7.1 Release
nvbufaudio.h File Reference
NvBufAudio Interface
This file specifies the NvBufAudio management API.
The NvBufAudio API provides data structure definition for batched audio buffers. NOTE: Currently the audio data buffers are raw (on system memory). GPU memory support is unavailable.
Definition in file nvbufaudio.h.
Data Structures
struct  NvBufAudioParams
struct  NvBufAudio
Macros
#define RESERVED_BYTES   16
Enumerations
enum  NvBufAudioFormat {
  NVBUF_AUDIO_INVALID_FORMAT,
  NVBUF_AUDIO_S8,
  NVBUF_AUDIO_U8,
  NVBUF_AUDIO_S16LE,
  NVBUF_AUDIO_S16BE,
  NVBUF_AUDIO_U16LE,
  NVBUF_AUDIO_U16BE,
  NVBUF_AUDIO_S24_32LE,
  NVBUF_AUDIO_S24_32BE,
  NVBUF_AUDIO_U24_32LE,
  NVBUF_AUDIO_U24_32BE,
  NVBUF_AUDIO_S32LE,
  NVBUF_AUDIO_S32BE,
  NVBUF_AUDIO_U32LE,
  NVBUF_AUDIO_U32BE,
  NVBUF_AUDIO_S24LE,
  NVBUF_AUDIO_S24BE,
  NVBUF_AUDIO_U24LE,
  NVBUF_AUDIO_U24BE,
  NVBUF_AUDIO_S20LE,
  NVBUF_AUDIO_S20BE,
  NVBUF_AUDIO_U20LE,
  NVBUF_AUDIO_U20BE,
  NVBUF_AUDIO_S18LE,
  NVBUF_AUDIO_S18BE,
  NVBUF_AUDIO_U18LE,
  NVBUF_AUDIO_U18BE,
  NVBUF_AUDIO_F32LE,
  NVBUF_AUDIO_F32BE,
  NVBUF_AUDIO_F64LE,
  NVBUF_AUDIO_F64BE
 Specifies audio formats. More...
enum  NvBufAudioLayout {
  NVBUF_AUDIO_INVALID_LAYOUT,
  NVBUF_AUDIO_INTERLEAVED,
  NVBUF_AUDIO_NON_INTERLEAVED
 Specifies audio data layout in memory. More...
◆ RESERVED_BYTES
Definition at line 36 of file nvbufaudio.h.
◆ NvBufAudioFormat
Enumerator
NVBUF_AUDIO_S8
NVBUF_AUDIO_U8
NVBUF_AUDIO_S16LE
NVBUF_AUDIO_S16BE
NVBUF_AUDIO_U16LE
NVBUF_AUDIO_U16BE
NVBUF_AUDIO_S32LE
NVBUF_AUDIO_S32BE
NVBUF_AUDIO_U32LE
NVBUF_AUDIO_U32BE
NVBUF_AUDIO_S24LE
NVBUF_AUDIO_S24BE
NVBUF_AUDIO_U24LE
NVBUF_AUDIO_U24BE
NVBUF_AUDIO_S20LE
NVBUF_AUDIO_S20BE
NVBUF_AUDIO_U20LE
NVBUF_AUDIO_U20BE
NVBUF_AUDIO_S18LE
NVBUF_AUDIO_S18BE
NVBUF_AUDIO_U18LE
NVBUF_AUDIO_U18BE
NVBUF_AUDIO_F32LE
NVBUF_AUDIO_F32BE
NVBUF_AUDIO_F64LE
NVBUF_AUDIO_F64BE
Definition at line 39 of file nvbufaudio.h.
◆ NvBufAudioLayout
Enumerator
audio sample from each channel shall be interleaved LRLRLRLR
audio sample from each channel shall be interleaved ; LLLLLLLLRRRRRRRR
Definition at line 75 of file nvbufaudio.h.
