8.0 Release
nvds_kafka_proto.h File Reference
Macros
#define NVDS_MSGAPI_VERSION   "2.0"
#define NVDS_MSGAPI_PROTOCOL   "KAFKA"
#define CONFIG_GROUP_MSG_BROKER_RDKAFKA_CFG   "proto-cfg"
#define CONFIG_GROUP_MSG_BROKER_RDKAFKA_PRODUCER_CFG   "producer-proto-cfg"
#define CONFIG_GROUP_MSG_BROKER_RDKAFKA_CONSUMER_CFG   "consumer-proto-cfg"
#define CONFIG_GROUP_MSG_BROKER_PARTITION_KEY   "partition-key"
#define CONFIG_GROUP_MSG_BROKER_CONSUMER_GROUP   "consumer-group-id"
#define CONFIG_GROUP_MSG_BROKER_RDKAFKA_SHARE_CONNECTION   "share-connection"
#define DEFAULT_KAFKA_CONSUMER_GROUP   "test-consumer-group"
#define DEFAULT_PARTITION_NAME   "sensor.id"
◆ CONFIG_GROUP_MSG_BROKER_CONSUMER_GROUP
Definition at line 24 of file nvds_kafka_proto.h.
◆ CONFIG_GROUP_MSG_BROKER_PARTITION_KEY
Definition at line 23 of file nvds_kafka_proto.h.
◆ CONFIG_GROUP_MSG_BROKER_RDKAFKA_CFG
Definition at line 20 of file nvds_kafka_proto.h.
◆ CONFIG_GROUP_MSG_BROKER_RDKAFKA_CONSUMER_CFG
Definition at line 22 of file nvds_kafka_proto.h.
◆ CONFIG_GROUP_MSG_BROKER_RDKAFKA_PRODUCER_CFG
Definition at line 21 of file nvds_kafka_proto.h.
◆ CONFIG_GROUP_MSG_BROKER_RDKAFKA_SHARE_CONNECTION
Definition at line 25 of file nvds_kafka_proto.h.
◆ DEFAULT_KAFKA_CONSUMER_GROUP
Definition at line 26 of file nvds_kafka_proto.h.
◆ DEFAULT_PARTITION_NAME
Definition at line 27 of file nvds_kafka_proto.h.
◆ NVDS_MSGAPI_PROTOCOL
Definition at line 18 of file nvds_kafka_proto.h.
◆ NVDS_MSGAPI_VERSION
Definition at line 17 of file nvds_kafka_proto.h.
