Data Structures | |
| struct | _NvSpotCsvFields |
| Data structure contaning all the parameters specified in one row of a Spot CSV file. More... | |
| class | SpotCSVParser |
| Class for parsing of Spot CSV data. More... | |
Typedefs | |
| typedef struct nvspot_csv::_NvSpotCsvFields | NvSpotCsvFields |
| typedef std::map< std::pair< uint32_t, uint32_t >, NvSpotCsvFields > | _SpotIndex_Map |
| std::map<std::pair<surface_id, spot_index>, NvSpotCsvFields> More... | |
| typedef std::map< uint32_t, _SpotIndex_Map > | _SpotCSVMap |
| typedef std::map< string, uint32_t > | _SpotCameraMap |
| std::map<camera-ipaddress, camera-id> More... | |
| typedef std::map< uint32_t, uint32_t > | _SpotCameraViews |
| std::map<camera-id, num_spot_views> More... | |
| typedef std::pair< _SpotIndex_Map::iterator, bool > | _SpotIndexMap_Result |
| typedef std::pair< _SpotCSVMap::iterator, bool > | _SpotCSVMap_Result |
| typedef std::pair< _SpotCameraMap::iterator, bool > | _SpotCameraMap_Result |
| typedef std::pair< _SpotCameraViews::iterator, bool > | _SpotCameraView_Result |
| typedef std::map<string, uint32_t> nvspot_csv::_SpotCameraMap |
Definition at line 68 of file nv_spot_csvparser.hpp.
| typedef std::pair<_SpotCameraMap::iterator, bool> nvspot_csv::_SpotCameraMap_Result |
Definition at line 75 of file nv_spot_csvparser.hpp.
| typedef std::pair<_SpotCameraViews::iterator, bool> nvspot_csv::_SpotCameraView_Result |
Definition at line 76 of file nv_spot_csvparser.hpp.
| typedef std::map<uint32_t, uint32_t> nvspot_csv::_SpotCameraViews |
Definition at line 71 of file nv_spot_csvparser.hpp.
| typedef std::map<uint32_t, _SpotIndex_Map> nvspot_csv::_SpotCSVMap |
Definition at line 65 of file nv_spot_csvparser.hpp.
| typedef std::pair<_SpotCSVMap::iterator, bool> nvspot_csv::_SpotCSVMap_Result |
Definition at line 74 of file nv_spot_csvparser.hpp.
| typedef std::map<std::pair<uint32_t, uint32_t>, NvSpotCsvFields> nvspot_csv::_SpotIndex_Map |
Definition at line 64 of file nv_spot_csvparser.hpp.
| typedef std::pair<_SpotIndex_Map::iterator, bool> nvspot_csv::_SpotIndexMap_Result |
Definition at line 73 of file nv_spot_csvparser.hpp.
| typedef struct nvspot_csv::_NvSpotCsvFields nvspot_csv::NvSpotCsvFields |
