7.1 Release
nvdsinfer_model_builder.h File Reference
Data Structures
class  nvdsinfer::BaseModelParser
 ModelParser base. More...
class  nvdsinfer::OnnxModelParser
 Implementation of ModelParser for ONNX models derived from BaseModelParser. More...
class  nvdsinfer::CustomModelParser
 Implementation of ModelParser for custom models. More...
struct  nvdsinfer::BuildParams
 Holds build parameters common to implicit batch dimension/full dimension networks. More...
struct  nvdsinfer::ImplicitBuildParams
 Holds build parameters required for implicit batch dimension network. More...
struct  nvdsinfer::ExplicitBuildParams
 Holds build parameters required for full dimensions network. More...
class  nvdsinfer::TrtEngine
 Helper class written on top of nvinfer1::ICudaEngine. More...
class  nvdsinfer::TrtModelBuilder
 Helper class to build models and generate the TensorRT ICudaEngine required for inference. More...
Namespaces
 nvdsinfer
Typedefs
using nvdsinfer::NvDsInferCudaEngineGetFcnDeprecated = decltype(&NvDsInferCudaEngineGet)
using nvdsinfer::ProfileDims = std::array< nvinfer1::Dims, nvinfer1::EnumMax< nvinfer1::OptProfileSelector >()>
Variables
static const size_t nvdsinfer::kWorkSpaceSize = 450 * 1024 * 1024
