SPDX-FileCopyrightText: Copyright (c) 2018-2024 NVIDIA CORPORATION & AFFILIATES.
All rights reserved. SPDX-License-Identifier: LicenseRef-NvidiaProprietary
NVIDIA CORPORATION, its affiliates and licensors retain all intellectual property and proprietary rights in and to this material, related documentation and any modifications thereto. Any use, reproduction, disclosure or distribution of this material and related documentation without an express license agreement from NVIDIA CORPORATION or its affiliates is strictly prohibited.
NVSPOT CSV File Parser library to be used by applications / libraries
Definition in file nv_spot_csvparser.hpp.
Data Structures | |
| struct | nvspot_csv::_NvSpotCsvFields |
| Data structure contaning all the parameters specified in one row of a Spot CSV file. More... | |
| class | nvspot_csv::SpotCSVParser |
| Class for parsing of Spot CSV data. More... | |
Namespaces | |
| nvspot_csv | |
Typedefs | |
| typedef struct nvspot_csv::_NvSpotCsvFields | nvspot_csv::NvSpotCsvFields |
| typedef std::map< std::pair< uint32_t, uint32_t >, NvSpotCsvFields > | nvspot_csv::_SpotIndex_Map |
| std::map<std::pair<surface_id, spot_index>, NvSpotCsvFields> More... | |
| typedef std::map< uint32_t, _SpotIndex_Map > | nvspot_csv::_SpotCSVMap |
| typedef std::map< string, uint32_t > | nvspot_csv::_SpotCameraMap |
| std::map<camera-ipaddress, camera-id> More... | |
| typedef std::map< uint32_t, uint32_t > | nvspot_csv::_SpotCameraViews |
| std::map<camera-id, num_spot_views> More... | |
| typedef std::pair< _SpotIndex_Map::iterator, bool > | nvspot_csv::_SpotIndexMap_Result |
| typedef std::pair< _SpotCSVMap::iterator, bool > | nvspot_csv::_SpotCSVMap_Result |
| typedef std::pair< _SpotCameraMap::iterator, bool > | nvspot_csv::_SpotCameraMap_Result |
| typedef std::pair< _SpotCameraViews::iterator, bool > | nvspot_csv::_SpotCameraView_Result |
