8.0 Release
nvdsinfer::ImplicitBuildParams Struct Reference
Holds build parameters required for implicit batch dimension network.
Definition at line 158 of file sources/libs/nvdsinfer/nvdsinfer_model_builder.h.
Inheritance diagram for nvdsinfer::ImplicitBuildParams:
Collaboration diagram for nvdsinfer::ImplicitBuildParams:
Public Types
using TensorIOFormat = std::tuple< nvinfer1::DataType, nvinfer1::TensorFormats >
using LayerDevicePrecision = std::tuple< nvinfer1::DataType, nvinfer1::DeviceType >
Data Fields
int maxBatchSize = 0
std::vector< nvinfer1::Dims > inputDims
size_t workspaceSize = kWorkSpaceSize
NvDsInferNetworkMode networkMode = NvDsInferNetworkMode_FP32
std::string int8CalibrationFilePath
int dlaCore = -1
std::vector< TensorIOFormatinputFormats
std::unordered_map< std::string, TensorIOFormatoutputFormats
std::unordered_map< std::string, LayerDevicePrecisionlayerDevicePrecisions
Member Typedef Documentation
◆ LayerDevicePrecision [1/2]
using nvdsinfer::BuildParams::LayerDevicePrecision = std::tuple<nvinfer1::DataType, nvinfer1::DeviceType>
inherited
◆ LayerDevicePrecision [2/2]
inherited
◆ TensorIOFormat [1/2]
using nvdsinfer::BuildParams::TensorIOFormat = std::tuple<nvinfer1::DataType, nvinfer1::TensorFormats>
inherited
◆ TensorIOFormat [2/2]
inherited
Field Documentation
◆ dlaCore
int nvdsinfer::BuildParams::dlaCore = -1
inherited
◆ inputDims
std::vector< nvinfer1::Dims > nvdsinfer::ImplicitBuildParams::inputDims
◆ inputFormats
std::vector< TensorIOFormat > nvdsinfer::BuildParams::inputFormats
inherited
◆ int8CalibrationFilePath
std::string nvdsinfer::BuildParams::int8CalibrationFilePath
inherited
◆ layerDevicePrecisions
std::unordered_map< std::string, LayerDevicePrecision > nvdsinfer::BuildParams::layerDevicePrecisions
inherited
◆ maxBatchSize
int nvdsinfer::ImplicitBuildParams::maxBatchSize = 0
◆ networkMode
NvDsInferNetworkMode nvdsinfer::BuildParams::networkMode = NvDsInferNetworkMode_FP32
inherited
◆ outputFormats
std::unordered_map< std::string, TensorIOFormat > nvdsinfer::BuildParams::outputFormats
inherited
◆ workspaceSize
size_t nvdsinfer::BuildParams::workspaceSize = kWorkSpaceSize
inherited
