  StatusNotAcceptable,
  StatusProxyAuthenticationRequired,
  StatusRequestTimeout,
  StatusPreconditionFailed,
  StatusPayloadTooLarge,
  StatusUriTooLong,
  StatusUnsupportedMediaType,
  StatusInternalServerError,
  StatusNotImplemented,
  StatusOk = 0,
  StatusAccepted,
  StatusBadRequest,
  StatusUnauthorized,
  StatusForbidden,
  StatusUriTooLong,
Functions
NvDsRestServer * nvds_rest_server_start (NvDsServerConfig *server_config, NvDsServerCallbacks *server_cb)
void nvds_rest_server_stop (NvDsRestServer *ctx)
bool iequals (const std::string &a, const std::string &b)
◆ EMPTY_STRING
Definition at line 24 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ UNKNOWN_STRING
Definition at line 23 of file libs/nvds_rest_server/nvds_rest_server.h.
Typedef Documentation
◆ cb_func
using cb_func = std::function < NvDsServerStatusCode (const Json::Value & req_info, const Json::Value & in, Json::Value & out, struct mg_connection * conn, void *ctx)>
Definition at line 360 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerAppInstanceInfo
◆ NvDsServerCallbacks
◆ NvDsServerConfig
◆ NvDsServerConvInfo
◆ NvDsServerDecInfo
◆ NvDsServerEncInfo
◆ NvDsServerErrorInfo
◆ NvDsServerGetRequestInfo
◆ NvDsServerInferInfo
◆ NvDsServerInferServerInfo
◆ NvDsServerMuxInfo
◆ NvDsServerOsdInfo
◆ NvDsServerResponseInfo
◆ NvDsServerRoiInfo
◆ NvDsServerStreamInfo
◆ NvDsServerAppInstanceFlag
Enumerator
QUIT_APP
QUIT_APP
Definition at line 80 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerAppInstanceStatus
Enumerator
QUIT_SUCCESS
QUIT_FAIL
QUIT_SUCCESS
QUIT_FAIL
Definition at line 85 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerConvPropFlag
Enumerator
SRC_CROP
DEST_CROP
FLIP_METHOD
SRC_CROP
DEST_CROP
FLIP_METHOD
Definition at line 41 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerConvStatus
Enumerator
Definition at line 133 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerDecPropFlag
Enumerator
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
DROP_FRAME_INTERVAL
SKIP_FRAMES
LOW_LATENCY_MODE
Definition at line 26 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerDecStatus
Enumerator
Definition at line 111 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerEncPropFlag
Enumerator
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
BITRATE
FORCE_IDR
FORCE_INTRA
IFRAME_INTERVAL
Definition at line 33 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerEncStatus
Enumerator
BITRATE_UPDATE_FAIL
BITRATE_UPDATE_FAIL
Definition at line 121 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerGetRequestPropFlag
Enumerator
Definition at line 65 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerGetRequestStatus
Enumerator
Definition at line 99 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferPropFlag
Enumerator
INFER_INTERVAL
INFER_INTERVAL
Definition at line 55 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferServerPropFlag
Enumerator
Definition at line 60 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferServerStatus
Enumerator
Definition at line 159 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerInferStatus
Enumerator
Definition at line 153 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerMuxPropFlag
Enumerator
MAX_LATENCY
MAX_LATENCY
Definition at line 49 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerMuxStatus
Enumerator
Definition at line 145 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerOsdPropFlag
Enumerator
PROCESS_MODE
PROCESS_MODE
Definition at line 70 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerOsdStatus
Enumerator
Definition at line 165 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerRoiPropFlag
Enumerator
ROI_UPDATE
ROI_UPDATE
Definition at line 75 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerRoiStatus
Enumerator
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
ROI_UPDATE_SUCCESS
ROI_UPDATE_FAIL
Definition at line 105 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerStatusCode
Enumerator
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
StatusOk
StatusAccepted
StatusBadRequest
StatusUnauthorized
StatusForbidden
StatusNotAcceptable
StatusUriTooLong
Definition at line 171 of file libs/nvds_rest_server/nvds_rest_server.h.
◆ NvDsServerStreamStatus
Enumerator
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
STREAM_ADD_SUCCESS
STREAM_ADD_FAIL
STREAM_REMOVE_FAIL
Definition at line 91 of file libs/nvds_rest_server/nvds_rest_server.h.
Function Documentation
◆ iequals()
bool iequals ( const std::string &  a,
const std::string &  b
◆ nvds_rest_server_start()
NvDsRestServer* nvds_rest_server_start ( NvDsServerConfig server_config,
NvDsServerCallbacks server_cb
◆ nvds_rest_server_stop()
void nvds_rest_server_stop ( NvDsRestServer *  ctx)
